Question about Brother MFC 210C All-In-One InkJet Printer
How to receive fax
I do not know how to receive a fax. In fact I just started faxing period. The manual just shows how to set up the ringer, transmission and etc. I had someone fax me something and I didn't get it, but the report stated that it came and it was ok. The person told me to look in the memory and of course the manual said a different printer had that feature but not the MFC 210c. I went to the store where I purchased the printer and I was instructed to unplug for 15 minutes in order for the printer to reboot and again nothing happened. HELP !!!!!!!
  • 3 Answers
Check to see if your faxes are not going to a recieved file on your computer and are bein stored instead of printed.
Posted on Nov 11, 2008
My mfc fax machine will not ring and will not receive faxes. I can send them out though
It's probably set to manual receive and the ringer volume is low or off.
Nov 20, 2010 | Brother IntelliFax-4100e Fax
I have a panasonic fax machine. It will receive
if this is to every line then you have a bad main board or your ringer waiting period needs to be increased... (meaning the amount of times it rings before pickup...
Dec 10, 2009 | Brother IntelliFAX 4100 Laser Fax
The Fax machine just gives me a problem on the screen (Ringer off), I don't know what is mean that, please Is it possible to recommend what I do.
It means that your fax will not ring when it receives the fax, but it will receive just fine.If you use this machine as fax only,don't worry about this message,but if you use it as a phone as well and you want it to ring,you will need to go to "menu" and turn the ringer "on"
Oct 04, 2009 | Canon LaserClass 2060P Plain Paper Fax
How to set machine to receive incoming fax?
Quoted from the manual: The HP all-in-one will not automatically answer calls. You must receive all faxes manually by pressing Start Fax Black or Start Fax Color. For information on receiving faxes manually, see Receive a fax manually. You might use this setting if the majority of calls on this phone line are voice calls and you rarely receive faxes.
This page has more information: http://www.fixya.com/support/p378554-hp_officejet_6210_all_in_one_inkjet/manual-3600/page-86
May 23, 2009 | HP OfficeJet 6210 All-In-One InkJet...
We cannot receive incoming faxes without first picking up the phone and then hitting the start button - how do we get the fax machine to work automatically.
Should be in the operators manual. You need to change the setting, through the control panel, to "autoanswer". You can print out the current settings by pressing the "menu" button, scrolling to "user settings" and print from there. You can also select the number of rings before the machine picks up, and the volume of the ringer.
Dan
Jan 07, 2009 | Brother IntelliFAX 4100 Laser Fax
Panasonic KXFHD331 something simple the ringer volume was adjusted and somehow it got messed up and now wont receive I dont know what to change
ringer volume can bi adjusted with volume key or with navigator kex by pressing up and down.if fax is not receiving just check fax receive mode .put iton fax only mode.by mian jee
Dec 02, 2008 | Office Equipment & Supplies
Incoming Phone Ringer
After months of trying to solve this problem I finally figured out that the machine was set to phone/fax mode instead of fax only. If you have a dedicated fax line you can set to FAX ONLY MODE. In FAX ONLY MODE you can control whether or not the machine rings when it receives a fax call. You do this by selecting Data Registration, Press Set and use the up and down arrows to select 4. RX Settings. Press Set and use the up and down arrows to display the item you want to set or change and turn the ringer OFF. Press Set.
Mar 26, 2008 | Canon LaserClass 2050 Plain Paper Fax
How to set Ans/Fax receiving mode of SCX-4521F?
Try setting the receive mode to FAX/ANS. If you want the fax not to pickup before a phone call comes in, you should set the number of fax rings to a higher number, like "5" for instance. Set the answering machine rings less and the fax higher. The machine will usually record a message first and then detect a fax tone.
Jan 24, 2008 | Samsung SCX 4521F All-In-One Laser Printer
How to set ringtone when receiving fax Canon Fax L800
RINGER IS SET TO SILENT MODE,PLEASE CHANGE IT HAPPY FAXING OMNIPRESENT
Sep 19, 2007 | Canon FAX-L800 Plain Paper Laser
Unreceivable
Manual can be found here: http://www.samsung.com/support/productsupport/download/FileView.aspx?cttfileid=526982&type=Multi+Function+Printer&typecode=16&subtype=Laser+MFP&subtypecode=&cmssubtypecode=1601&model=SF-5100I&filetype=UM&language= Does the unit ring at all? If it does do the following (taken from the manual) Receiving automatically in FAX mode 1. Press Rcv.Mode/Contrast until the display shows ?FAX MODE?. 2. When you get a call, the machine answers the call on a specified number of rings and receives a fax automatically. You can change the number of rings. See ?RINGS TO ANSWER? on page 5.4. To adjust the ringer volume, see ?Adjusting volume? on page 2.8. If the phone is not ringing, then the call is never even getting to your fax machine. Hope this helps If you need more information, please ask before rating this solution. Ed
Jun 09, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Brother MFC 210C All-In-One InkJet Printer Logo
88 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
