Question about GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Galaxy 24.5 side by side Ice maker problem
The inside of the ice maker plug on a chain came out and is suspended on the hanging chain. How do i replace the plug so the ice maker will function properly.
Fred
  • 709 Answers
This is Going to take some study on my part. I have never seen a Galaxy Fridge. In the mean time, Try taking the entire Ice maker out of the Freezer and study it closely to see where the Plug might fit. This is basically what I would be doing. I will be back if I can find a definate answer for you.
Greg
Posted on Nov 07, 2008
  • Greg Stokes
    Greg Stokes Nov 07, 2008
    Fred,
    I am unable to find any Documentation on a Galaxy Refridgerator at all. I checked in several places, and even with Sears. Nothing available for me to help you with. I apologize and wish you luck. All I can say is to remove the icemaker to get a better look and fit the plug.
    Greg
Icemaker will not shut off
The ice maker has a pin plug in the back of most model refrigerators. Disconnect there if nothing works to turn it off. What is the model number of your refrigerator? Does the ice maker have a shut off arm that turns the ice maker off, switch or does your model refrigerator have an electronic eye that turns the ice maker off? Let me know what you find, Thanks Sea Breeze
Nov 15, 2012 | GALAXY Microsystems 25.4 cu. ft....
Ice maker has not been working?
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
fshsf45
Jul 18, 2010 | GALAXY Microsystems 25.4 cu. ft....
Ice maker is not working - not making ice - water dispenser is working fine
heatman101
te95
Dec 07, 2009 | GALAXY Microsystems 25.4 cu. ft....
WP side-side freezer appears to be overflowing the
You just need a new water valve for this unit. Call us with your midel number and we'll be sure to get the right part out to you right away! We look forward to hearing from you soon.
Oct 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore Galaxy Ice Maker Not Making Ice
Sounds like you have a bad water valve. It will have a dual water valve on the back where the water connects to the unit. You can take the wire plugs and swap them around. Then push the water in the door leaver. hold it for around 4 sec. Then see if the ice tray has water in it. If it does, you have a bad valve. If not you ice make is bad, turned off or the freezer is not cold enough to operate. ( It has to be 5degrees or lower before the ice maker will try to operate)
Please rate this solution if it helps. Thanks
Aug 19, 2009 | Kenmore 57029 Side by Side Refrigerator
Water leaks from ice maker in ice tray.
When the ice maker calls for water it'll be filling for about 7 seconds if is more the ice maker inside control board is bad , but if there's water in the ice maker all the timeeven after or before it calls for water it means that the water valve (solenoid) that supplies water to the ice maker is leaking and you have to replace it.
Apr 27, 2009 | GALAXY Microsystems 25.4 cu. ft....
Ice maker
This should fill up automatically. It takes 24 hours to have that basket full of ice cubes it might take longer depends on conditions. The arm inside is what controls the ice maker, make sure it's facing downward. Give it a change. You can take out the basket also to inspect problems. If you don't see what you any ice cubes in 24 hours then have that service. Or you can do it yourself if you want.
Jul 29, 2008 | GALAXY Microsystems 25.4 cu. ft....
Ice Maker
check the temp inside the frezeer it should be 0 degrees at all times if is higher then that then lower temps and clean condenser coils . if it is zero then repl entire ice maker the thermostat inside ice maker is not closing when it should and in return takes longer to cycle ice.
Jul 03, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Ice maker problem
Take the ice container out of the freezer, there is a metal rod that sticks out behind the ice container, You should be able to move this up and down to open a flap inside front of container to allow whole cubes to get through. In rear of freezer there is a hole that this rod sticks into. You will see a plastic square shaped actuator hanging down. It sould be completely down, and you should be able to move it up and down easily with your finger. If not then it is either frozen or it has failed. If it seems to be hanging about half way down, take a hair dryer and warm it enough that you can move it up and down. Once it is all the way down, reinstall ice container and try for cubed ice again.
Oct 22, 2007 | GALAXY Microsystems 25.4 cu. ft....
Ice maker problem
I also have this problem.  The ice that was hanging, when looking in the freezer was the right side ice.  I just releveled the frig or increased the height of the side that was hanging causing the water to level.  It has cut down on the amount of ice or times the ice hangs.
Sep 17, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
180 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
