Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P knocks when spinning
I get a knock when my washer spins. Clothes come out dry but the knocking is getting worse. Bearing?
  • cr101960 Nov 09, 2008
    After reading other problems with this washer I decided to take a shot at it.
    After removing the back cover and looking at the shocks and springs I noticed that the belt wheel lock nut was loose. I took it off and looked for damage then put it back in place. I tightened the lock nut really good and so far all is good. I did notice that the lock nut needs to be a smaller profile. We use these at work all the time and they require one thread out past the nut. This one is under flush and not locking.
I had that problem while the washer was under warranty. Luckily my neighbor is a repair man. He removed the front cover just under the door. There are shocks under the barrel that keep it aligned. One of mine was damaged and the barrel became misaligned. Check that area, that might be your problem. Good Luck!
Posted on Nov 09, 2008
Knocking during spin cycles, and water coming out of soap dispenser
hello, usually the knocking noise is a failed bearing. If it is the bearing it cost alot to repair. Try lowering the front legs to stop the leaking. hope this helps.....
Jun 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet steam washer knocking noise when in spin cycle.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Loud knocking and vibration during spin
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet Washer rattles and knocks when spinning
you either have a broken shock or the spider gear is gone,take off the bottom panel and check out the shocks,if it's the spider gear it's time for new washer,it's around 500 bucks for new gear,to much detergent used over the years eats at the metal
Jan 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Knocking sound, violent spin cycle led to not
my problem to just 3 days ago from yours! bearings are out, $600 getting a new one.
Jan 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer is knocking in front left when is starts spin cycle. The unit used to stop and re-align but not longer does. The knocking gets louder at slow speed and somewhat improves at a faster speed. What...
The unit is self aligned when all the load springs connecting from the tube to the bottom chassis are intact. When one of them some how gets out of its position or broken, it causes the tube imbalance so it knocks during the spinning. There are about 8 springs distributed evenly from front, sides, and the rear. Need to check these out.
Jan 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Very loud knocking during spin cycle
I just had a technician tell me that problem was caused because the main rotor bearing was bad. Apparently, it is a sealed bearing that comes apart due to the excessive spinning. The repair charge is $800.
Jun 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet washer knocking sounds
From what it sounds, it could be one of the suspension bars. when it's spinning, it is all in the same direction where as agitation is both directions... that would make noise from starting and stopping directions etc. it could be a few other things... please let me kno if you need more help.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
342 people viewed this question
Dan Webster
Dan Webster
Sal De
