Question about Philips Magnavox 51MP392H Rear Projection Television
Closed caption i can't turn get the words off the screen
    Scholar:
  • 33 Answers
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
Just word search the manual for closed caption
if you can find this in your TV options I cut and pasted it from the manual, see the line with Closed caption settings see if yours matches, sorry about the formatting this furm post will not cut and paste properlyeach of the #'s below corosponds to the bold headings.
OptionSetting/Basic2US1/BasicW/Basic+2US2/Core2US3/Basic+2US4
AAVL 1 1 1 1 1 Auto Volume Level via Sound Menu
ACS 0 0 0 1 0 Auto Convergence
AOUT 1 1 1 1 1 Audio Out
APC 1 1 1 1 1 Auto Picture Control
AV3 1 1 1 1 1 Side AV Source
AV5 0 1 1 1 1 (yes this is blank)
BNUM 1 1 1 1 1 Numerics Displayed in Menus
C169 1 1 NA 0 NA Compress 16:9 mode available
CBFL 1 1 1 1 1 Comb Filter Present
CCAP 1 1 1 1 1 Closed Caption
CFMU NA NA 1 1 1 Comb Filter Menu Item
I also found this with the word search but it makes no sense to me sorry...
The HDR2002 has two microprocessors. The Microprocessor, 7001, on the SSB monitors the Keyboard and the Remote sensor during standby. This IC controls the Tuner, Video switching on the SSB, generates the consumer OSD. Pin 5 of 7001 monitors the Keyboard for a voltage change to generate a command. The Front Detect line on Pin 6 monitors the AV inputs on the Side Jack panel. If a problem develops, the Front Detect will go Low, preventing 7001 from receiving any commands. The Power Fail input on Pin 79 goes High if the set looses power while the set is On. Composite Video is fed to Pin 31 for Closed Caption decoding. Horizontal and Vertical sync on Pins 53 and 55 synchronize the OSD and Closed Captions display signals, which are output on Pins 46, 47, and 48. Fast Blanking for the OSD is output on Pin 52 There are three I2C busses on 7001. The Bus on Pins 78, 80, and 97 communicates with the MemoryIC 7012. This IC stores Customer setup information, Option codes, and Error codes. I2C busses, Sand F communicate with the Tuner on the PIP panel, and the ICs on the SSB. The S bus also controlsthe Tuner on the SSM and the Audio and Video switching on the SSM. Data lines on Pins 16 and 17communicate with the Microprocessor on the ACS module.
below is my general post about this TV, I'm not sure if any of its info will help but there are links to other info on this TV set... Good luck
Great reference link that I posted pictures on, check out page 3
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/
Where I got all my parts that worked:
Suburban Electronics http://www.suburban-elect.com/
BTW if you don’t plan on trying this and are going to throw out the TV, I still need a IC convergence board for a 51MP392H/17 TV I'm fixing, I'm willing to pay S/H and buy your IC board that’s not been tampered with. Edwinkraus@hotmail.com
Posted on Nov 20, 2008
2 Suggested Answers
SOURCE: Philips 50" flat screen - Closed captioning won't turn off
on my magnavox it was the verizon fios remote that enabled it by accident (it is tuned to control the tv) however it was a cc button represented by the * on the remote that i had to select to change the cc. this didn't make it go away so i just pressed buttons i used the "Aspect" button represented by the # it changed the ratio and the message went away. I usually only use the fios remote to turn the tv on and off but this must be some whacky override that comes from the fios remote.
Posted on Dec 19, 2009
Text is coming up on screen on all free to air channels. How do I get rid of it? Thank you
Hello, Margaret -
By text on the TV screen, do you mean closed captioning text? Is the text the same wording as what is being heard? If so, that is closed captioning (for the hearing disabled.)
The button for closed captioning on your TV remote was probably pressed inadvertantly. Locate the closed captioning button on the remote, and while the TV is on, press it to see if the text disappears.
Dec 21, 2017 | Televison & Video
One caption frozen on screen
I believe this is associated with closed caption settings. This can be found in your setting menu, most likely under video. In there turn off CC.
Apr 02, 2014 | Samsung Televison & Video
Can't turn off the deaf aid
Enter "setup-mode" on the Shaw PVR, and disable "closed captioning".
Or, enter "setup-mode" on your TV, and disable "closed captioning".
Apr 28, 2012 | shaw.ca
I have a 19'' aoc flat panel,l19w861.after installing a new antenna i tried to reprogram it but all i saw on screen was the words
If no sound and closed captions (writing) appear in the menu look for (it may also be found in the box menu for cable box) captions and either turn it off or select a different choice.
Most sets (not the cable box) will offer captions all the time or only when sound is muted.
Apr 01, 2012 | Televison & Video
We have a Sharp 25J-M100 and we cannot turn off the Closed Caption. We hit menu on our Sharp Remote Control and go down to Closed Caption and make sure it is off. The words never go off of the screen. Our...
If the captions are turned off on your TV, they have to be coming from your cable box. The TV is just displaying what it's getting. Check your cable box menu and make sure captions are turned off there. Cable boxes, especially on digital systems, can prevent the TV's caption decoder from operating properly. So they need to be able to provide captioning, and I suspect you've turned it on somehow. Comcast should be able to tell you how to turn off captions if you can't figure out the menus.
Jul 15, 2011 | Televison & Video
Misspelling on Closed Caption
Yes - perhaps yoga, or a nice massage. You have some seriously uptight members!! It is either a computer error in translating a word from speech, or a human mistyping a word.... but it's all at the broadcast end, you really have no control over it. Try looking up "closed captioning" on Wikipedia.... and relax, the world is not perfect :)
Mar 04, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Close caption writin words display all the time on tv how do i
Go to menu aand look for tv settings. go to closed caption and continue to scroll untill you see off
Nov 26, 2008 | Mintek DTV-263 26 in. LCD Television
RCA Universal Remote Control #451--Closed Captioning Will Not Turn Off
I can't figure out how to turn the cc off either. I went to menu and then audio then captions and off but they still won't go off. The captions are only on when I am watching HD channels. Anyone know why?
Oct 11, 2008 | RCA Universal Remote Control
Tv screen has script words showing
It sounds like you have the closed captioning turned on. Your remote control may have a button marked 'CC'. If so, press the button repeatedly until the words disappear. If you do not have a CC button then you will have to go into the TV's menu, also called setup on some sets, and turn the closed captioning off.
Jan 06, 2008 | Televison & Video
Philips Magnavox 51MP392H Rear Projection Television Logo
157 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
