Need help setting the time on my Tag Heuer Formula 1 watch. I need to change the hour for daylight savings time and don't know how.
Tags have a screw down crown (winder knob) turn the knob counter clock-wise until you feel the crown unscrew (not off) then pull the crown carfully. It will pop once this is for date adjust. Then pull once more and you can now adjust the hands, set accordingly then push crown back in. After you push it back in gently compress the crown and tighten clockwise until it stops. CAUTION!!!!!!! Tags are not waterproof if the crown is not screwed back down. I hope this helps I am actually a car guy (just happen to own a couple)
Thanks, you're a genius!
had the same problem followed the directions given by Brian032472 worked like a charm
How do I reset my watch?
I am unable to change to daylight saving time
