Washer top How do I remove the top or cover of the washer. I need to remove it to see where the washer is leaking from. I checked all of the hoses on the backside of the machine and the leak appears to be coming from the bottom front of the machine. Thanks, I need to remove the top/back of a Kenmore series 90 Washer. There are no corner pieces or clips to unhook. Please help! Model 110.26902691
  • alkhester Nov 07, 2008
    Thanks aborcass, but there is no link at all, no explanation either.
    Sweet - all done - not too bad for an old lady:)
    President:
  • Washing Mach... Master
  • 2,651 Answers
HERES A LINK TO SHOW YOU HOW
Posted on Nov 06, 2008
  • Ron Coons
    Ron Coons Nov 07, 2008
    should have been a link to you tube video, anyawy you can find a video on you tube, much easier then expaining it, not bad at all to do
I have a leak somewhere.where could it come from?
check the pipes from the water main and the pipes in the machine could be a seal has gone
Feb 19, 2016 | Kenmore HE2 Plus Front Load Washer
What does FA mean on the machine
Hello. You didn't state the model number of the washer so my help is limited. The FA error code on some washers indicates the flood sensor has been tripped. (Check for a water leak asap) There is a sensor, usually located at the bottom, rear, that trips if water comes into contact with it.(shorts across the terminals) and causes an immediate shut-down of the washer. I'm assuming this is a front-loading unit. Depending on the model, you will have to either remove the service panel from the middle of the rear panel or, remove the entire metal rear cover of the washer--about 20 screws more or less, the top 3 and middle 2 will be machine thread and not sheet metal screws(have a much coarser thread).
Check for water residue trails( to help you locate the source of the leak. Don't rule out a leak coming from one or more of the inlet water valves located at the top, rear of the washer underneath the top cover. Shut off the water at the wall first, and then do what *I* do--start from the top and work my way down. If the valves *are* leaking, there usually will be rust and moisture around the magnet coils of the suspect valve(s). (i.e. LG washers are notorious for leaking inlet water valves and I keep several sets on the svc van). Also, carefully check out the electric drain pump for a cracked casing or loose hose clamps--I hate those spring clamps--replace them with automobile hose clamps if you can(the kind that you use a screwdriver to tighten). If the valves aren't leaking, CAREFULLY check any and all hoses coming from the dispenser holder on a front-loader and the lines leading to the different dispensers on a top loader. I hope I helped you!
Sep 12, 2015 | Whirlpool Washing Machines
My kenmore washer molel 110-82873120 is leeking from the top.
Dear R.A.,
If your washer is leaking you should first check the hoses.
  • There are several types of hoses found on a washing machine and the most common are the drain and fill hoses.
  • The fill hoses connect the household supply to the water inlet valve and are normally located at the rear of the washer. Check to make sure that the threaded fittings are tightened securely and that the leak is not caused by the faucet.
  • The drain hose is also located at the rear of the machine and may not be properly installed into the household drain. Verify that the leak is not caused by a restricted household drain that is backing up through the stand pipe.
  • Washers will also have internal hoses that connect the inlet valve to the tub. A defect in this hose would create a leak during the fill cycle.
  • Access the tub inlet by lifting the main top or removing the cabinet and inspect the hoses for signs of abrasion or cracking.
  • Also inspect the other components of the water inlet system such as a siphon break or tub injection assembly for signs of a leak. Check for loose or corroded clamps, and cracked or perforated hoses.
  • Your inlet Valves may also be totally defective and cause the washer to overfill therefore causing a leak over the top.
  • Check for the tub Pressure switch assembly may be defective causing such leak.
  • Your model requires removing the complete cabinet.(front and sides come out as on piece) Here a link to all your machine parts
I think we cover all the possibilities.
Best of Luck,
JP
KENMORE AUTOMATIC WASHER Parts Model 11082873120 Sears PartsDirect
Jul 03, 2015 | Kenmore Washing Machines
Maytag neptune top load fav6800aww washer leaks from bottom during spin
for a start you should check if the rubber of the spinner is still ok. you will probable have to replace that rubber
Mar 21, 2014 | Maytag Neptune FAV6800AW Top Load Washer
Stackable washer (bottom), top load leaking water??
Easy fix most likely the water pump is leaking or the hose from tub to pomp. Remove the front cover
A couple of screws at the base come out and you can remove the front.
Run is a while with the cover off to see where the leak originates but
keep the pets and children away from the machine while the cover is off.
Tip it back to remove the belts.
Feb 10, 2011 | Maytag LSE7806A Top Load Stacked...
Whwn the washer is running. Getting a leak on the floor. Seems to get worse every time I wash.
need to remove front panel on washer usually 2 clips at top of unit between front panel and top panel approx 2 inches over and one on each side..if you stick a slim screwdriver in you can gently push and the clips will release allowing you to remove front cover.. once in there check the side of tub there is a small hose runs to side of tub assembly this is a pressure switch hose make sure it is connected and no holes in it.. if that is ok then check hoses going to tub and at the drain pump assembly.. may require you to start washer to check connections ... if no obvious leaks yet then fill washer and run through a spin cycle check pump assembly they are notorious for cracking or leaking ... hopefully you can find culprit this way... once you find source of water you can order parts from www.sears.com then hit the parts direct link up top it will go to a page you can enter your model number and find a parts diagram and price ...good luck to you
Jan 24, 2011 | GE WBSR3140DW Top Load Washer
I have a LG washing machine Model # WM2688H*M it has a slight leak that I traced to a small black hose. The hose is in the back of the machine that goes from the bottom of the drum to the top somewhere...
It's not likely the hose is leaking, but rather water is leaking from somewhere else and is running down the outside of that hose. Remove the washer top by taking out the two phillips head screws from the bottom of the plastic clips on the back side of the washer's top. Now, stand in front of the machine and use the palms of you hands to sharply push the top cover back about 2 inches, then lift the cover off. Look for the water leak. The most likely suspect is a water inlet valve.
Jan 01, 2011 | Washing Machines
My washer leaks and we checked the pumps and hoses. Pumps and hoses are fine. The leak seem to be coming from the top portion of the washer during agitation and spinning. Thanks Lian
Sounds like p/n 22001299, tub cover and gasket assembly, if it's leaking from the top or upper part of the washer tub. It could also be the bleach hose or air vent hose as well.
Unplug the unit from power, pop the top and look for water tracks down the side of the drum.
Or p/n 22002417 seal, which is at the top center of the drive shaft.
Let me know what you find.
Dec 12, 2009 | Maytag LAT3600A Top Load Washer
Leaks while tub is filling.
could be any number of things: water inlet to tub leaking and running down outside tub,tub seal on top of transmission,pump leaking,bad hose washer remove top and front cover,then plug-in and let it start to fill you should be able to see your leak easier that way be careful when plugged-in
Aug 02, 2009 | Amana NAV2335A Top Load Washer
Washer top
The following link should give you the steps necessary to remove the exterior washer casing to inspect the interior:
http://www.fixya.com/support/r397092-replacing_water_pump
The instructions are for replacing the washer pump, but the steps to gain access to the interior are the same. If the leak is coming from the FRONT of the washer, check the pump and drain hoses for loose connections. If the pump is leaking, it is not repairable (sealed unit) and must be replaced. If the leak is coming from UNDER THE WASH TUB, this is a symptm of a leaking tub seal, or cracked tub. This requires removal of the wash basket to replace either part. If the leak is coming from the SIDE of the wash tub after it starts to fill, check the air dome hose to ensure it is still attached and not leaking. This is a small air hose that connects to the side of the wash tub and runs to your pressure switch. It sometimes becomes loose or disconnected and leaks. If the leak is coming from the BACK of the washer, check the fill hoses and water inlet valve hoses. I hope you find this information helpful. If you need further assistance, please let me know.
Oct 19, 2008 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
83 people viewed this question
Top Washing Machines Experts
