Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Cannot close drawer...topper is in down position
    President:
  • Fisher and P... Master
  • 2,651 Answers
Is it open only a few inches??? or completly open, if only a few inches, i would force back and then start the machine, the first thing the unit will try to do is lock/unlock the lid, first time id chaulk it up to a glitch.
Posted on Nov 07, 2008
Kitchen Aid KUDD03DT top drawer won't stay closed
The lock lever on the unit --- that is shaped like a U --- if you have it ---may be bent a little. You can move it to the correct position - usually down a little --and your door will stay closed
Mar 04, 2014 | KitchenAid 24" Double-Drawer Dishwasher...
Opened the drawer while it was running now the drawer will not close
Turn off the mains power and back on and see if there is any change.
The drawer lid is stuck in close position when you opened the drawer. Try to select another program on the panel and see if it clears the stuck lid.
Jan 18, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Cd rom door opens by itself
If the drawer does not detect that it has completely (100%) come to the "closed" position, it will open itself up, indicating that you should remove any object that is preventing the drawer from reaching the "100% closed" position.
Aug 30, 2013 | Compaq Computers & Internet
Whilst the cd drawer was in the open position I caught it with my knee leaving the drawer on an angle. When I press the close button nothing happens and any attempt to close manually is met with...
drawer is out of alignment...some players have timing marks to align the gears(similar to engines)...but without a service manual..it may be complicated...you can try to realign the drawer...there is a limit switch that tell the player when the drawer is fully open and one that tells the player when it is fully closed....a good way to try to realign is to move the drawer one tooth at a time and trying it..until it lines up
May 26, 2011 | Marantz PMD320 CD Player
Crisper drawers are feezing vegetables.
look down at the bottom crisper and there should be an air control that lets more or less air in from the freezer section. close this control down so that most of the air stays in the freezer. some models may say meats(colder) and vegetables(warmer).
some models the control in the down position opens up the vent more allowing it to get colder and in the up position closes the vent down more allowing less cold air into the refrigerator. you can remove the crisper and experiment with the control.
Jul 14, 2010 | GE Profile¿ Arctica® Energy...
Dishwasher lid stuck
the lids on dishdrawers are pulled down and sealed by lid activaters. there r two types, the screw type and the magnetic solonoid type. the reason your draw gets stuck is your lid activator is not releasing. there are 2 reasons for this 1st- 1 or both activators are faulty. 2nd the lid activator control board is faulty, which is located under the bottom drawer.pull the draw out and see if u can see if the lid is down on 1 side or both sides.please reply 4 more help.
May 02, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
CD DISC IS NOT SPINNING
Check the cd drawer sometimes the position switch is not detecting the drawer completely closed.
It could be an obstructing object stuck behind the drawer door who prevent the drawer to close completely.
Spider Guy
Jan 11, 2010 | Audio Players & Recorders
We have the bottom drawer freezer, top french doors, 3 months old, freezer will not shut all the way and now after door open beep has gone off for an hour the whole unit has gone dark
Make sure nothing has fallen behind the freezer drawer or is hitting the top of the freezer to prevent it from closing. Also check that the tilt open front is in the closed position. If nothing is blocking the drawer the gear wheels that support it may not be in the right position. See Owners Manual for instructions about removing/reinstalling the drawer. When you get the drawer to close you may have to unplug the power cord for 30+ seconds to get the unit to reset and restart.
Aug 11, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Bottom drawer does not properly close
Okay, I fixed it for now. The design for this bottom freezer drawer is not good. What happened was most likely that my son slammed the door, and it bounced and was slightly open. Overnight, ice started to form all over the compartment, including inside the drawer guides. Some ice was probably obstructing the drawer glide from sliding shut.
What I did, not thinking this was the solution, was to prop chairs against the drawer to close it while I searched for answers on the Internet. In the meantime, some of this ice must have refrozen in the closed position (due to the weight of the chairs). When I went to check it later, I had a little trouble opening the drawer. I gave it a hard yank and some small frost flew off, as I opened the drawer.
It was not easy sliding it due to the frost. I then moved it out and in until it felt smooth, and finally closed the drawer and it stayed in the shut position.
Kids are instructed to close the drawer gently and visually check that it is sealed. There is also an air passage between the refrigerator unit and the freezer so that when you close the double french doors, some air pushed to the freezer section and momentarily pops the drawer open. You should make sure that the drawer closes before leaving the kitchen. If you are on vacation, prop chairs to make sure both the freezer drawer and the french doors stay closed. This is important if you're in an earthquake area as a small tremor could open the doors and you'll get a fire when the lights stay on and burn through the wiring (as others have noted).
Dec 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
CD drawer will not open or close
Hi, The CD drawer mechanism needs a new belt. They have a motor that drives the tray mechanism, and there's a small belt that drives the main gear so that pushing the drawer in gently to close it doesn't damage anything. However, once that belt breaks/wears out, the drawer will stay in whatever position it was last in.
Jul 24, 2008 | Audio Players & Recorders
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
