HV CABLES I was replacing the convergence IC chips on my 60in hitachi rear projection tv so i disconected the HV cables. When I put them back in and turned on the TV there was and electrical charge snapping and popping all around the unit the HV cables plug into. How do I fix this?
  • 19,396 Answers
That means that there is a bad short somewhere.
You did something wrong when you replaced the STKs
Posted on Nov 14, 2008
  • Ginko
    Ginko Nov 14, 2008
    Check the convergence ICs that you just replaced, see if they had blown again by testing the picofuses on the convergence board.
    check for burned areas on the TV boards, if you do not find anything wrong it may be a faulty power board, that was probably also the reason for the convergence ICs blowing out.
    Try also leaving the TV unplugged four or five hours, to check if the problem is with electrostatic charges accumulated inside the TV and then discharged via signal board (the one that connects to cables).
Hitachi 46f500 46 in problem double picture end two collor
This is symptom of convergence output chips failure in rear projection tv, replacement of convergence output chips will fix the problem.
Chips/ IC replacement requires soldering work in circuit board, if you are not familiar with electronics stuff fixing an soldering work, call local tv repairman to help you.
Thanks.
Oct 26, 2010 | Hitachi 46F500 46" Rear Projection...
I purchased a tv repair kit and replaced the convergence ic chips to fix my convergence problem. put everything back together and now, no picture. I tried magic focus and it works great, the colors are...
As per statement, "the magic focus works great, the colors are bright and aligned" it means the tubes are working ..you need feed a signal to see the picture...the tv video goes muted without signal
Dec 29, 2009 | Hitachi 60SDX88B 60" Rear Projection...
Hitachi 50ux26b projection TV, the color lines separated...
It sounds like a convergence problem; either bad solder connections at one of the convergence Ic chips or a bad Ic. if this was helpful give me a vote----if one of the chips is now bad it will have to be replaced(usual thing is to replace all the convergence ic chips---most use two and a few 3.
Aug 12, 2009 | Televison & Video
Hitachi 43UWX10B 43" Power Light flashes Continuously
I doubt if its the fuse. We just helped a customer with a very similiar problem. Its more likely that the convergence IC have failed and shorted out. When this happens one of the symproms is that the TV will shut down and chirp. Goto www.TvRepairKits.com and click the contact us button. They can provide you with more instructions on how to test if this is the problem.
Ed
Jun 16, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Can I replace a 110 Convergence IC with a 150?
The 110s have a high failure Rate of getting to hot and pinns fall off use 180s.also replace the 7 low ohm resistors.
May 05, 2009 | Hitachi 51SWX20B 51" Rear Projection...
Hitachi 43FDX Rear Projection TV
If the picture was good prior to the 3D images, I would fix it. The convergence ICs either have poor connections or are defective. The IC is an STK392-110. There may be 2 inside the set. If you have this repaired, expect a labor cost in the $200 range. Request that the ICs be replaced rather than the board changed. This will maintain all of the internal settings and require only part replacement not a complete re-convergence adjustment.
Keep us posted.
Dan
May 01, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi Television
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Feb 18, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 51G500A Convergence Problem
Hi, 110`s & 150`s are both replaced by stk 392-120`s. which run waaay cooler because the 120``s are rated at 4 amps while the 110`s and 150`s are 3 amp devices , the real key is to make absolutely certain you are not buying generics (which are everywhere on the internet), there should
be NO black print on the back side and a 4 digit code (not 5) on the front, top right corner, the originals or OEM`s are never $8.99, usually run about $12-15 and are made by Sanyo but the word sanyo will NOT be on the IC`s , so go by the info above, be sure to check for burnt resistors next to the heatsinks as well, good luck, video-tek
Feb 03, 2009 | Hitachi 51G500 51" Rear Projection...
43UWX10B problem with green
if you have a 2 IC convergence chassis they dont control the green , However if you have the 3 IC chassis the green is controlleed by the third IC these are usually STK4275 or simallar single amp ICs. Which type chassis does your hitachi have? Its possibly related to the digital convergence board if all resistor near the ICs are good. Do you have the service manual? I can post a link where you can get the full service manual if you need one
Mar 29, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Convergance/coaxial cables
Check any / all soldered in micro fuses...F851,F852,etc.
Note:read my Powered Products>View all>Toshiba>convergence issues .........? What quality IC's did you use and what price did
you pay ?............................T.
Mar 12, 2008 | Toshiba 50HX81 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
