Question about American Standard Colony 3275.505 099 Chrome/Brass Mixage Soft Two-Handle B...
No hot water from faucet but when i turn on the shower there is hot water. What is causing this?
  • Anonymous Nov 24, 2008
    Hubby installed new electric water heater last week. Was great for a week, now there's hot water to only one half of the house (upper and lower floors for kitchen and one bathroom fine, upper and lower for baths on the other side of the house, no hot water.) What could be wrong?
  • 374 Answers
Let's start with assuming nothing okay. There may have been two cold water lines ran to the faucet at time of a repair in error. The stop under the sink could be turned off. The supply pipes may be connected backwards making cold hot and hot cold.The stem on a single handle model may be installed incorrectly. A piece of trash or part of the valve seat- if an older two handle type - may be obstructing the water flow. You could also have a ruptured pipe under the slab.
Let's start with the worst case scenario first- a break in the piping system. Shut all water off inside the house as well as any outside faucets etcetera that may cuse the usage of water. Go to the hot water heater and close the hot water valve. Now go to the water meter and see if the meter is moving- it should be stationary. If you use a pump check for a loss in pressure at the bladder tank. If all is good go and open the hot water valve and check again at the meter. If the meter is moving there is a break in the line. If not we will proceed.
Now go to the sink you have issue with and check the stops to see that they are turned on. If so turn them both off and get you a bucket, towel, flashlight and a basin wrench and remove the hot water supply line. Once you have this done bend the line into the bucket and turn the stop back on and see if you get hot water here. If not try the same with the other supply line. If neither produce hot water you more than likely have a cold line ran to both supplies. If you are able to get hot water than the issue is within the faucet. Re connect the supply lines and leave the stops off. Remove the stem from the faucet and turn the stop on a bit to flush out trsh and debris. If you have a stem that uses a valve seat - a small piece of rubber attached to the bottom of it by a screw- check to ensure that it is not missing parts of it that may get lodged in the valve itself. Assuming this is new house, to you anyway, it is also possible that the manner in which the hot water line to that appliance was ran from to far away from the water heater and requires a great deal of time before it reaches this appliance.
I hope this assists you to some degree and apologize for being longwinded. Thanks for using Fix Ya and if I can be of further assistance please let me know.
Jim
Posted on Nov 09, 2008
Why don't I have water pressure on the hot water side of any faucets
Most class a mtorhomes have water valves in your water fill bay that have controls for all faucets. There is separate one for hot and cold.
the hot would be turned off for storage to allow you to drain the hot water heater for storage.
there may be hot water valve for all faucets or one valvefor each faucet.
Jul 21, 2014 | Itasca 2008 Ellipse 40WD
I have two vanities and a shower in the bathroom. We only get hot water to the sinks when we turn on the shower to hot. Even if we turn off the shower we will still get hot water for a while. It just seems...
Check the water supply lines to the shower at the faucet handles. If the fitting for the hot water line connected to the handle is loose, it can twist and kink off the water supply further down the line when you turn the faucet handle. I'm not exactly sure how this could be relevant otherwise, but under normal design circumstances this type of scenario with your shower wouldn't matter for other faucets.
May 01, 2011 | Delta Faucet Bathroom Faucet - Delta 2...
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
& One Handle Tub & Shower Faucet : i have a moen shower faucet and i get not hot wate...
these valves can be adjusted by removing the handle and adjusting the white gear that regulates the hot and cold that come out, try going more to one way if it gets colder then go the other way.
May 16, 2010 | Moen & One Handle Tub & Shower Faucet
No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
Oct 07, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Shower problem
This must be a joke because there is no way the shower is connected to your faucet. the faucet on you vanity is connected directly to your hot and cold water supply. And only by opening the hot water side of the faucet can you get any hot water.out of the faucet.
Aug 01, 2009 | Home
No hot water flow from faucet/shower
change the cartridge it is bad or defective.
Jul 20, 2009 | Delta & Single Handle Shower Faucet
American Standard Colony 3275.505 099 Chrome/Brass Mixage Soft Two-Handle B... Logo
183 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
Steve Wood Plumbing...
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
