Question about Singer CE-100 Futura Computerized Sewing Machine
Thread HI I have a ce-100. I have replaced the bobbin case. I have cleaned and oiled.I have thread from the bobbin coming up and collecting under the fabric and then jamming. Any help would be apreciated . I thought I had it fixed but of course.. its not and the fabric starts to pucker and then I have to cut thread underneath to disconnect. Please help. Thanks
  • 323 Answers
You need to do a tension assembly test.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}Tension assembly test. To do this test. Pull the threadthrough the tension assembly and test it to make sure the tension is workingcorrectly.
(To do this test, adjust your tension setting to normal or medium or 5 orsomething in the middle. Raise the presser foot and pull the thread through thetension. It should pull easily!! Lower the presser foot and pull the thread. Itshould pull noticeably harder.)
If it doesn’t work this way then you probably have a pieceof thread or lint stuck inside the tension discs. To remove it, turn thetension to 0 zero and raise the presser foot.Using a small screwdriver, openthe space between the discs and spray with canned or compressed air. The stuffshould come out. Do the tension test again to make sure you got everything andthen try sewing again.
sewman7
Posted on Nov 07, 2008
My bobbin thread continues to bunch up on the back of the fabric.. How can I fix this?
Is it really the bobbin thread that is globbing? Check closely. Usually it is the upper thread accumulating under the fabric.
If it is in fact the bobbin thread, then the bobbin case is not threaded correctly, the bobbin case tension needs adjustment, or it is broken and needs replacement. There are web sites and YouTube videos that show how to adjust the bobbin case tension.
QUICK FIXES: Remove all the thread from the machine. Clean the area around the feed dogs and bobbin area. Oil as instructed in the owner's manual using ONLY fresh, good quality sewing machine oil (only 1-2 drops each spot). Install a brand new needle insuring it is installed correctly. Avoid using fuzzy, old, or bargain bin thread. Rethread: Be sure you raise the presser foot BEFORE threading the upper thread so it will seat properly in the tension disk--and check to make sure you are threading the machine correctly. Check that the upper tension is set properly (the factory standard is usually the halfway point between the high & low number on the selection). Test on a scrap of the fabric you wish to sew. Adjust the upper tension--either tighten to pull the upper thread toward the top of the fabric, or loosen to pull more upper thread down.
Here are some web sites that may help.
Sewing Machine Thread Bunching Up Here Why
sewing machine birdnesting
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
8 Tips to Fix Birdnesting in Embroidery
Birds nest under the fabric big loops of thread top side looks good...
3 Common Sewing Machine Problems and How to Fix Them
Dec 29, 2015 | Sewing Machines
I am just making a regular straight stitch and the thread on the back of the fabric is looping ALOT! what am I doing wrong
change the needle
make sure the bobbin is inserted correctly into the bobbin case
make sure the top thread has not come off the thread take up lever
also try adjusting the top thread tension
Sep 01, 2012 | Singer CE-100 Futura Computerized Sewing...
I have a Singer CE-100 and I would like to know why it keeps beeping and stopping?
There are a few problems this could be. Your top thread could be broken or about to break; your bobbin thread could be broken, about to break or empty/about to become empty and is loose around the bobbin; you could have a birds' nest (a mass of thread just under the fabric/presser foot and/or within the feed dog and bobbin) forming and causing a jam; or it could be your Futura having a little bit of a hissy fit. Obviously, if you've checked for broken thread you need to move on. Check for a birds' nest by removing the fabric and clip your threads. If you find one, clear it, rethread your bobbin and begin sewing again. If there's no birds' nest, then place the fabric back in and try sewing/embroidering again. If the machine acts up again, I recommend removing the fabric/hoop, rethreading your top and bobbin threads, replacing fabric/hoop and resuming where you left off. If the machine still gives you trouble, try hitting the start button for a couple of times and seeing if the problem doesn't simply resolve itself. When you're embroidering areas that have a few small, short stitches only, the machine seems to act up a little and then behaves fine once you bypass the area. Be sure to take all of the other steps first, though, because a birds' nest will RUIN a beautiful seam or embroidery.
Nov 11, 2010 | Singer CE-100 Futura Computerized Sewing...
Thread is balling up and not allowing the fabric to move it isn't stitching right
This can be caused by several different things. Check the threading. Un-thread the machine and follow the guidance on the manual and re-thread the machine. The bobbin, if the bobbin thread that coming out of the bobbin case in a wrong direction, could cause this. Re-set the direction. When you pull thread from the bobbin case, bobbin should roll counter clockwise. The needle, if it is not the right size needle for the fabric or the needle is slightly bent, maybe replace the needle and try with different size of needle. Once its balling up, sometimes it's left some thread in the machine under the needle plate around the feed dog, clean them up. Thread tension, different fabric may need to be adjust the thread tension, try to check this one under the manuals/instruction. When ready, check and use a scrap of fabric/remnants!
Aug 02, 2010 | Riccar Sewing Machines
I have the futura ce-100. When embroidering it
This annoys the heck out of me, cause it happens a lot more than it should. There can be some valid reasons as to why it happens, though.
Mar 22, 2010 | Singer CE-100 Futura Computerized Sewing...
The bobbin thread shows
I am having the same problem and can't seem to find the answer. Please email me if you have found a solution!
Debr535@yahoo.com
Sep 30, 2009 | Singer CE-200 Quantum Futura Computerized...
Bobbin case is popping out, and machine is birdnesting
Usually when this happens the bobbin is in wrong, replace it make sure the thread is going out the right way, make sure there is no lint or small pieces of thread around or underneath the bobbin area. Make sure you thread it with the foot up. Also make sure you are usng the right bobbin for the machine. They can easy get mxed up.
Jun 16, 2009 | Singer CE-100 Futura Computerized Sewing...
Futura ce-100(Singer)
Sounds like a tension problem. Email the singer company at talktous@singerco.com They should be able to help!
They responded back to me the same day.
Nov 17, 2008 | Singer CE-100 Futura Computerized Sewing...
Problem with bobbin case - new machine Singer CE 100
My problem is solved (I think...that is a knock on wood kind of thing). Upon recommendation from another Futura user, I remove and clean my bobbin case and I put a drop of oil in the little hole under my bobbin case about every 5th or 6th monogram use. AND, I pitched all of my bobbins that were 15 and not 15J (I had some that were 15 and they were the culprit as well.) I have had no more problem. It seemed the least bit of lint caused me a lot of birdnesting. I also stopped using rayon thread and use only polyester and bobbin fill in the bobbin. I have got to say I am thoroughly enjoying my machine these days. Please try these things before giving up on this so user friendly machine.
Nov 22, 2007 | Singer CE-100 Futura Computerized Sewing...
Tangled bobbin thread
Okay. I had this problem too. try taking the bobbin casing out. I had a bit of thread lintg caught in a remote area of the under-plate area. Blow it out with canned air and oil your machine. That should help. It fixed mine.
Jan 16, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer CE-100 Futura Computerized Sewing Machine Logo
99 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
