Question about Fuji FinePix S2 Pro Digital Camera
Fuji Finepix split screen
My Fuji 601 has a permanent green vertical line splitting the screen in two.After a few seconds the right side of the screen goes black.Pictures are saved but show the same symptoms.Performance has been faultless until this problem occurred,do I need a new camera?
    Champion:
  • 217 Answers
If the picture taken from digicam are ok when viewed from a computer, the lcd viewer has a loose connection or defective already, if you can open your unit, try to disconnect and reconnect the lcd flexwire inside.
Posted on Aug 27, 2007
Permanent split screen down middle by black line
The GPU has overheated that is what causing this problem.
You will need to stop the heat build up and get it repaired - you can even do this with a good guide or send it in.
Nov 01, 2009 | Microsoft Xbox 360 Console
Random purple lines flashing across screen
It can be Bad or defective CCD.Please click HERE
The only solution is to get it repaired.
Goodluck..
Feb 26, 2008 | Fuji FinePix S7000 Digital Camera
TI-84 Silver - Screen only works at certain places.
It may be a hardware problem, but there is apossibility that you have activated the Split screen feature.
[MODE] opens a configuration screen. At the bottom, (the last line) has [Full] [Horiz] and [G-T]. Full means screen is complete; Horiz means screen is split down the middle, horizontally in two; G-T mesn screen is split vertically in two; To the lesft is the Graphic screen, to the right is the table of values pertaining to the graph.
[MODE] DownArrow to last line, make sure that [Full] is highlighted.
Hope it helps.
Sep 04, 2009 | Texas Instruments TI-84 Plus Silver...
Purple and green vertical lines on pictures, fujifilm finepix z
Check to see if the Fuji website has any downloads or updates for your camera.
Aug 12, 2009 | Agfa FUJIFILM FINEPIX Z33WP Digital Camera
Fuji F50fd suddenly has only a white screen when turned on. No display at all. It still takes photos, however you cannot see them or see if you are zooming or see any menus, etc. Camera was in a case in...
Either the screen ribbon has moved in it's socket or it has split. Only way to find out is to open the camera. A good light source and a magnifier will show any breaks in the ribbon, could also try a trick with a felt tipped pen to see if the ribbon is split. But before that make sure it's seated correctly
Mar 08, 2009 | Fuji Finepix F50FD Digital Camera
Colours split and vertical bowed green line at to and bottom of s
This is a convergence problem that can be either poor solder connections at the convergence ICs or defective ICs. If you can solder and feel comfortable working inside the set where there are potentially dangerous high voltages, update this and further details and instructions will be provided.
Thanks,
Dan
Dec 12, 2008 | Samsung HLN5065W 50" Rear Projection...
Turns on only for split second!
I was just trying to solve this exact same problem on my girlfriends A345 and upon inspecting the battery door I noticed a small tab had been broken off. I lined up the tab and just above the memory card where it says push to eject there is a slot. In that slot is a tiny black pressure switch that the broken off tab used to depress. I stuffed a small piece of wire in there and hit power and it works just as it did :) hope this solves your problem as I'm sure these tiny tabs break off without people noticing since the battery door closes and locks without them
Oct 28, 2008 | Fuji FinePix A345 Digital Camera
Fuji Finepix S602Z
Since you can see it when taking new pictures but not on old photos then that suggests that the part of the image sensor is faulty. I think this would make it a camera repair shop job as the S602's can't be taken to bits easily.
Jan 06, 2008 | Fuji FinePix S602 Zoom Digital Camera
Screen split into 2 colours - vertical split
I think it is degaussing problem if any thing is lying which has magnet please remove it. &then put of monitor for 15 minutes & then put on again.do not move when it is on. please let me if it gets ok good luck
Sep 09, 2007 | Philips 170B4MG 17" LCD Monitor
Fuji FinePix S2 Pro Digital Camera Logo
120 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
