Question about Estate TAWS800JQ Top Load Washer
Estate top loading washer needs a lid switch replacement
I read your expert advice on estate top loading washers and how to replace the lid switch. the only thing i need is the replacement part. how do i get that?
  • angelbladel Dec 19, 2008
    i now what the problem is its the lid switch.the question is ,is it hard to put in your self?
I found one one NEW on ebay for 6.50 + shipping, total 12.49. Other parts places had them for a lot more. It wasn't too hard to install.
Posted on Dec 01, 2008
Agitation does not stop when lid is open... Kenmore 20172 Top Load coin-op Washer needs new lid switch? Cost? Easy to Fix? Do I need a expert to do? Thank you...
sounds like the lid switch is jammed on- you can try to spray it with WD 40 or replace it it usually requires taking the machine apart to get at the wiring. Easy fis, just need patience. the switch should be able to be ordered online.
Oct 21, 2010 | Kenmore 20172 Top Load Washer
Estate washer lid switch
Simple, dont as this could be very dangerouse. as machine will work. Think saftey as you dont want children, or your own limbs ripped from your body for the sake of saving a small ammount of money.
Mar 09, 2010 | Whirlpool LSR6232J Top Load Washer
Washing machine timer stops mid cycle
Your lid switch needs replacing.
Part number 3949237 available at any applinace parts store.
Apr 05, 2009 | Estate TAWS800JQ Top Load Washer
Lid switch isn't working
yes you do,yo can watcxh this video to show you how to remove the cabinet switch, maybye no t your switch but you cgain acess the same way/.
http://www.youtube.com/watch?v=6XIsK3W_Qcg
Mar 09, 2009 | Estate TAWX700JQ Top Load Washer
Don't run all the way thru
This problem is commonly attributed to a lid switch malfunction. If the model number you have this listed under is correct, the lid switch is mounted under the washer top casing, on the right hand side. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If your washer is not configured in this manner, please post back with your COMPLETE model number (located along the tub rim under the lid) so I can confirm how your washer IS configured.
If you determine that your lid switch is broken, the following link will give you the necessary steps to replace it: http://www.fixya.com/support/r397101-replacing_lid_switch You can order a replacement switch on line at searspartsdirect.com. Just type in your model number and look for item 9 under the "Top and Cabinet" heading. The lid strike is listed as item 20. NOTE: Another thing that can cause lid switch malfunctions, is the lid being bowed. This can occur from placing heavy items (such as detergent bottles and clothes baskets) on top of the washer. If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 29, 2009 | Estate TAWX700JQ Top Load Washer
ESTATE WASHER
ck lid switch earlier modes had switch on right of lid opening later it was moved to left rear hinge area ..those on right just replace those on left first ck hinge screws on left be sure they are secure listen for click when closing lid..no click raise lid push on hinge arm on left side toward rear of washer slightly try again still nothing remove console screws on rear of console lift and roll console back ck switch on left side may be broken if so replace
Sep 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer estate brand ETW4300SQ Model
If the washer fills and stops at the rinse cycle, and then will not spin or drain, you more than likely have a defective lid switch. If you open and close the washer lid and do not hear a “clicking” sound, the switch has probably come loose, or has broken. There are two mounting screws that hold the switch in place along the washer rim. Also, inspect the lid to ensure the small plastic piece that pushes down on the switch when the lid is closed has not broken off. This is called the “lid strike”. If the lid strike is broken or missing, the lid switch will not activate. If you diagnose the problem and need to replace the switch, you can click on the following link for advice on how to replace it:
If you need further assistance, such as where to get replacements parts, please let me know. I hope this helps you.
NOTE: You do not need to drain the wash tub to replace the switch. Once the switch has been replaced, the washer should spin and drain, which will prevent you from needing to bail water.
May 23, 2008 | Estate TAWB600JQ Top Load Washer
Washer will not complete rinse cycle and will stop.
it is probably the piece that your lid pushes down to let the washer know that it is closed try hitting the lid realy hard.It happened to me i have to do it every time
Feb 11, 2008 | Estate TAWS800JQ Top Load Washer
Estate TAWS800JQ Top Load Washer Logo
189 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
