Question about JVC AV-56P777 Television
Won't power on
I push the power button, there is a clicking sound and the power remains off.
  • JVC Master
  • 19,396 Answers
The clicking sound is a protection switch that keeps turning off your TV because an internal error had been detected.
Try unplugging tv power cord for a couple of hours.
If this does not work , that means that there is a faulty component, in this case the TV should be inspected by a technician.
You can call support by using the phone number listed onthe TV user manual.
Posted on Nov 06, 2008
I have a Minolta CSPro 3050.. legal paper drawer won't close..and it won't copy
To the rear cover located one hole before waste toner box.Introduction one long screwdriver and push the unlock button.
Jan 18, 2013 | Konica Minolta Copier Toner EP6001 CS Pro...
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
Dec 20, 2012 | Fisher and Paykel Washing Machines
Dryer buzzes but won't start
see the diagram :
1) O.k if the thermostat 2) Thermofuse is o.k is good resultant BUT please 3) Test the door switch for open or defective , if the remain open the motor will NOT START. see the diagram. 4) After changing the switch if the problem remain the same the motor is faulty( centrifugal swithc, etc) need repair or replace. 5) Test the push button start for diryt or open, test the wires for loose, broke, or burn wires too.
God bless you
Jun 09, 2012 | Whirlpool LER4634J Electric Dryer
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
1996 nissan pathfinder driver side window won't go up and down
does it click or grind when pushing window button if so the window lift track may need replaced, if there are no sounds then disconnect the wires from the lift motor and with the ignition on so power is sent to switch, push button and check wires to 12 volts dc. If no power I would replace the driver side switch after checking the wires for defects. If there is power then I would re-install wires to motor after turning off key and try button again with power on. replace motor if it doesn't work.
Dec 31, 2011 | 1996 Nissan Pathfinder
Device could not start
what device? is *********** board won't start? Or a hardware doesn't start like ram or your printer
If the problem is your motherboard check all your hardwares and connectors like this:
  1. If the motherboard won't start if you click the power button check the LED(the small light bulb on your motherboard) if its glowing. If not, check the connector of your power supply or check the power supply if its working by looking its fan if revolving.
  2. If you push the button and there's a sign of power but didn't start up that will appear on your screen check the connection of your monitor screen to your desktop computer. If it's connected, remove your RAM from the motherboard and insert it to another memory slot to check if it's broken.
  3. Last, if you push the power button and here 1 short beep but the boot screen didn't appeared from your screen check your graphic card. Remove the graphic card and re-insert it again to its graphic card slot and plug in your monitor connector to it. If it still remain that way, buy a new graphic card.
Aug 01, 2011 | Computers & Internet
After shutting down my HP LAPTOP, it won't restart. If you push the "on" button, there's no response. I noticed that about 3 days before this happened, the system cannot...
- try to remove the battery of the laptop and unplug the power cord
- hold the power button for 20 seconds to drain the remaining power
- turn on the system
Jul 09, 2011 | Computers & Internet
JVC AV-56P777 Television Logo
157 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
