Question about Toshiba 35AF44 35" Rear Projection Television
Toshiba 35AF44 Sound on full & will not shut off.
The set comes on when plugged in ac with sound full & no controls work.
I soldered new controls in {on\off,vol up\dn\ect.} same problem but now
it does it after a minute or so if left unplugged when cold.
When cold sometimes works ok for a minute.
I tryed cold spray-no go.
Any thoughts.
Thanks Mike
  • sagey Nov 07, 2008
    Yes, as far as I can tell everything looks ok.
    The keyboard board has the buttons,a few transistors & 1 diode if I remember right.
    What about the audio board that is directly connected to it.
  • 44 Answers
Well, a shorted diode on the keyboard circuit would be likely. When you change out the tactile switches, did you check for any shorts on any of the switches?
Posted on Nov 07, 2008
I have a Sony VCR remote control that is compatible with a Sony TV. The VCR functions work fine but I can't get the TV functions to work. I have set the proper code and installed new batteries, but to no...
All Sony remote controls will be compatible to any other sony products except the other buttons than Ch Up/Ch Dn and Vol Up/Vol Dn. No other buttons won't be.
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Feb 07, 2015 | Sony Televison & Video
Tip
Resetting the Lamp Timer
After replacing the lamp, you need to reset the lamp use timer. The manual is a bit cryptic on how this is done. The manual says "Fn. Up > Fn. Dn. > Vol. Dn > Vol. Up > Enter > Power" However, my remote has no "Fn" or "Vol." controls. Further study of the manual shows that "Fn. Up" = joystick up; "Fn. Dn" = joystick down; "Vol. Dn" = joystick left; "Vol. Up" = joystick right; "Enter" and "Power" are keys on the Remote, "Enter being "6 o'clock" position on the ring encircling the "joystick" I am calling the control that one would use to move the cursor on the screen the "joystick" Thus to reset the timer, key in from the remote "cursor up" "cursor down" "cursor left" "cursor right" "enter" "power"
on Sep 12, 2008 | LG RD-JT30 Multimedia Projector
Dont have the remote control cant turn to channel 3 or 4 dont have a menu button
Isn't there a channel Up/Dn button at the front panel of this TV. It should be there. Only Menu button is not. There is Ch up ' Ch Dn and Vol Up ' Vol Dn buttons, beside a power button. Even pressing the channel Up ' Dn button, the channels cannot be changed, check the micro switches inside the TV. Replace them all at one time. You ave to open the TV to access these components.
Aug 02, 2012 | Sylvania 6719DF 19" TV/VCR/DVD
Turn on without remote control
If the TV was switched OFF by remote control for the last time, you can't switch it back ON, without its remote control.
Just try this. Unplug the TV from AC mains wall socket. Wait for at least 5 minutes and plug it back. Switch it ON by its front panel power ON/OFF switch. Just press any button [Ch UP / Ch DN or Vol UP / Vol DN] Sometimes this might turn ON your TV.
Jun 02, 2012 | Televison & Video
Cp9430r
Fixed Hunter ceiling fan with remote light pin out wiring 9 wire plug search words
Hunter Ceiling Fan with remote, fails to turn on light, fails to turn on fan..remote receiver is Cp9430r
1) Test your remote, Hunter uses Radio Frequency remote, point RF remote one inch from antenna of working AM radio, press each button on remote, each button will produce static sound from AM radio, if no sound..check battery wiring or solder connection on loop antenna of remote. If no sound on one or more buttons, disassemble and wash key pad with dish soap, rinse and fan dry, retest. If still one button no work apply graphite paint to button to rebuild conductivity of button.
2) Cp9430r receiver is below fan and above light. Remove light assembly, check receiver dip switches, mine was #5 On 1~4 Off, check remote control dip switches in 9v battery compartment also set #5 On 1~4 Off, new 9v battery still no Fan reversal "click" sound heard coming from the large Blue fan reversal relay located inside the Cp9430 receiver. All other buttons control transistors and will make no sound even if they are working.
3) Disassemble / unplug 9 wire plug from Cp9430r receiver, place receiver on wooden table, 9 wire plug has two empty pin squares, one empty in the center, the other empty we will call #1 ..counting clockwise #2,#3...#4,#5..#6,#7and finally top center next to empty #1 is #8. Now #8 is 110v hot/black ...& #4 neutral/white.
4) Shock Danger..carefully apply ac volts to pins #8,#4 use tape if needed, locate quad operational amplifier i call it radio receiver chip HA17324 on board, google HA17324 Datasheet, locate leg #14 it is across from leg #1. Locate small yellow ceramic capacitor very near leg #14, use capacitor's neg as neg for voltmeter, test volts at #1,#7,#8 and #14. My #1 was 3.1v, #7 3.2v, #8 3.25v and #14 .01v ...why #14 so low? I monitored each leg while pressing remote control buttons...no changes. **Desperate, I sparked (1/2 second or less) #14 with 3.14v from positive leg of yellow capacitor** and retested all legs, no change except now #14 rests at .02v and jumps to 2.5v~2.8v when any button on the remote is pressed then rests at .02v. Now Lights work, Fan speeds work, Reverse rotation Works :-)
Pin Out on 9 wire plug, #1 Empty pin, #2 Alternates w up/down fan rotation, #3 goes to 5uf fan capacitor other side of cap goes to white/neutral AC Line, #4 AC Line neutral, #5 goes to Triac? speeds? , #6 Alternates up/down fan rotation goes to up/dn blue relay, #7 goes to up/dn blue relay looks to be AC hot looking for fan probably paired with #3 changing sides at up/dn blue relay, #8 AC Line hot in. Why did **sparking** work, smarter people might know, i think a small spark got stuck in the chip and sparking helped the chip release it out. No electrical education, novice. Jer. 51 8,9 and 11
Feb 24, 2012 | Hunter (25417) Ceiling Fan
AV input selection without a remote
I had the same problem. I hooked up the DVD player and then got into the set up. I used the add/erase feature to go through all of the channels. At channel 91, I saw the logo for the dvd player. I added that channel and now the dvd player works.
Jan 24, 2009 | Televison & Video
Prima TV Model Q2016 comes on when plugged in.
the prima tV that co on as soon it is pluged in 90% of the time the Micro IC causes that proplem you need to replase the micro
Dec 14, 2008 | Zenith B19A02D 19" TV
Magnavox portable TV
Try hitting VOL UP & VOL DN at the same time.
Your set is in the demo mode.
Stargazer
Dec 27, 2007 | Philips Magnavox 20MT133S 20" TV
No remote
If you have a menu button on
the front panel you can by
using the ^/v </> buttons
(ch up ch dn vol up vol dn)buttons
to navigate the onscreen menu
If not you will need to purchase a
universal remote with a menu set
enter tv/vid pip button and a working
code for your tv you may have to try
more than 1
Nov 20, 2007 | Sony KV-13M10 13" TV
Reset lamp timer
you need to enter factory Menu.
You do so by doing the following:
1).Start the projector.
2).Press keypad <Source> and <Auto> keys simultaneously, enter " Lamp Hour info" layer
3). Press <Source> and <Auto> keys simultaneously again, then enter factor menu.
Do not change anything till you reach Lamp Layer where lamp hour and usage hour is given. If you reset, then all data revert to default - factory reset. you may chage here or under (2).
Let me know if this solves your problem.
Sep 03, 2007 | LG RD-JT30 Multimedia Projector
Toshiba 35AF44 35" Rear Projection Television Logo
62 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
