Question about LG 24 in. LDS 5811 Built-in Dishwasher
Lg DISHWASHER INTERMITTENT WATER LEAK
INTERMITTENT WATER LEAK, ONCE/MONTH?. WETS FLOOR IN FRONT. TODAY I WAS ABLE TO SEE A SQUIRT OF WATER BOTTOM LEFT ABOUT 8 INCHES FROM END AND 4 INCHES INWARD BY USING RINSE ONLY CYLE BUT IT ONLY OCCURED ONCE IN 3 TRIES.
  • 1 more comment
  • mission3_16 Apr 24, 2009
    We have the LG model #LDS5811. We bought it from scratch and dent at a Mudges and it kept leaking at each corner of the front (door). Sometimes not at all, sometimes only a dribble and sometimes enough to soak through 3 bath towels! The never figured out the problem and replaced it with another of the same model. Now THIS one's doing the same thing. It only starts leaking near the END of the full cycle and it's always at the front of the dishwasher at both corners. I'm wondering if there's a seal problem between the detergent dispenser and the stainless steel door and maybe the door is filling with water and then slowly leaking down until near the end of the cycle...but that's just a guess...even the "professionals" couldn't figure out the problem the 1st time.
  • jak1227 May 04, 2009
    I have the same problem with my LDS5811, but mine just started leaking from the bottom right - where the door meets the body of the washer. Is there a retrofit for this?
  • Jeff Meyer May 11, 2010
    What did you find your problem was with this intermittent leak?
    Also what is you LG dishwasher's Model number?
I have this same dishwasher,and have had the same problems that have been described in this forum..
LG model#LDS5811.I bought it from Home Depot as a scratch and dent with no warranty available for about $400.00.
The problems I have seen on my own and have read online have been Intermittent leaks on the left side door,as well as both sides.And in some cases,even wiring and motor problems.
In my case,the water was coming from a leaking O-ring behind the evaporator housing in the door,as well as a small hole in the drain hose in the part of the hose on the left side where the hose loops up the side of the machine behind the panel before it comes out of the back.
You will need to take the left side panel off to undo the wire holding the hose in place as well as remove the bottom plate over the motor to gain access to remove the hose from the pump to get the hose off of the machine.Simply replace the hose.You can order online or buy a replacement at an Appliance Repair store as I did.
To repair the door leak,you will need to remove the lower outside panel that is under the control panel.Inside the door,you will need to turn the vent cover at the top of the door counter clock-wise one-forth turn and remove the entire evaporator unit as a whole.You will see a 1.5 inch O-ring.
I repaired this by getting G.E 100% silicone that you can purchase at a Home Repair store like Lowes or Home Depot and sealing around both sides as well as putting a good bead on top of the O-ring itself,and wipe off the excess after re-installing.
I performed these repairs over a month ago,and have had very good success.No leaks to be seen.I am a A\C,Refrigeration Tech by trade,and have done alot of Appliance repair/installation as a side trade from being a maintenance technician at some very large Grocery chains the last 20+ years.
I completely dissassembled this machine and have found it to be a decent product,but some shoddy materials and questionable assembly practices have created these problems,but good sound engineering.
I hope this helps someone with the problems with this machine so it wont be a total loss.
Posted on Mar 15, 2010
I have an LG LDS5811WWDishwasher and it leaks through the lower left part of the door. There is no loose connection and I can't see where the water is coming from. It seems to collect at this door low point. I perceive the unit is generating this moisture accumulation during the drying cycle from steam and that it’s manifesting as a water leak. Please advise what steps can be taken to fix this issue.
Posted on May 06, 2009
I have LG Dishwasher model-LD-2131WH/SH/MH/LH it is telling it is having a water leckage problem!!!!!!!!!!! what sould I do?????????
Posted on Mar 27, 2010
I had the same problem - intermittent leak at door, left side. The solution is to replace the level sensor and/or the inlet valve. This intermittent electrical malfunction allows to much water to enter the diswasher and spill out. I changed these parts once, it solved the problem and 8 months later the problem has returned.
Posted on May 01, 2010
I have a LG LDF7810ST and has been trouble since we bought it two years ago,.Does not clean well plus it ALWAYS leaks from both sides of the front door. We used to keep a couple of towels underneath but yesterday we had gallons of water all over our floor. Had a guy come over and he says its the door seal. I have a feeling this will not fix the problem and if I ruin my wood floors I will scream? Can anyone hlp? Thanks
Posted on Nov 24, 2009
  • mygirls359 Dec 07, 2009
    Here is the serial number 00176
    Seems like I got one of the first of these horrible machines.
  • sherrymiller Sep 23, 2010
    Did the door seal fix the problem? I have this problem to with the same model as yours. I hope that the F132 gasket (door) part #3920DD3005A will work.
    New Friend:
I had the same problem during the same cylce where it was leaking out the right bottom corner of the door (as you face it). Took the door apart and noticed the seal was warped fairly well. I figured it was bad so I started to pull it out with a pair of pliers and noticed it strectched out to perfect form. I stopped pulling and cut about 3/4 of an inch off the length of the seal. It worked! I think they are putting seals in that are too long and then they bunch up over time as they heat up causing ripples and gaps in them. Good luck, I hope mine holds up as well.
Posted on Nov 27, 2012
I have LDS5811 which leaks from both corners under the front door. Only during wash cycle, few seconds, but at high pressure pushing out around a cup of water. I replaced the whole front door, which excludes issues with O-ring, Vent Kit, bottom gasket (still leaks around it on the corners). Still the same. Never touch programming since bought in 2005. I am out of ideas now.
Posted on Mar 29, 2010
This problem occurs when the water level high when it starts both rinse or wash cycle. it blows the water through the bottom gasket and you can see the water outside of the gasket. it immediately disappears when the water gets into sprays. the problem is the bottom door gasket which can not be replaced (i believe) or faulty programming.
Posted on Nov 01, 2009
  • 423 Answers
Hi mission,
Try this: Take a close look at where the leak comes from. Watch it with a flashlight and see if the water is coming from a slot in the door panel (probably on the left) or is it coming out farther in.
Also, post the serial number back here, we can see if the little-known retrofit can be applied to possibly help this problem.
OK?
Posted on Apr 27, 2009
Intermittent leaking during wash cycle
is the dishwasher leaning foward,are you useing to much soap?start the dw with out anything in it let it run a few minutes open the door and see if there are suds in it if so way to much detergant
May 31, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
Door leak on built in LG dishwasher.
Check and make sure the unit is level front to back and side to side.
Check all 3 spray arms for plugged or restricted holes that may be diverting water in the wrong direction..
Jan 05, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Our Fisher & Paykel single dish drawer unit (6 months old) is leaking limited water from its base down the front of bottom drawer below the unit's base onto the kitchen floor. One inspection by a...
One drawer leaks can cause this problem. If you don't fix it. One day it will turn on the pumps from both units without any one touching them since the floor sensor at the bottom housing detects water and it will run for ever until you unplug the power cord. This dishwasher is a state of art in design and replacing parts is very simple once a person has enough understanding of its mechanism. If the tech fail to find the problem then he is not qualified to touch this dishwasher. When there is a leak, it is a problem with the lid seal from the top not closing down tightly so during the wash cycle, water shoot up and leaks through the top opening then collecting on the bottom housing of each unit. Let say the top draw is leak, so the bottom housing of top draw if full of water then it overflows to the bottom drawer unit then the floor. Here is the idea of how it happens. The top lid is pulled down by 2 actuators from both sides at first start. That is why you can hear the motor noise turning on at the beginning of the wash cycle. That is the noise from the actuators. If the actuators are bad. only one side works then the lid can not be sealed properly there is a leak. If bothe of actuators are week the gear worn out so they can not hold the lid down during the wash cycle then it can cause a leak. You can pull each tube out and access from the left side at the bottom to touch the bottom housing to fell the wetness. Put in tower to dry them out. If there is a weteness from the bottom housing upper tube it doesn't mean the bottom drawers is leaking. It is wet just because the top is leaking. However you have to dry the bottom in order to continue use the bottom dryer. If you ignore my advice then your circuit board at the bottom housing of lower drawer will be damaged and it is not cheap. With the information that I provided you can interview a tech claiming know about the this type of dishwasher before letting him coming into your house. Good luck.
Dec 28, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Leaks when being unloaded
I may not have the full solution here, but to avoid (expensive) sub-floor damage, I recommend you do the following.  Assuming that the water is not coming from some dripping between the opened door at the hinge....
-Remove the kick plate that is in the bottom, front of the dishwasher.
Use a flashlight to look for wet flooring.  Run the dishwasher with the kick plate removed, watching for leaks/dripping.  It is possible for a leak to seep under the floor.  If leaking is found, do not ignore it.  Pull the dishwasher, fix the leak or replace the dishwasher.  Remove the first layer of sub-floor under the dishwasher, looking for deeper damage.
You should probably do the same with the carpeted area.  Pull the carpet back and decide if the sub-floor needs to be replaced.  A flooring expert should probably inspect.
Sorry to be such an alarmist, but I have been around floor damage that was unnoticed and ignored.
Apr 14, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
LG dishwasher is dripping water from vent onto floor
Good that it is working. Recommend you keep a lose eye on the vent on the bottom of the door panel. This model will probably begin leaking again if it has not been retrofit with a kit that LG developed.
Please open a new problem when it starts to leak and please provide the Model and serial number when you do. Good Luck!
Mar 24, 2009 | LG LDF6810ST Stainless Steel Built-in...
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Dec 07, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
Water will not drain out of the tub all the way and behind the front door bottom in the insulation seems to be wet. and the cycle seems to take a long time to run...thanks
My dishwasher, Bosch Model No. SHU9922UC/U12, Serial No. 10 0202 80447 01 0040 goes through its wash, rinse and dry cycles but sometimes there is some water remaining on the items in the upper tray and one inch or so of water remaining in the bottom of the tub. Once water leaked out onto my kitchen floor. I found some broken glass and some plastic in the circular trap at the bottom and have removed the detritus.
Jul 29, 2008 | Dishwashers
Leaking dishwasher
what sort of soap powder do you use
some soap powders foam a lot in machine causing dishwasher to leak through seals
also check that the machine is square that is the door is closing parallel with cabinet
do not use power balls in machine just standard dishwasher detergent and separate rinse aid
Feb 02, 2008 | Dishwashers
Water leaking from bottom of washer
you need to fill it up a little then switch it off. tilt it backwards and if it hasnt got a base you should be able to see where the water is coming out of. check the bottom hose and around the element location.
Jun 23, 2007 | LG WM-2277HW Front Load Washer
Dishwasher leaks
If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is sudsing too much. Cut back on the amount of detergent you use and see if that makes a difference. Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. Also make sure the dishwasher is sitting level (you can adjust the front feet up or down and many units have some type of levelers at the rear). Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson. An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Jan 18, 2006 | Hoover 24 in. DT999 Free-Standing...
LG 24 in. LDS 5811 Built-in Dishwasher Logo
4,569 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
