Question about Mitsubishi VS-60719 60" Rear Projection Television
Color i cannot get my colors to align on the crosshairs or to adjust the colors what do i need to do
    Genius:
  • 2,920 Answers
You need to have someome come out and converge the colors
Posted on Nov 06, 2008
My elevaition crosshair wont raise high enough to raise my point of impact
your crosshair actually needs to go lower to raise the point of impact. if thats what you meant than you have a mounting/scope problem. the scope should naturally align within the adjustment range assuming the mounts are correct and the scope is functioning and mounted properly.
Sep 29, 2013 | Barska Optics Optics
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 28, 2011 | RCA R52WH73 Projection Television
I cant site the scope in the adjustment ot make it go left to right will not adjust
Put the gun in a vise. Look into a mirror and align the crosshairs so that you have one set of crosshairs when viewing in the mirror. The windage adjustment is maxed to the side you are trying to adjust . This will set the parallax of the crosshairs close to zero and allow adjustment in all directions.
Dec 30, 2010 | Leapers Optics
Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
To process and save the adjustment made, follow the steps below;
  1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  2. Enter the menu on your TV. Use the remote control and bring up the menu.
  3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  5. Press "Enter." A crosshair pattern will appear on your screen.
  6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  9. Repeat these steps for all colors.
Take care
Jul 06, 2010 | Televison & Video
I have a Philips 46PP9302 and can't find the Quick Setup guide. I'm wondering if it is located on-line. We moved our tv and want to recalibrate it.
http://www.retrevo.com/support/Philips-46PP9302H-TVs-manual/id/278ci462/t/2/
The above link should take you to the location where you can view all the parts of your models manual. Select the area of interest and rad onlinje
Please rate my help++++Thanks for using FIXYA
Nov 24, 2009 | Philips 46PP9302 46" Rear Projection...
Mitsubishi WS55859, was getting 2 and 2 blink, replaced the pico fuses and convergence chip - 3 times, each fix worked better than the next but evenually failed - now have it working, trying to adjust...
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 07, 2009 | Mitsubishi WS-55859 55" Rear Projection...
I have a 56" toshiba dlp. It has a red have throughout the screen. sometimes worse then others. Is it the bulb? color wheel? Is it something I can fix? Where do i get the parts.
This sounds like the alignment of the red beam is off. There is usually a configuration tool in the menu that shows a white cross in the center of your TV against a black backgound (if it's aligned properly). It's a combination of the red, blue and green light bars hitting the screen. You should be able to adjust the positions of these crosshairs for each of the colors and "fine tune" your picture. Some of the higher end TV's even do a grid with over 100 crosshairs to fine tune every few inches or so. Once you get the red beam in line with the others and save the settings you should be good to go!
Aug 27, 2009 | Televison & Video
Unable to align red crosshairs in horizontal range
No there are no quick fix options for this fault. The convergence amplifiers operate similar to a high power audio amplifier, so if there is an impairment anywhere in the system, it will result in distorted audio, or in the case of television convergence amplifiers, one or more colors won't align. The convergence power pacs need to be replaced and the out of tolerance precision resistors located near the power pacs need to be carefully checked and replaced as necessary. And the power supply fuse links to the power pacs checked and replaced as needed.
It is also possible that there are root faults that cause the amplifiers to go bad which include bad connections or a bad digital control module. This repair is possible for anyone having basic electronics knowledge and soldering skills. After the above repairs are performed it may be necessary to perform the static convergence realignment procedure using the outer cross hairs as you mentioned, and realigning them.
Apr 23, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Alignment issue - PT-47wx49 Panasonic PTV Tubes out of align
your convergence is off. u need to get in service mode to correct this problem. its pretty in depth and time assuming. u need to go to servicemanuals.net and for 15 bucks u can get a service manual. it has every thing u need to fix that tv. i had same problem but i had all 3 colors out of whak. i see alot of people on this forum changing the ic's and resistors to fix convergence problem, (me too)and nothing works. i got this manual and saved me alot of money. its been 3 months since i corrected it and i am still watching it. good luck.
Nov 24, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Picture alignment
If your convergence alignment wont work by the convergence menu you have defective Convergence ICs for about 10.00 each there are two that need replacing. If you need any further assistance let me know.
Feb 03, 2008 | Mitsubishi VS-6041 60" Rear Projection...
Mitsubishi VS-60719 60" Rear Projection Television Logo
74 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
