I have a samson f1200 amplifier. when i turn the peak led warning lights come on for both channels and dont go off. The amp is not outputting anything to the speakers
  • 20 Answers
SOURCE: sound problem on Sony TA-343 amplifier
If you're not experienced with troubleshooting and repairing electronics, I strongly suggest professional service. There are internal problems and most likely several components will need replacement.
Posted on Oct 10, 2007
mixculture
  • 14 Answers
SOURCE: Samson Servo 170 Amplifier
check see if youy have some coving the vent or the speak connect right
Posted on Dec 22, 2007
  • 905 Answers
SOURCE: leem m86t power mixer amplifier
probably blew the amps or the pre amp section
Posted on Oct 08, 2008
blueextc3221
  • 15935 Answers
SOURCE: ICBM-DIGITAL MONO-Channel 2000W AMPLIFIER speaker much
Look into competition lines of different manufacturers.... Massive Audio DMX, Soundstream, Atomic APX, Incriminator Audio Death Penalty Series, Kicker Solo X etc. In car audio, you have to pay to play. Dont expect a 100.00 subwoofer to take 2000W continuously.
Massive Audio offers a no questions asked warranty. Even covers blown voicecoils!
Posted on Dec 22, 2008
srinivasb81
  • 51 Answers
SOURCE: Center channel speaker output problem
Check for the speaker separately for proper working? If needed change the speaker and check it ok.
Posted on Jan 08, 2009
Samson SX1200 - Protect light on. No blown output transistors.
Have you checked the power supply section? Also look out for any IC's in the amp stages. They can go causing that kind of fault.
Oct 11, 2014 | Samson SX1200 Amplifier
No power up on ssl f2.200 car amplifier
Yes it does. You should be able to use the blue/white wire to turn it on if you are using an aftermarket radio.
Apr 09, 2012 | Sound Storm Laboratories F1200 Car Amp
How do I connect my samson amp to my samson MDR10 mixer?
on the mixxer, use the "mix" "L" and "R" outputs. use 1/4 inch instrument cables, and connect the mox L and R to the amp's "channel 1" and "channel 2 inputs". always turn the mixing board on first, and the amp second- when turning off turn off the amp first, and turn off the mixer second. start with the mixer levels at the lowest, with the amp levels about 1/2 to 3/4 up. slowly raise the mixer channels first and then the mixer main volume until you have an adequate volume.
Mar 09, 2011 | Samson SX1200 Amplifier
I have a s1500 samson amp I keep blowing speakers, what can I do to prevent this from happing again? The speakers that blown first was two 12'' yorkville 350 w impedance 8 ohm, the next speakers that blown...
Turn the volume down? Feed it cleaner source material?
http://s3.amazonaws.com/samsontech/related_docs/s1500_s2000_manual.pdf
You don't say under what conditions you're blowing them or if any of the informative indicators are warning you of impending doom. The Samson is capable of cooking just about any home speaker.
The following conditions will cause the Protection LED to go on:
Initial power-up: For approximately five seconds after initial power-up, the
protection circuitry is activated and the speaker output is muted. If everything is
operating normally, you will hear an audible click at the conclusion of this brief
period, as the protection circuitry is deactivated and the S1500 / S2000 begins
delivering signal to connected speakers (at which point you'll hear a click). It is
normal for the Protection LED to fade gradually after the amplifier is powered off.
Overheating: A temperature sensing device in the S1500 / S2000 will cause
the protection circuitry to be activated (and the Protection LED to go on)
whenever the operating temperature of the unit rises above a safe level. To
guard against this problem, make sure the S1500 / S2000 receives adequate
ventilation on all sides and that both the front and rear panels are unobstructed.
Severe overcurrent conditions: This occurs whenever the signal being input to
the S1500 / S2000 rises to a level above 20% THD (Total Harmonic Distortion).
Shorted speaker cables: This will occur if, due to faulty wiring, the hot and
ground signals being output by the S1500 / S2000 short one another.
Output impedance drops below 2 ohms: This can occur if the S1500 / S2000
is connected to inappropriate speaker systems (see the "Setting Up and Using
Your S1500 / S2000" section on page 5 in this manual for more information).
DC voltage detected at speaker output: The most likely cause of this is an
internal failure.
In general, any time the Protection LED lights up (other than during the
approximately five seconds following initial power-up), there is reason to be
concerned. If this occurs, turn the S1500 / S2000 off immediately and carefully
check all wiring and external devices in order to locate and correct the condition
that caused the LED to light up in the first place.
For further assistance, contact your local Samson dealer. If purchased in the
United States, you can call Samson Technical Support (1-800-372-6766)
between 9 AM and 5 PM EST.
Feb 07, 2011 | Crown XTi 2000 2-Channel Amplifier
Samson servo 300 right channel low output power protection on.Left channel ok.
Hi...
This amp will need to be serviced
Check on the web for someone who does audio/stereo repair in your area
Jan 22, 2010 | Samson Servo 300 2-Channel Amplifier
Ma audio hk 4000d
you have definately blown a output channel, or power supply. Send it in for warranty.
Jan 09, 2009 | MA Audio HK4000D Car Audio Amplifier
Logic alx1280 2 ch amp
Amps can be rated based on their RMS power or their peak power. In this case, the amp's rated RMS power is 300x2 at 2 ohms (total 600W RMS) with a peak power rating of 600x2 (1200W peak). For the most part, peak power means almost nothing.
If your head unit didn't have RCA preamp outputs, you would used the standard speaker outputs from the head unit and connect them to the hi input plug of the amp.
Mar 17, 2008 | Logic Soundlab ALX1280 Car Audio Amplifier
Samson Servo 170 - 1 dodgy channel
http://www.soundonsound.com/forum/showflat.php?Cat=&Number=403253&Main=351397
Dec 02, 2007 | Samson Servo 170 Amplifier
Samson sx1800 power surge
Hi There,
Manufacturers install protection devices in their audio systems that are there for that purpose, any loud 'thump' or 'crack' trips the protection device so the loud speaker wont be burnt out. Speakers are expensive so the manufacturer does his best to allow you to listen to very loud sound and yet provided protection in case you exceed the sound rating of the output protection device.
In your case it sounds like the protection device has done its job but has not reset, to allow more listening...
Check the operational manual that came with the amp system to see if there are re-set instructions available to you....
If you dont have the reset detail, then phone/e-mail the manufacturer to obtain the reset information...
If there is no resetting you can do as a consumer then it should be no problem for a service shop to do the reset for you...
It may be a simple internal fuse that has blown but if its not accessible from the outside then I dont suggest you go inside and make changes unless you are skilled and trained in electronic servicing...
Cheers for now YUBEUT
Oct 31, 2007 | Samson SX1200 Amplifier
131 people viewed this question
 Grubhead
Grubhead
