Question about Acer PH110 Multimedia Projector
Not recognizing any source
Hi. My PH110 stopped to work: the vpr starts, the bulb lights on, the startup screen appears, but no input source is recognized. The vpr accepts menu commands, shows the OSD menu and messages. I tried to connect a video cable, as well as a VGA one, but it does not recognize them. The USB port seems to work, but no reset or firmware-update procedure is mentioned in the user's manual,  Any hint ? Thanks in advance.
    Problem Solver:
  • 4 Answers
Hi, i hope this works for you, all you need to do is press the source button this makes the projector search for active inputs.
Posted on Nov 26, 2011
How do I use the video source button? I can see the different video inputs I can select on the screen after hitting the button but I can't move the cursor to select a different video source an
On Most TVs I have messed with, Hit the input or source button muliple times to cycle throught the different inputs. Also make sure there is an active device on the input for the TV to recognize it. Good luck
Jan 03, 2015 | Televison & Video
What does hdmi is blocked mean
Hello!
HDMI blocked could mean, that one or more HDMI inputs are turned off. In WD- series DLP TVs it's possible to disable one or more inputs, which are not to be in use, to speed up signal source switching. Most of modern sets are constantly monitoring inputs and automatically recognizing "plug"n"play" signals. blocking any input would not cause TV to shut down.
Yellow(amber) light means: lamp door interlock switch is off or malfunction. green blinking: set is initializing, about to begin normal operation. So: quite possible that lamp has been replaced incorrectly or door is not tight intermittently. Last possible issue: door's interlock switch is bad. Take lamp door off and you will find the switch with blue lever on the left side of the door inside plastic compartment. Push it with your "pinky" or pencil carefully, then ask someone to turn set on. Make sure, yellow light is off, before do so. If set starts normally, observe lamp's activity: it should stay on and getting brighter, while you holding switch. If lamp stops working, while there is no "amber" light, then TV shuts off, red blinks, lamp is bad. I just had to replace lamp twice, due to defective batch of lamps with housing. 3rd time I replaced bare bulb and it solved the problem. But there was no "amber" issue!
good luck,
Alex.
Mar 06, 2012 | Mitsubishi WD Televison & Video
Changed lamp and now turns on and only stays on for about 5 minutes and red lamp light stays on in an acer ph110 projector
Hi, what you need to do is reset the lamp hours to get the red light to go if it is a new lamp. To do that plug in a source such as a laptop or dvd player. When the display from the laptop or picture comes up go into the menu and reset the lamp hours I had the same problem. Hope this works if not let me know.
Nov 10, 2010 | Acer PH110 Multimedia Projector
I have a sanyo tv. Slightly older. Not hi-def or New
Hi:
This may be due to the possiblity that the you are on the wrong input source, If you watch HD Channels then the input source would either be componet or HDMI input. Try changing the input source of the television with the TV's remote until you see the Channels again. IF you are not watching HDTV then the television is on the wrong reception channel for the Direct TV's box. Try channel 4 or 3 or even 73.
May 06, 2010 | Sanyo AVM-2509S TV
No image on sony wega 42 inches
Was it working then stopped? What do you have connected to it? Does the screen appear to power up or is the bulb completely dead?
If it powers up normally power on all your sources and press the "input" or "source" button to cycle through the different sources and see if any will appear.
The more details you can provide the more accurate suggestions I can make. Hope this helps.
Cheers,
Jan 06, 2010 | Sony Televison & Video
How do I get back to the right input? Model TXE2546 25" TV
To change the input source for your TV, you can use your remote to change the video source by following these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button. The current source appears on the TV screen.
  3. Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Aug 17, 2009 | Samsung TXE2546 25" TV
Amplification does not work
It sounds like a source slecton issue. Try the following and if that does not help I would start with a simple stereo setup and source and work up from there.
The RV-8 is powered on, but there is no audio.
1. Make sure volume level is audible. Volume level can be
increased with the front-panel volume knob or the remote
control VOL �� and �� buttons.
2. Make sure audio has not been muted. The message “MUTE
ON” or “FULL MUTE ON” will appear in the on-screen and
front-panel displays when audio has been muted. To deactivate
mute, press the Mute button or adjust the volume level.
3. Check the INPUT SETUP menu DIGITAL IN and ANALOG IN
parameters to ensure the appropriate audio connector is assigned
to the selected input.
4. Make sure the RV-8 is receiving an audio signal. To do this,
follow the instructions that begin on page 2-29 to open the
STATUS menu for the current input source. Hint: (Use the "STAT2" Button on the remote.)
Apr 29, 2009 | Lexicon RV-8 V2.0 Amplifier
Blub goes out during use.
Most fans have a sense line to detect the fan is working properly, Possible the sense circuit has failed. The unit should not start if it thinks the fans are not running. Possible thermal problem with the sense circuit, since your unit starts up then stops.
Mar 10, 2007 | Toshiba TLP-ET1 Multimedia Projector
Acer PH110 Multimedia Projector Logo
182 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
