Turn on and stay on
I have a Smart Plus Series, Phillips Magnavox, When I turn on the television with the power button on the tv the picture has black and white lines then turns off. I push the channel "up" button the tv turns on the about 5 seconds it turns off automatically. I tried pushing the "up" volume the tv turns on then about 5 seconds it turns off automatically. How do I get it to stay on??
  • 153 Answers
It seems that Your TV set may have a problem with its power supply circuit, the problem is intermitent bring it to the repair shop.
Posted on Nov 07, 2008
Can't find install code for philips magnavox smart series plus
Universal remote codes for Philips Magnavox TV are: 0062 0204 0207 0183 0226 0288
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Sep 27, 2012 | Philips Smart Plus TP3285C 32" TV
Manual for phillips magnavox 19 inch smart tv series
As there is no Menu button on the front panel of the TV, you must have its remote control to select inputs.
Jul 07, 2012 | RCA TruFlat 27F520T 27" TV
PTV835 PICTURE SHRINKS
Hello, I dont have a solution but I am experiencing the same problem. Did your tv get fixed ? Any solutions that you can offer ? Rudy
Jan 13, 2010 | Philips Magnavox 9P6034C 60" Rear...
Need codes to unlock the smart block on my phillips magnavox tv
do you have a 3 digit code for RCA TV for the philips universal remote?
Dec 30, 2008 | Televison & Video
TV makes "Pops" and "Crackles" sounds from the back while viewing
remove the cover and observe the source of the light. if its in the picture tube it can be fixed with a picture rejuvonator. if its a cracked solder joint a soldering iron and solder will fix it.
Dec 06, 2008 | Philips Magnavox 42MF521D/37 Television
27 in Magnavox Smart TV
problem in vertical circuit 100uf 35 volt cap also could have poor solder connections on vertical ic
May 02, 2008 | Philips Magnavox 20MS233S 20" TV
Suddenly went off!
This is a power supply issue. Probably in the high voltage stages. Maybe a fuse, regulator IC, or Horiz. Output transistor or all of them. If you don't know anything about TV repair, you should take it to a shop that will provide an estimate to you.
Geno
Mar 04, 2008 | Televison & Video
Black screen no sound
What is the model or chassel number it be a few thing H.O.T Resistor Caps etc..most likely horizontal output transistor.
Nov 12, 2007 | Televison & Video
Televison & Video Logo
244 people viewed this question
Top Televison & Video Experts
