Question about Jenn-Air JMC7000 Microwave Oven
Seal replacement? I think the seal on my JMC7000 door is leaking. There is condensation between the glass panels in the door and when cooking steam condenses on the cabinet just above the door. A moment ago the microwave shut off completely while cooking rice (as if the control electronics was faulty - or got wet?) with a blank display. After leaving the door open for a few minutes the display lit up again with no user intervention. I see from some online diagrams that one can replace the door seal: 1) Do you think this is the issue? 2) How do you remove and replace the seal if this is the problem? Are there clips holding it in place?
  • Mawrob Nov 07, 2008
    The other thought I just had is that there might be an extractor fan that is not working?
  • Jenn-Air Master
  • 9,086 Answers
It sounds like your cooling fan has failed, or possibly the relay on the control board. This same relay also runs the turntable. Is the TT working?
It's critical for the cooling fan to work, or the magnetron can overheat, which will cause the thermostat to interrupt power until it cools backs down. Sounds like what happened to you.
If it gets too hot or gets hot too often, it can be ruined.
A failed fan can cause such overheating and a buildup of moisture as well.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Nov 08, 2008
My y ovan glass was broken wher it was change
The glass front of the microwave is not important, as long as the mesh behind it is intact.
You may replace it at your leisure, or just ignore it.
To check your microwave for leaks, simply place a mobile telephone inside (do not switch the microwave on unless you are tired of the mobile telephone) and close the door. Ensure the microwave is plugged in. This will create a Faraday cage if the microwave is leak-proof.
Now dial the mobile telephone number. If it rings, you have a leak. Conversely, if not, there is no leak.
Happy cooking!
Jan 28, 2015 | Microwave Ovens
Brand new Model mircowave BMC253SS installed at the end of April. Condensation getting within the glass door this as already been replaced by your Baumatic Engineer yesterday and it is still happening....
Sounds like you need to call them back, they should warranty their work. Make them do it until ti is right. Make him show you it doesnt steam up before he leaves. OR Dont pay them and dont sign off that it is fixed.
Oct 14, 2017 | Microwave Ovens
Door glass is lose and seal is leaking..moisture is forming on inside of glass
That is normally caused by the clear plastic adhesive cover either having been removed or missing. It covers the perforated door inner and stops condensation and food particles from getting inside the door cavity where is cannot be cleaned.
Feb 14, 2011 | Goldstar MV-1526 Microwave Oven
Condensation inbetween glass door on GE Spacemaker
Your glass seal has failed and I doubt it makes sense to replace the door. Yes, it can be dangerous as the moisture becomes worse you risk the chance the glass could over-heat and blow out. Sounds like you need to replace it, sorry!
Aug 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Leaking Microwave door seal (between grated and back of door)
I think that you can get the plastic wet, ie sponge, or lick.
Jun 26, 2009 | Microwave Ovens
Condensation marks on microwave door
For most microwaves the process is pretty straightforward. You can open the door and you will see the screws that hold the outerinside panel on to the glass. After you remove those screws you will see the screws that hold the ouside cover to the door in place. Once you get that far you will see what is holding the glass in place. Keep in mind to replace the gaskets around the glass right and anything you take off to get to the glass itself. If you are getting condensation from range top cooking then the seal around the glass may need to be replaced. You really cannot hurt anything by taking it apart, but it needs to be put back together exactly the way you take it apart. Good luck and hope this helped.
Jan 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
When the oven is cooking for over 5 mins part of the door goes a white opaque colour inside the door, it is as if the seal is broken and steam is getting inside the door itself.
That's probably what's happening, but it's not dangerous as long as the internal cooling fan is running and the screen / mesh between the door panels is not arcing or rusting.
It's suggested that you leave the door open for a few minutes any time you cook and notice a moisture buildup afterward.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 20, 2008 | Panasonic Microwave Ovens
Condensation betwejn the front door glass
This would require disassembly of the door panels, which is not recommended unless really required.
You can download the installation guide to help you troubleshoot and correct your venting issues. That should be priority one.
It may be a clogged filter, a bird's nest in the outlet, etc. etc. Failure to vent can cause control panel and keypad trouble if it continues.
The manual / guide is found here: http://www.geappliances.com/service_and_support/literature/
Nov 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Jenn-Air JMC7000 Microwave Oven Logo
280 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
