Question about Sony DVP-NS501P Progressive-Scan DVD/CD Player : ** Now Your Chance Brand ** CD Player
Sony CD/DVD Player DVP-NS501P
Have misplaced the manual and cannot figure out how to connect the TV to the DVD player ... neither can anyone else!  I need help!  Can anyone help me ~ I'M DESPERATE!
Lost in the the Sierras
There are several ways to connect the TV to the DVD player but you can only take advantage of the progressive scan option on your player if you use component cable. Component cable has three input jacks on it and they are colored Green, Blue, and Red. Your TV/amplifer must have component input jacks on the back of it to use this cable. If it does, then the input jacks on the back of the TV are usually labled Y, Pa, and Pr. The Y input is for the Green input jack, the Pa input is for the Blue input jack and the Pr is for the Red input jack. Once you have these plugged in you will next need to hookup the audio/vidoe cable that came with your DVD player that has a Yellow, White, and Red input jacks on it. The Yellow input jack is for Video and the White and Red are for audio. Both your TV and DVD player will have inputs for these so just match them up. If you do not have component inputs on your TV then just hook up the audio/video cable and it will work.
Posted on Nov 15, 2008
Bought a soney dvp-ns501p at yard sale for $15 no remote.can I buy an cheap universal remote?
HELLO
My advice to you is buy the original remote! Lots of these so-called UNIVERSAL types never have all functions so get the proper remote and set it up right!
May 14, 2010 | Sony DVP-NS501P Progressive-Scan DVD/CD...
No sound coming from sony dbp-ns501p
check wires if nothing then its broke replace
Oct 31, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Movie has no red color only green and yellow
Remove & re-seat the component video cables at both the TV and the DVD player.
If the problem continues, disconnect BOTH ends of the BLUE cable and the RED cable. Connect the BLUE cable to the RED jack at both the DVD and TV, and connect the RED cable to the BLUE jack ob both the TV and DVD. If the RED color comes back and the BLUE is missing, then replace the RED cable (the red cable is broken and will not pass the signal that it is connected to).
If all works, reconnect the colored cables to the corresponding colored jacks at both the TV and DVD player.
If the RED color still won't display, isolate the trouble to either the DVD player or TV by connecting the DVD to another TV w/ component jacks. If the RED is still missing, it is a problem inside the DVD player - if the RED displays, it is a problem with the TV.
Sep 30, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
I need help connecting sony dvp ns 300 to a jvc tv. I can't watch dvd at all, confused about the wiring where does it go?
The CD/DVD player has three output ports:
(i) Line out Video used to connect the yellow pin of composite cable.
(ii) S-video out use d to connect an S-video cable.
(iii) Component video out (red, blue, green) used to connect a component video cable.
So, in order to connect the CD/DVD player to the TV, the TV should have either of the corresponding input port on it.
However, the video quality transmitted by component video cable will be the best among the three.
So, you may connect the TV and the CD/DVD player using an appropriate cable.
All the above connections require an additional audio cable to transmit audio from the CD/DVD player to the TV.
In this case, you may use an RCA (red and white) audio cable to connect the "R and L" audio out port on the CD/DVD player to the corresponding "R and L" audio in port on the TV.
Performing all the above steps will help you get the DVD player work with the TV.
wish u good luck!!!!!!!!!!
Sep 17, 2009 | Sony DVP-NS300 DVD Player
I have a Sony DVPNS501P ProgressiveScan DVD/CD Player and my remote died. I bought a universal, but it won't control the menu option...so i can only turn it on and off and press play, stop or pause. The...
You need a learning remote control or check e-bay. Almost any Sony DVD remote will work. 10-20$ If you list the model # of the remote I may even have one. Hope this helps
Aug 17, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
I need to know how to hook up DVD player with Cable TV I have the cable with the white yellow and red. I hook one end into the TV and one into the DVD player. I don't get a pic or sound. I do not havethe...
The key is having at least a Universal Remote ($10.00 or less) that will operate your brand of TV. Your TV is only looking at "stations". You need to make it see Aux-1, Aux-2, or Line In mode. BUT, another trick is to run the DVD into your VCR (if capable). Select the VCR proper "input mode" (Aux-1, Aux-2, or Line In mode) then the DVD will play through the VCR and it will play through the TV on either channel 3 or 4. Problem solved!
Jun 27, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Sony CD/DVD Player DVP-NS501P: It says LOCKED when I try to eject
What you have to do is unplug it and plug it back in it resets the dvd player
Nov 15, 2008 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Will not play disc
you may have a region1 player and are trying to play a region 2 disc or vise versa or if you are playing copyed dvds are they finalized.
Jun 05, 2008 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Sony DVP-NS501P Progressive-Scan DVD/CD Player : ** Now Your Chance Brand ** CD Player Logo
282 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
