Chanel goes from ch8 to ch13 when ch selector is used, will not go to any other ch.
    Genius:
  • 2,920 Answers
Switch it fromair to cable
Posted on Nov 06, 2008
How do i set the chanel to 3 so that i can hook up cable with out a remote
Most sets it is impossible and will skip channel 3 and input. You will need to buy a cheap universal remote.
Feb 27, 2015 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony tv needs to be set to ch. 3 for comcast/ no switch
if you dont see the chanel 3,find the it from the menu or settings then you must rechanel it for manual rechanel then add it on
Mar 30, 2013 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Have a new cobra 29lx. Everthing works fine except for the SWR meter. Can't use the meter to adjust SWR. No matter what I do the meter stays the same. Sent to factory but they said nothing was wro
The SWR cannot be changed by rotating this knob. The SWR function allows you to determine the SWR or "match" of the antenna system and transmitter on a specific channel. The entire process must be performed whenever you want to know what the SWR is on a different channel. The SWR/CAL button toggles the meter between the CALIBRATE and SWR modes.
Set the radio to CH1. Press the SWR/CAL button. The radio CAL(ibrate) mode is now selected. Press and hold the mic PTT (or push to talk) button. Rotate the SWR knob as needed to adjust the meter indicator until it is on the SET mark on the dial. The meter is now calibrated for this channel.
While still holding down the mic PTT, press and release the S/RF SWR CAL button to the SWR setting to read the SWR on the meter.
This entire process should be done for Ch 20 and Ch 40. You must go through the CAL procedure for EACH channel before attempting to read the SWR.
Changing the SWR requires that the antenna be lengthened or shortened until such time that the SWR can be reduced no further. Typical SWR across the band may be:
CH1 - 1.5:1, CH20 - 1.1:1, CH40 1.5:1
or
CH1 - 2.2:1, CH20 - 1.7:1, CH40 2.3:1
The "dip" in SWR on CH20 is typical, as the antenna is the perfect length on only one channel - it will be come slightly too long or slightly too short as you tune up or down from CH20. The further away from CH20 you go, the poorer the SWR will be. You can "slide" the dip to any channel you prefer - say CH8. If you tune for lowest SWR on CH8, You might see CH1 with a 1.2:1 SWR, CH8 at 1.1:1 SWR and CH40 at 2.5:1. All are acceptable - sort of. Many manufacturers say up to 2.5:1 or even 3.0:1 matches are ok, There's no reason a quality antenna can't be tuned for optimum SWR in the middle of the band (CH20) to have less than a 2.0:1 SWR on CH1 or CH40, unless there is a ground issues or bad cable / antenna / connection somewhere.
You can view the manual here. I hope this helps & good luck!
Nov 30, 2012 | Cobra 29 Lx Full-featured Cb Radio
I need replacement lenses for ch5076h
Lydia31 The Chanel 5076 is discontinued but we make aftermarket lenses for this model that are better than the originals. They are $39.00 for the pair. Contact us at www.sunglassreplacementlenses.com
May 10, 2011 | Chanel CH 5076H Sunglasses
My remote control's input select button wont work.....how do i do it manually?
Not sure about this particular TV, but usually, you select inputs by channel selector. Go to Channel 1 on TV not Cable or dish, Use the channel selector button on the set itself, go down from 1. You should see somthing like Aux or Line, then aux 2 or Line 2 etc.. eventually (3 clicks or so) rolling around to ch 115. But usually between the highest ch on the set and ch 1 are the auxillary input selections.
Nov 11, 2010 | Emerson EWF2004 20" TV
Sound problem with home theater speakers
Change both left & right TDA7275 IC
Change all the 1uf 50v capacitors related to the IC,s
Thank you very much
contact me at meganetsl@yahoo.com
thank you again
M.Fateh Almunajed
Jul 28, 2009 | Yamaha 5.1-Ch. Surround Sound Home Theater...
VCR model VHQ 41m
I have not heard of one that doesn't have the selector switch to change to 3 or 4, Could it perhaps be in the front behind a door or just somewhere else?
Aug 01, 2007 | Quasar VHQ401 VHS VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
