Question about Maytag MGR5770 Gas Kitchen Range
Maytag MGR5770 Gas Kitchen Range displays OFF and nothing works!
I had to work on some electrical ckts in the kitchen today, so turned the power off and the breaker box. When I turned to power bakk on the Stove's Oven won't work. can't set time or anything. Stove has power to it since the oven light works. Manual doesn't say anything about a display of OFF.
Thanks in advance
  • 2 more comments
  • truettdc Nov 07, 2008
    The display is blank. When you push any button the word "OFF" is displayed for about 15 seceonds and then goes away. Off is displayed in the same place the 3 digits would be displayed if you were setting temp of the oven.
    Test the fuses? Within the range or breaker box? If your talking about the breaker box the circuit is fine.
    It's not that the ocen won't light, the control panel is blank except for the word "OFF"
  • truettdc Nov 08, 2008
    If I think it's bad????
    I was hoping that someone would tell me if it is, or is not bad, if it displays the word OFF. Maybe there some kind of reset other than cycling powere on and off. Surely the hard software installed in the display was programed to display this under certain conditions...Yet know one has ever seen the display read OFF
  • Maytag Master
  • 19,396 Answers
That is normal, whenever you cut power the range goes in Off mode, that is a safety standby mode. The same as you first installed the kitchen.
No faulty thing and no need to take apart anything, do not disassemble the appliance.
The usual procedure to activate back the kitchen range is by downpressing the timer main wheel.
If this does not work, then there must be a different command, check the user instructions , or try playing withthe controls.
Posted on Nov 07, 2008
    Sergeant:
  • 306 Answers
Its that a few screws will drop rear panel to check connections, , check your power supply as well possible bad connection at outlet
  • AbdulRahiman S Nov 07, 2008
    i suppose there may be irregular power supply!!so better to contact a service man who can have a direct look at urs and solve tis!!
    else unplug it for sometime and then plug it.. reset the timer and then set to any point.. it may become normal
  • 849 Answers
Must be defect in power supply, check if you can the power output components of power supply, if u dont, try some technician
    Brigadier General:
  • 6,966 Answers
Initially, pls try to unplug from the mains, this simulates a reset.. Additionally, try to reset the circuit breakers. It is possible that only one engaged. In some models, there is a reset button at the rear of the unit. If none is corrective, it would appear that the system controller/logic needs looking into.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 08, 2008
    Hi again,
    I was reviewing past similar cases. It would appear that in some incidents of similar concern, the keypad has been determined to be faulty, might you want to try and check it out. Incidentally, some versions has a tech sheet somewhere inside or behind one of the panels.
  • Louie  Role
    Hi again,
    Any development(s) so far?
    Genius:
  • 1,239 Answers
Hi The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
    Master:
  • 505 Answers
Most likely cause for the problem described is a weak HSI. Hot Surface (Glowing) Igniter. Replace that part as a first do it yourself attemp to correct the problem.
Retail parts dealers and appliances parts stores can also help determine what the possible problem may be based upon that specific brand and model. Bring the make, model and serial numbers. Dealers and appliances parts stores are listed in the phone book.
Additional Suggestions:
Read the manufacturers on line web site for product information, problem possibilities, causes, solving methods, part locations, disassembly, reassembly methods, repair procedures, pictorials, schematics, repair and or owners manuals which may be available on line.
Cautionary Reminder Note:
Before attempting any repairs, be sure to unplug the appliance from the wall receptacle power source first.
Range-Stove-Oven-Broiler Basic Help Information & Manufacturers Web Sites. Range/Stove/Oven/Broiler Info, Leak Detection, Fault Codes, Fuel Conversion & Links
Use the reply button to add additional information or questions. Using the reply button keeps or moves the topic back up to the top of the list automatically and keeps all communications on this subject in this thread.
Regards and Good Luck. Web Site Host, Moderator Hiring Agent, Gas Appliances Topic Moderator, Multiple Forums Moderator & Natural Gas Appliance Diagnostics Technician.
Personal Driving Safety Reminder: Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own." __________________
    Sergeant:
  • 207 Answers
Your Oven has two igniters in it since it is unlikely that BOTH went bad at the same time, I would try having the sensor at the back of the oven or the electrical cord checked.
That would be the 2 most likely causes
If this doesn't help please post back and I will try to offer more advice
Thanks
Dave
  • David Preston
    David Preston Nov 07, 2008
    With the display being blank I think we can probably narrow it down more to the cord or possibly the clock timer, as the display should not be affected by a faulty sensor
    Hope this helps
    Dave
    Genius:
  • 1,550 Answers
Fuses can become weak, burn out or blow out.
Check for fuses and test them for continuity.
  • SAM ANDERSON Nov 07, 2008
    I need you to test inside the range .
Stove top works , oven does not
If the ignitor is not glowing to lite the oven then it needs to be replaced. Here is that part to order.
Whirlpool 74007498 Oven Ignitor AppliancePartsPros com
Mar 20, 2014 | Maytag MGR4452BDW / MGR4452BDQ /...
Low gas in during cold weather
Get you gas supplier out there. The meter pressure is off.
Dec 28, 2010 | Maytag MGR5770 Gas Kitchen Range
Gas Oven Won't Light
make sure the wire is connected to the ignition(where it sparks)if it is gently clean the sparking surface with a piece of fine sandpaper.Hope this helps,if it still does'nt work you may need to replace this part but it should'nt be expensive and you can do it yourself(usually one screw) ps sorry for the late reply.
Mar 07, 2009 | Maytag MGR5755QD CleanDesign Gas Kitchen...
Natural gas to lp
I have a. caloric mod rls340 with regulator. what is the procedure to switch it to lp from nat gas??
Dec 30, 2008 | Maytag MGR5770 Gas Kitchen Range
Panel off
Try cutting the power off to the unit for 10 minutes. most of the time this will reset the clock and it will work fine. if not replace the clock.
Nov 20, 2008 | Maytag MGR5770 Gas Kitchen Range
MANUEL
baking system-not lighting up.Code f-9 did show up.broiler works.Please advise
Sep 15, 2008 | Maytag MGR5770 Gas Kitchen Range
Clock display/oven control panel
a few screws will drop rear panel to check connections, , check your power supply as wellpossible bad connection at outlet
Feb 25, 2008 | Maytag MGR5770 Gas Kitchen Range
Maytag MGR5770 Gas Kitchen Range Logo
346 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
