Question about Panasonic Lumix DMC-LZ2 Digital Camera
Panasonic lumix lens go crazy...
Hello! I'm having the same problem as bonadrag14 does... Anyone figured this out?
I found 3 grains of sand between the grooves where the lens moves round between the pcb and front casing. I had recently been on a beach holiday! It was tricky to get them out as the electricity/ static was attracting them. I used a wet needle and they clung to it. It was a painstaking process but rather this than spend hundreds on getting panasonic to do the same or buy a new camera.
Posted on Jul 26, 2007
    Problem Solver:
  • 5 Answers
I had same problem... my kid dropped the camera today... First make sure the lens isn't cocked and make sure the smaller piece of the lens is orientated in the correct direction (make sure it isnt turned at an angle) Next, when you turn it on, you will see the segment of the lens closest to the base of the camera turn. To get my camera going, i had to help it as it turned. As it was spinning clockwise i grabbed the segment that was spinning and turned it past the point it was getting stuck. not too much force. Once I did this it worked fine again. When I shut it off it retracted completely. When I turned it on it worked as normal.
Posted on Apr 10, 2007
I had the same problem, but could not get those screws to release. Based on your observatoins, I could look into the gap between the lens and the body and I saw a piece of foregn matter there. First i tried a toothbrush, which just moved it around. then I took tore off a small piece of stiff paper , slid it into the gap, and worked out the stuff that was lodged in there. It worked! Good luck!
Posted on Apr 01, 2007
    Problem Solver:
Comment by bonadrag14: Like many of you, I couldn't justify sending my camera to Panasonic when a new camera would probably cost less. I've stared and cursed many hours, took it to several different places, then gave up. GOOD NEWS!! I think a tiny spec of dirt or sand got lodged in it. Unscrewed the four side screws, tested it and it worked. I don't know if this will solve others' problems, but it worked for me. Maybe it was pressure? I did see something tiny (like a grain of sand) in the middle of my lens INSIDE, and it did move around. But it works, and I'm happy. Again, all I did was unscrew those 4 screws on the sides, not on the bottom. Good luck!
Posted on Oct 29, 2006
Read my latest comment, it might be a fluke, but it's worth a try to unscrew it because it's not worth sending it back, and the only other thing you could do is sell it on ebay or craiglist for parts. Good Luck! MINE WORKS :)
Broken screen on panasonic lumix DMC-LX2. Have repair???
Hello I got one with broken lens (grinding cogs) : otherwise P'fect could we organise something ?Pete Cooper.
Aug 12, 2012 | Panasonic Lumix DMC-LX2 Digital Camera
The zoom wheel does not stop when I want it to. It like it has its "own" will... Once I start zooming it goes all the way until the max. Sometimes when I make it (somehow... I don't know how)...
Hello.
It sounds like your camera's lens is broken. Did you accidentally drop it? When you shake your camera, do you hear something moving inside? Like a loose part? Or looking in the lens do see anything amiss?
Aug 13, 2011 | Panasonic Lumix DMC-FZ28 Digital Camera
Where can I get my Panasonic Lumix DMC-LS75 fixed?
call panasonic directly. however, your warranty doesn't cover accidental damage.
Jan 28, 2009 | Panasonic Lumix DMC-LS75 Digital Camera
Panasonic lumix dmc-fx01
If the dark spot is not focused, it could be on the sensor. Otherwise, check the lens for any dust particles. If you can't find any dust, take the camera to an authorized service center.
Aug 20, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera mesaage says turn camera off and on tis has no impact also the lens will not retract
hello, i did get also same message and lens did stay out. did put camera in play back mode and in menu did reset everything. now it works again. maybe i was lucky, maybe this is ,,the"solution.
Jack
Jun 18, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Replacement lens cap for Panasonic Lumix DMC-FZ7 digital camera
Please see below for a link to the Lens Cap with String. This is an original part direct from Panasonic. Used specifically with this camera.
Lumix DMC-F27 Lens Cap with String
Mar 26, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Hello pronlem with a panasonic lumix dmc-fx7 battery
help,i have solution panasonic lumix dmc-fx7 lcd blank water damage
Jan 19, 2008 | Panasonic Lumix DMC-FX7 Digital Camera
Panasonic Lumix DMC-LZ2 Digital Camera Logo
62 people viewed this question
Top Panasonic Cameras Experts
Jay Plesset
cesarakg
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
