Question about Kenmore 88732 Top Load Stacked Washer / Dryer
Kenmore Laundry Center 417.99160120
I need to get the agitator out of this machine to get to some fabric that is stuck between the tub and the agitator. I have unscrewed the top and soaked the shaft/center with PB blaster overnight. I even poured hot water over agitator, all to no avail. I can literally lift the whole machine off the ground washer, dryer and all. I heve whacked it with a hammer to get it unstuck. I am an engineer and an automotive tech so this is not rocket science to me. Is there a special tool like a puller for this job or do i have to take this machine out in the drive way and hook it up to some rope and a 2X4 or something. The stud with the threads for the cap comes out of a bolt that is surrounded by a metal ring - preventing one from putting any kind of socket on it since it is basically flush! Your expert help will be greatly appreciated and may I say Uplate looks pretty cute!
Thanks,
Ray
  • ray32825 Nov 07, 2008
    Yes I did remove the cap - as I mentioned in my post.
    President:
  • Kenmore Master
  • 2,651 Answers
Did you try remove the agitator cover/cap. thinkin hteres a screws holding it down to center shart,
Posted on Nov 06, 2008
Kenmore Model 110.2234 top loading wash machine About a year old It is so loud on spin cycle we cant hear each other talk in the other room with laundry door shut What is the problem?
Possible bearing failure but if only a year old, it should be under warranty. Check around the spin bowl for any foreign objects sticking through the tub. Perhaps a bra wire or nail , screw etc or something has come out and stuck in the tub.
Nov 20, 2016 | Kenmore Washing Machines
Top agitator won't rotate. bottom rotates but top is stuck in neutral and spins freely
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the section on the Sears site for Agitator, basket and tub.
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=a10ed20760ebb48ebf7c5df88d5f840d
Nov 21, 2009 | Kenmore Washing Machines
I have a kenmore elite model # 20949 and the bottom of the agitator turns but not the top
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
See the part "Dog, agitator "
direction only.
Oct 31, 2009 | Kenmore Washing Machines
Clothes get stuck between drum and opening, come out with "burn marks"
There should be a felt type seal on the drum in that opening to prevent this. It could be that it fell off or wore out. It is a hassle to put on unless you have good access but not difficult with a bit of patience.
Sep 04, 2009 | Kenmore 73952 Gas Dryer
Anyway to remove agitaror to get stuck piece of fabric without tearing apart entire machine? Kenmore top loading washer
This is a simple procedure. Just follow these steps:
1. Remove the center post cap or fabric softener dispenser (if equipped) from the agitator by gently prying it off.
2. Under the center post cap locate the air gap plastic cap (if equipped) and remove.
3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4. Remove the upper portion of the agitator (called the "auger") by lifting straght up.
5. Remove the lower portion of the agititator by grasping the lower flanges near the bottom of the wash tub and pulling straight up.
This will expose the transmission shaft and anything that may be lodged under the agitator.
Reassemble in the reverse order of the instructions I provided. NOTE: Make sure you only tighten the agitator bolt until it is snug. Do not overtighten as this can break the agitator or restrict its movement.
If you have any questions, please let me know. I hope this helps you.
Jun 25, 2009 | Washing Machines
Kenmore Dryer 70 series washer agitator sounds like its skipping
Remove the center cap, or fabric softener dispenser (if installed) from the agitator center post. There should be another cap (used as an air gap) under the center post cap. Remove the cap and locate the agitator bolt. Using a socket and ratchet, hold the agitator still with one hand and loosen with other. The upper portion (called the auger) should lift off, first. Then, grasp the agitator by the flanges at the bottom of the wash tub and lift straight up. This will reveal the gearcase (transmission) shaft.
Now...is the entire agitator slipping? Or, is it just the auger? If the auger is slipping, you may just need to replace the agitator dogs. The following link explains:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
Read through the link provided and let me know if you still need assistance. I hope this helps you.
NOTE: If the dogs are worn and need replaced, you only need to remove the auger and not the entire agitator.
Jun 22, 2009 | Kenmore 15864/15862 Top Load Washer
Agitator came apart while doing laundry
There is a bolt that holds this together that screws into shaft. Is the upper agitator broke? Or the ratcheting part in the center? Give full model number to further assist you.
Jun 15, 2009 | Kenmore 15864/15862 Top Load Washer
Sheet stuck under washer agitator.
remove agitator top remove 7/16 bolt to remove agitator. tub mounting hub may be worn which allows the tub to drop down. the hub is located on the center post below the agitator.
Dec 20, 2008 | Kenmore 23822 Top Load Washer
Kenmore Washer 70 Series - sheets stuck around agitator
The transmission probably stripped the worm gear that drives the drum - you would have to crack it open and take a peek.
Nov 24, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore 88732 Top Load Stacked Washer / Dryer Logo
213 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
