Question about Hoover AL130 Front Load Washer
Water won't stop heating up
When the machine is in the wash cycle the water is constantly heating up to extremely high temperatures, the machine is incredibly hot to the touch. This has happened intermittently in the past but now happens with every wash. Can anyone help please???
  • 641 Answers
You should replace the thermostat (it doesn't stop current to the heating element in the temp it should). Good luck!
Posted on Sep 04, 2007
Why is it not cleaning dishes?
Contact one of the Asko authorised repairers in your area and they will be able to tell you the likely cause provided the water in your machine is heating up to the correct temperature and not trying to wash luke warm and without the powder dissolving properly.
Set the machine for a hot wash and stop it and open the door mid wash cycle and check how hot the water is. It should be extremely hot and you should get a mass of steam rushing out when you open the door.
Jan 10, 2016 | Asko 24 in. D3121XL Free-standing...
My Roper washer will run through wash cycle then stops. Nothing will work for 40 minutes then I can put it on rinse then the cycle will complete. What could cause the stopping with nothing working then...
It could be that the machine is trying to heat the water in the drum, but is not able to for some reason. The timer is waiting for the water to reach temperature before advancing. Posssibly a broken heating element. This can happen even on a cold cycle as most machines prefer to heat all soaping water to about 30C regardless of the temperature setting.
Sep 13, 2013 | Roper Washing Machines
Ariston AQXXF 129 Error code F 05 - What is this?
see this causes and fix it. God bless you
F05 Water temperature sensor error If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Replace failed component.
Sep 30, 2012 | Ariston Technologies Washing Machines
Stop work and is showing a code f 05
Potential Causes
Dec 14, 2010 | Kenmore HE2 Plus Front Load Washer
KENMORE DISHWASHER CLEAN LIGHT BLINKS SEVEN TIMES M#665.17029403
The thermistor beneath the accumulator inside the sump detects the water temperature as it begins the first 8 minutes of the main wash cycle. During this time, the controller expects the thermistor to detect the 2-4 degrees rise in the water temperature when the first 8 minutes is completed. If the expected temperature rise is not met, the controller will not be satisfied. It will shut the dishwasher down and blink the clean light 7 times. Press the heated dry then normal wash buttons in the same sequence two times. The unit will enter diagnostics mode, but can be stopped by pressing the cancel button. It will clear the fault and makes the dishwasher run normal but the fault will appear again if you have problem in either of the following:
  1. Heater and its circuitry
  2. Water filling
  3. Pumping motor
If the heater is not working, the water temperature will not rise then controller will shutdown the machine.
If there's no water entering the machine, no water will be heated and there's no way the controller through the thermistor can detect any rise in temperature.
If the pumping motor is not working, the water cannot circulate over the heater and be heated. Again, the controller will not be satisfied.
You can bypass this fault detection feature by filling the machine either with extremely cold or extremely hot water. Water colder than 62 or hotter than 160 degrees Fahrenheit will make the controller not to check for a temperature rise but rather continue on the next cycle.
Please let me know if the problem still bother you.
Dec 03, 2009 | Refrigerators
Clean lite keeps flashing will not start whenstart
The thermistor beneath the accumulator inside the sump detects the water temperature as it begins the first 8 minutes of the main wash cycle. During this time, the controller expects the thermistor to detect the 2-4 degrees rise in the water temperature when the first 8 minutes is completed. If the expected temperature rise is not met, the controller will not be satisfied. It will shut the dishwasher down and blink the clean light 7 times. Press the heated dry then normal wash buttons in the same sequence two times. The unit will enter diagnostics mode, but can be stopped by pressing the cancel button. It will clear the fault and makes the dishwasher normal but will appear again if you have problem in either of the following:
  2. Water filling
  3. Pumping motor
You can bypass this fault detection feature by filling the machine with either extremely cold or extremely hot water. Water colder than 62 or hotter than 160 degrees Fahrenheit will make the controller not to check for a temperature rise but rather continue on the next cycle.
Dec 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
On the normal cycle of my Duet front load washer at 37 minutes the machine stops and flashes F5. I push the reset button then the start button and the machine works fine after that.
HI. This is a Water temperature sensor error.
Potential Causes
Replace failed component.(Most common issue will be a failed water temp sensor)
Jul 25, 2009 | GE WBVH6240F Front Load Washer
Machine runs for about 5 minutes on normal cycle than stops and flashes f 05. It works on other cycles
F-05 is the error problem for :Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed in between the running machine.
Check the Water Temperature Sensor, Heating Element and Element Relay and Check connections to the Sensor, Heating Element and Relay
in this case mostly the sensor needs replacement some times its only the case of sensor getting loose.
you can get new sensor from
www.repairclinic.com
thanks.
Jul 13, 2009 | Whirlpool Washing Machines
Washing Machine starts, squirts water, then stops.
E5E  IS FOR  Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 To much soap.
Nov 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing machine doesnt heat the water
Most washing machines do not heat water, they merely let the hot water into the wash tub that comes from your house hot water heater.... when selecting warm, hot and cold water will be mixed together to get warm or when selecting cold.. only the cold water is allowed into the wash tub.. Please provide brand and model number of machine so I can tailor a reply toward your specific washer...
Sep 21, 2008 | Washing Machines
Hoover AL130 Front Load Washer Logo
76 people viewed this question
Top Hoover Washing Machines Experts
shaun taylor
jimorris77
Steve F
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
