Question about Mitsubishi CS-27205 TV
Sound but no video
Hello all. I have a problem with my Mitsubishi CS-27205 TV. I turned it on this morning and I have perfect sound but no video at all. I have only a VCR hooked up to it, and video problem happens via coax cable or A/V cables. I can't make the adjustements to the screen because even the on-screen display does not show up. A different TV worsk fine in this setup so i don't have any issues related to the incoming cable. Any ideas? Is this fixable or is my TV essentially dead? Thanks in advance for any help you can give me. Dan
    Scholar:
  • 68 Answers
This looks like an internal fuse has blown, or a problem with the start up circuit. It could be just a small mains transformer about 5 cm cube in size has a fault. They have a built in over temperature cut out which may take half hour to reset.
Posted on Oct 16, 2006
I have tv a cs 27205 that the image show big spots
Sounds like the picture tube is burnt out. It can happen when the television is left in direct sunlight. There is no cure for it, you can however put in a darker area and over time it may clear itself up.
May 23, 2011 | Mitsubishi CS-27205 TV
Lost remote and tv is stuck on parental code screen mitsubishi cs 27205
Hello phillip and welcome to FixYa. A possible easy solution would be to power offf the television and unplug it. You should leave it unplugged for about 15 minutes. This Should remove the parental control screen and solve your problem. I hope this solution works out for you and good luck.
Apr 24, 2011 | Mitsubishi CS-27205 TV
Mitsubishi diamond vision 27" 1995
It is an indication of leaky electrolytic capacitor on the vertical section.
This is not a diy if you are not an expert.
I've adviced you to look for a qualified technician to replaced the faulty capacitor.
This is quite fixable and easy to locate by the technician.
pls rate my help...
Thanks for using fixya.
Jan 14, 2011 | Mitsubishi CS-27205 TV
I have a tv mitsubishi model cs 27205 the problem is green screen, what is the problem?
CHECK RESISTORS ON CRT BOARD .THE BOARD IS MOUNTED AT THE BACK OF PICTURE TUBE .
Aug 12, 2010 | Mitsubishi CS-27205 TV
Screen is black except for thin line in middle of screen
The problem is in the vertical section of the main board. Bad capacitors and maybe the vertical IC. If you are not inclined to be a tech you will have to take it to a shop.. I don't know what they may charge but I normally get $69- $89
Apr 10, 2009 | Mitsubishi CS-27205 TV
TV problem
Hello Barbara76,
Is this a Horizontal line (inch or two) across the screen, if so
the fault could be either a faulty Vertical IC,Faulty Electrolytic
capacitors or just simple dry joints.
Regards
Patrick
P-Tronics
Feb 03, 2008 | Mitsubishi CS-27205 TV
How do I get closed caption on my TV?
Step thru video menu selections one at a time until CC comes
up, then change with plus or minus....can be done with remote
or at set............if more help needed, do we have the owner'
manual ?....................Please let me know....T.
Dec 27, 2007 | Mitsubishi CS-27205 TV
Mitsubishi CS-27205 shrunken picture
Good set...worth repairing vertical circuit.....in shop...
about 100.00........................T.
Nov 15, 2007 | Mitsubishi CS-27205 TV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
