Question about Samsung 15.3" LCD Monitor
Monitor color dominated by blue; Green and red colors fade away as yellow and black
I have Samsung 56V 17' CRT Monitor which is dominated by blue color and all objects in red and green are in turn displayed as yellow and black. However sometimes in between the display is automatically corrected but for a brief period...and the faulty display continues. Can anyone help? Is it a problem with monitor or the pins in thecord i connect to CPU? Should i take my monitor for a repair?
  • goodpeople Feb 22, 2008
    I cleaned my monitor with a glass cleaner that read "safe for computer monitors", but now my monitor looks like a rainbow. Can this be fixed or is my monitor ruined? Help!
  • manojmanoj13 Feb 15, 2012
    Even i hav the same problem with my PHILIPS 107E5 CRT monitor..
The monitor probably changes its color due to loose connection in one of the wires leading to the RED color gun of the CRT. Simply put the monitor downwards and tap at the back. Repeat once or twice if the problem persists.
I hope this helps
ProfSweetlin
Posted on Sep 24, 2008
  • 624 Answers
As the guest posting stated it could possibly be a problem with the VGA cord but it could also be several other things as well. For the purposes of troubleshooting I would NOT go off and buy a new cable just to test it. Chances are pretty good you?ll just be wasting $15 for a cable you?ll never use. -Remove the monitor cable from both the monitor (if it comes off) and the PC. Inspect the ends and look for bent or corroded pins. If you find any let us know and I?ll go over how to straighten or clean. -The next step would be to swap monitors with another PC and see if the problem follows it. Again if your VGA cable is attached to your CRT via a connector you can swap that with a borrowed on to see if that is the cause. -If the problem stays with the monitor then you will probably wind up spending more money trying to repair it that its worth.
Posted on Jul 29, 2007
Probly just the chord connectin from your pc to the screen. just buy a new chord.
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
My E771 monitor colors suddenly shifted with
Possibilities:
1. video-card gone bad;
2. video-cable gone bad;
3. video-cable not tightly-connected to CRT;
4. video-cable not tightly-connected to video-card;
5. "red" gun inside CRT gone bad.
Disconnect the video-cable from the computer, and try again to adjust the "red". If red-free, then it's time to responsibly recycle the CRT.
Reconnect & wiggle the video-cable, to see if that induces any "red" onto the CRT.
Connect the CRT to the VGA-output port on a notebook computer, to see if that video-card generates "red" as one of the primary colours.
Give the CRT a strong "whack" on the side, to see if "red" makes an appearance.
May 07, 2010 | ViewSonic E771 17" CRT Monitor
Apple M6494 CRT monitor. No color
1.Check the Signal cable.
2. Check the Green Drive Driver / output transistor.If they are used driver IC in stead of Transistor, check all supply voltage (56V to 85V)..
Sep 19, 2009 | Computers & Internet
VGA connector wiring detail
Pink - red input - pin 1 green - green input - pin 2 blue - blue input - pin 3 ground shield wire - pin 6,7,8 and 10 black - ddc 5v - pin 9 violet - screen raster - pin 11 white - data or sda - pin 12 orange - clock or scl - pin 15 yellow - vertical signal - pin 14 clear - horizontal signal - pin 13
Sep 11, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Dear Sir, My monitor is SAMSUNG 753DFX (17" White), my monitor green color problem (green color loss),pl. help me and give me solution. I am electronics familier. Thanking You, Arif
try to use windows color management scheme under properties of your graphic card setting. you can manually override the green red blue and gamma settings. In this way may be availing of desired result is possible.
Either way if you're familier with electronics, repair including possibility of shock hazard costs you more than the price of a new flat monitor.
Sep 07, 2009 | Samsung SyncMaster 753 DFX 17" CRT Monitor
I too have d same problem..
unscrew the monitor plugs and re seat, often these plugs come loose and the pins fail to make contact reseating them usually solves the color bvleed. other than that you are using the wrong driver
Jun 20, 2009 | SAMTRON 55V 15" CRT Monitor
No yellow or blue color displaying
In a monitor like crt type. there are three colors amplifier. Red, Green and Blue. I think the Blue color amplifier is defective. Try check the biasing and also the transistor.
Feb 02, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Light blue color
look for cold solder joints on the crt neck (color circuit) board!
Nov 02, 2007 | CTX PL7 (Black) 17 in.CRT Conventional...
15 pin VGA connector damaged.
i want to know that what is the color combination of vaga cable connector
Aug 28, 2006 | SAMTRON 55V 15" CRT Monitor
Computers & Internet Logo
234 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
