I bought an 2 port usb kvm switch. why are there 2 usb connectors on each cable what do i do with the 2nd one. model gcs22u
  • 207 Answers
The purpose for each of the USB plugs are likely 1 for your keyboard and one for your mouse to each of the PCs you attach to your KVM
Hope this Helps
Posted on Nov 06, 2008
  • David Preston
    David Preston Nov 07, 2008
    After reviewing the product on IOGEARS website I can say that yes indeed the USB connectors are one keyboard and one Mouse to each PC you wish to control
    product page is at the following link.
    Hope this helps
I need to plug a 9-pin connector to a usb inside the computer but don't have a 9pin inside the computer. I do have an internal usb port so is there a converter?
Sounds like you're looking for something like this:
Jun 16, 2009 | Belkin 2 Port KVM with Integrated Cables -...
2-port KVM switch mouse & keyboard connected to wrong display
I have installed several of these KVM switches before... that's not normal. It sounds like there's a manufacturer's defect which is causing the video to link up with the wrong keyboard/mouse cables. If you just bought it, I'd recommend returning it and getting a replacement.
May 16, 2009 | Belkin F1DK102P 2-port KVM Switch
I have recently bought a KVM switch off ebay and have connected the two computers I needed to, upto the switch. The first time round the switch didnt work. To check the cables I shut down the...
Depending on the KVM (Brand, Model etc) there should also be a hot key sequence that will allow you to switch between the PC's. See if the hot key sequence works.
Also, is this a PS/2 KVM or USB ? In some cases with USB adapters you have to let the computer start up while it is set to that port. And if it is USB, does it also have a PS/2 connector? If it does, you want to use one or the other, not both. That can cause it to malfunction.
Jul 25, 2008 | Computers & Internet
Belkin KVM STandard 9 pin mouse/keyboard to USB COnversion
You need to have the keyboard connecter (purple) connected to your computer in order for the KVM switch to recognize it. The computer is providing some power through the keyboard connector and this is what the KVM switch is feeding on.
If you have a USB keyboard, you may want to change your KVM for a USB compatible one. If you just want to use the KVM to switch your monitor, you may plug the keyboard (purple) connector of the KVM to your computer's keyboard PS/2 port and also connect you USB keyboard directly to your computer. It should work.
Feb 08, 2008 | Belkin 2 Port KVM with Integrated Cables -...
Belkin (F1DK102P) 2-port KVM Switch freezes
We have the same model and the same problem. The scroll lock combo did not work for us. You need to press Ctrl, Ctrl then up or down arrow.
The manual was a load of old Tom *** as it did not mention this.
Dec 14, 2007 | Belkin F1DK102P 2-port KVM Switch
KVM GCS1734 with microsoft wireless mouse/keybrd 4000
The MS keyboard & mouse receiver is effectively a USB hub with two devices connected to it. So, plugging it into the keyboard socket on the KVM switch may well work, depending on how that particular switch implements USB. If it just passes things through, it should be OK. On the PC side you should only need to plug in the USB cable from the switch's keyboard port.
Sep 30, 2007 | IOGear USB gcs1734 4-port KVM Switch
Micrsosoft optical desktop 1000 to Belkin KVM switch
This is a common problem with a number of KVM switches - this model in particular. I have heard that the Bytecc BT-2000 connector will work in SOME cases: *5.99 on Newegg - It might be worth the investment to give it a try, if you haven't already tried this. Bytecc does make very high quality hardware. However, if that doesn't work, there's really not much else that can be done, other than replacing the KVM with one designed to run off a single USB port. Hate giving bad news like that. It's a hardware limitation, I'm afraid.
Aug 30, 2007 | Belkin F1DL102P 2-port KVM Switch
Belkin KVM 2 port switch
Sounds like its not detecting video on the 2nd port. Have you tried switching the computer on port 1 to 2 yet? If the problem moves then I would suspect that computers video card or the cable that connects it to the KVM. Let us know what happens or if you need more assistance.
Jun 26, 2007 | Belkin F1DK102U 2-port KVM Switch
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
