Question about IBM ThinkCentre S50 8183 - P4 3 GHz (8183D9U) PC Desktop
How to repair..IBM 240 w Powersupply...
IBM. power supply just gone dead, guess . due to pwer surge...i opened the unit but couldnot find any FUSE...can u plz help me...
    Sergeant:
    Champion:
  • 258 Answers
How did you know that's the problem is on power supply?what signs did you saw before it happened
Posted on Nov 14, 2008
IBM wont wake up
Unplug, remove battery, Plug in, reboot, Open the Control Panel, select Power Options, Select High Performance, you didn't supply the Model of IBM or the OS, so I'll give you a Win 7 solution, open Change Plan Settings, under Plugged in, select Never and Never, select Advanced Power Settings, Adjust Sleep and Hibernate to Never, adjust ALL settings to your preference. Always shut down and unplug your machine when not in use, it will last longer and prevent damage due to a power surge, and IF your Battery malfunctions COULD prevent a fire hazzard.
Feb 26, 2013 | IBM ThinkPad Computers & Internet
Gaggenau fryer won't heat
check to see if there is some kind of breaker on the unit, it should be like a reset button. some kind of safety switch has tripped, you need to find out what and where it is.
Nov 19, 2007 | Kitchen Appliances - Others
Plugged in heard a pop noise now no power
power voltage differences cause burn outs in power supplies
if it is a 120 volt supply unit and you plugged it into 240 volt supply then to bad so sad --junk it
Jun 23, 2017 | Logitech Z623
No start ,dead
Hi alonzot,
Here are some basic steps that will help you fixing the problem.
I'm assuming that your unit is dead set without an standby LED light and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I would advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts in the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact , don't attempt to touch anything because there some fatalcomponents stored electricity enough to hurt you with a simple mistake only. I would advice you to look for a professional to troubleshoot the power supply. If you want to repair it yourself make sure that you have necessary tools and test instrument. First check bad solder joints(re-solder all cold solder), leaky electrolytic capacitor(sometimes it has bulged at the top but not all, you better have a capacitor checker), open/shorted regulator transistor/IC(mounted in heat sink), open fusible resistor (caused by shorted regulator Transistor/IC), shorted zener diode.
You may also replace the power supply board, try online like ebay.com and shojimmy.com.
Also check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Apr 25, 2011 | Soyo DYLM1798 Monitor
Chassis is completely dead
Hope I helped you.
Have a nice day!
Mar 12, 2011 | Panasonic CT-27G23 27" TV
Nothing happens when plugged in and I guess the power button is on the side and it still wont turn on.
Hi ,
Here are some DIY steps that may help you fixing the problem.
I'm assuming that your unit is dead set without an standby LED light and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I've advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts on the power supply, you may visit the link http://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact on the board, don't attempt to touch anything because there somefatal components stored electricity enough to hurt you with a simple mistake only.
The next steps should be done by an expert or qualified technician because isolating the problem on the power supply is quite technical.
Give a thumbs if you find it useful.
Feb 07, 2011 | Philips Televison & Video
I have no power after my power flicker during a snow storm. I stheir a fuse or reset? What might be wrong no pwer at all
Hi Gloria,
The problem in your unit is internal, Ive advice you to find friends that can perform the FF:
Hope it may help you.
Feb 07, 2011 | X2Gen MV37R 37 in. LCD TV
My dell gx270 power supply has been burnt how can i repair it
If the power supply has been burnt, individual electronic components likely failed due to a power surge or other issue, and you may have experienced a short within the unit. Unfortunately, due to advanced difficulty and low cost, power supplies generally are not repaired, they are replaced instead.
Aug 04, 2010 | Dell (1N405) 180-Watt Power Supply
We are using this server for more than 3 years. yesterday, server switched off due to voltage surge. afterthat it is not turning on. even smps not switching on..
Sounds very likely that if the power supply isn't even showing signs of life then the surge has killed it, it'll need to be replaced. If your lucky then no other components have been damaged.
The supply in that unit (according to google) is an IBM 340W Power Supply - 24P6898. My searches have found a few refurbished units for about £40.
Nov 20, 2009 | IBM eserver xSeries 205 8480
HP Pavilion will not power up
Yes pwer in entering since the LED lights up but most probably your SMPS orpower supply has fried due to a voltage surge. Try replacing the Power supply unit and see if there is any difference(use a working SMPS for trial and if this works, you have the solution...........sodeep
Mar 30, 2009 | Computers & Internet
Computers & Internet Logo
123 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
