Question about Sanyo LAMP Projector Lamp FOR PLC-SW30/SW35 PROJECTORS
Poor picture The left hand side and lower edge of the projected picture has a bluish appearance superimposed. This fades towards the middle and right hand side and top where the picture is good. Has a filter or prism moved inside? I need to know what can be dismantled safely if it can be put right. I am an expert mechanical engineer but would like some advice before delving in. As I have not had this apart yet I do not know from the specification whether it has one or three Liquid Crystal Display panels inside.
4 Suggested Answers
SOURCE: Color Bleeding
The problem is most likely caused by a defective LCD panel. I am fixing this exact unit for a customer, tried cleaning the optics / LCD panels, made no difference. Panels aren't available individually, only as an assembly w/ the prism block. Sit down for this; DEALER COST $3148.59 !!!!!!!!!!!!!!
Posted on Dec 03, 2008
jerryg50
  • 1689 Answers
SOURCE: cracked screen
The screen in your TV is not easy to change. The cost of the screen alone will be very close to the purchase price of a new set.
Jerry G.
Posted on Apr 05, 2009
gopakumarg43
  • 76016 Answers
SOURCE: I have a Sanyo DP55D44 television and the right half of the screen is darker than the left half. Any ideas what part might need replacing?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Oct 31, 2016
Testimonial: "Thank you for your information. I was however hoping for someone with knowledge of the specific model that might shed some light on possible parts that could be an issue."
Green line 2inch appeared on left hand edge next
look like you panel fail,
but you can get 2nd opinon
Jan 08, 2010 | Televison & Video
Bluish color right coener
I'm afraid, it is problem of optics unit block (light engine), there are 3 LCDs red-green-blue for color picture formation and blue LCD sounds bad, please call local TV tech for fix.
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Bowed picture and color misalignment
Replace both STKS ICs Ck low ohm resistors 2.7ohms most of the time there will be 2 of them bad.
Jun 11, 2009 | Samsung HCN5527W 55" Rear Projection...
LG rear projection colours out of alignment
I have a similar problem with an LG (except my red is the one that is fine) and was able to talk to a tech in some detail about it. The tech prefaced by saying that he had done a hundred or so of these with exactly the same issue. This is very common and the life span of rear projection televisions is not great. Having said that, plasmas and LCDs are also limited in life span mostly due to modern high performance gaming machines which shorten the lifespan of monitors both plasma and LCD alike.
From what I have gathered, this is not a problem that you can easliy sort out. (Of course they would say that though) It involves replacing the digital board which means soldering followed by aligning the lamps which requires quote a lot of expertise.
The part itself apparently costs around $200 Australian and the labour will vary for the cost of the technician but I was quoted that the labour was about the same cost as the part.
Not sure if I would call this solved but I hope it has been at least a little helpful.
May 26, 2009 | JVC AV-56P575 56" Rear Projection...
Bluish tint that starts in lower left corner and goes across scre
i have blueish on right lower corner of screen.... what causes this
Mar 05, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
PICTURE PROBLEM
Convergence failure - goto www.tvrepairkits.com to get the parts and instructions to fix it yourself.
Oct 18, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Color separation
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 03, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Sony kp-65wv600 blue arch line on left side
in the menu does it have a convergence menu? try doing that.
Feb 20, 2008 | Sony KP-57WS500 57" Rear Projection...
Bowing in the middle like an hour glass
OUCH!!!! Don't kick me...would be my response if I were your TV
Convergence amps problem.
If it works after a kick I'd say poor solder joints on the convergence amp leads
Dec 17, 2006 | Zenith IQB50M90W 50" Rear Projection...
26 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Rod Donovan
Rod Donovan
Level 1 Expert
k24674
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
