Question about E-Machines eMachines Desktop PC
Monitor not recieving signal
I have an t6536 e-machine and the monitor is not receiving a signal the monitor and cord is good checked with anther computer
  • 2 more comments
  • kmmm7 Nov 07, 2008
    i tryed the monitor on another computer and it works then when i hook it back up to the one it still says no signal
    i think i got it fixed thank you so very much and i think i only have the integrated video card if it happens agian i will let you know
  • athome43 Nov 14, 2008
    I have the same problem with my emachine. It also has the integrated video card. Can you tell me what you did to fix it
  • Diana Townsend Nov 19, 2008
    i have an EMACHINE T6420 and last week. when i would go into vnc (pc connecting software) the monitor would just go blank. i couldn't get it back either unless I unplugged the machine for a few mins and plugged it back in. Then it would run fine for awhile and sometimes turn off again but always seemed like when I was in vnc software. I uninstalled vnc software and re-installed. I ran adware, malwarebytes and our antivirus software and got nothing. I thought memory was faulty. I bought new memory and replaced. The pc came up once and went down again when i went into vnc software. shut machine off to reboot and it will not come up. The keyboard stopped working the mouse stopped working and i have no video. I also can not ping on network anymore. so I can't remote into it either.
    Sergeant:
  • 207 Answers
Have you tried a different Monitor with the PC?
Sounds like a Video card problem. Try a different Monitor that you know works with it. If you have the same problem try removing the video card from the PC and then put it back in. Make sure it fully seats into its slot, if the slot has a flipcatch at the back of it make sure that swings up and locks into the notch on the video card. If there is a power connector on the video card make sure that it is plugged in.
If you try these and you still have a problem, please post a comment here, so I can further help you
Hope this helps
Dave
Posted on Nov 07, 2008
  • David Preston
    David Preston Nov 07, 2008
    Your Motherboard has an integrated Video adapter that I think may have inadvertently turn on. Do you have a seperate video card (One near the bottom of the PC in the slot ports) or do you just have the integrated Video (Up near the mouse/keyboard and USB connectors)
    If you have a seperate Video card move your monitor cable to the Other Video connector, If you then get a signal, let me know and I can advise you how to change your BIOS setting to use the seperate card.
    If you do not have a seperate card let me know and I can try to think of other causes for your problem.
    Looking forward to helping you
    Dave
No sound coming out of reciever
Check that you have not pressed tape monitor, or changes the speaker A/B settings if these are available on your machine, but first, check that you have not muted the receiver. If these settings are good, unplug the machine, wait a minute a plug it back in.
On this unit there is a speaker switch so make sure that it is ON.
Mar 03, 2011 | Kenwood VR-5080 Receiver
Hooking up my Sony HD Tv
Couple of items come to mind.
In the menu of the receiver, is there a way to choose video and RGB?
Set the receiver to SAT
Connect the HD Cable Box to SAT
Check the TV is on Monitor RGB.
Check the input being used by the monitor RGB cables is selected on the TV.
Have a picture? NO, receiver has issues.
Yes? Do this with each input to confirm they work.
You can reset the whole receiver to factory by holding the tone button down and holding the standby button for three seconds. (This clears your speaker setups, too.)
Apr 02, 2010 | Televison & Video
Blu-ray player won't play through hdmi with yamaha reciever
The problem is some intermediate connections do not allow the HDCP signal to reach the telivison. Electronic HDMI switches have this issue. I have one HDMI port on my Telivision and I have a Blu-ray player & HD satellite reciever. I had purchased a two in one electronic switch and found that the satellite reciever signal would make it to the tv and was working but the blu-ray player was not. I had to by a passive push button switch and it allows the HDCP signal thru. The funny thing is the electronic switch was supposed to be HDCP compliant and it still did not work.
Sep 06, 2009 | Yamaha Audio Players & Recorders
Baby monoitor reciever piking up no sound or delayed sound - link light flashing
A delay may be caused by interference from other radio sources. I heard of one case where a woman's cell phone call overpowered the transmit power of her baby monitor.
Other things that can cause interference or other receiver problems:
1. monitor in contact or close proximity to running appliances or their cords. (induced electromagnetic field)
2. neighbor with baby monitor on same channel ('cross-talk')
3. distance between transmitter and receiver too far (the strength of a radio signal fall dramatically over larger distances. think of how often you lose cell phone coverage)
4. reduced power: low battery strength or cooked power supply
5. transmitter or receiver insulated from signal (if your monitor was transmitting/receiving through any metal obstruction)
May 07, 2009 | Kitchen Appliances - Others
Hooking up surround sound to t.v.
Start with the receiver. If your speaker connections are done and you have good sound coming from the speakers, connect your components (xbox, dvd player, cable box, etc) to the appropriate connection type on the back of the receiver (HDMI, Component, etc for video; Optical, Coaxial, or analog for audio). Next, find the "Monitor Out" connection and hook that to an input on your television. The receiver should take care of the rest in the setup menu. To program your receiver i suggest downloading the user manual (search google for the make and model number of your reciever you should be able to find one available).
Things to remember.. your reciever may not "up-convert" video signals, which means if you hook Component into your reciever from, say, a dvd player and your Monitor Out is HDMI to the TV, your receiver might not switch the connection for you. If you end up with good audio but no video on an input, this is why. Try running that same video type (Composite, Component, HDMI, etc) to the TV from a seperate Monitor Out.
Your subwoofer, which I am assuming is a "Powered" type that plugs into a receptacle as well, plugs into the back of the reciever on the "Subwoofer Pre-Out" connection. If it is "Passive", which is unlikely, let me know.
The rest is programming, which is usually done in the setup menu or main menu for your receiver. Again, I recommend downloading the manual from a good website.
Apr 11, 2009 | Panasonic Televison & Video
Computer not booting up
Could be one of two things:
1. Signal cable from monitor isn't hooked up. (either monitor end or computer case end)
2. Video card in the computer is damaged and not putting out signal. This is unlikely though as usually this will trip the motherboard into beeping when you turn the computer is turned on.
3.
Jan 15, 2009 | E-Machines eMachines Desktop PC
Pc powers up but nothing on the monitor
I have run into this a few times and it has turned out to be a bad motherboard.Also the power supply they put in the emachine is not very good.The power supply in them has caused the motherboard to blow.Im not saying it is your motherboard, that is just a good possibility.Goodluck
Sep 22, 2008 | E-Machines eMachines Desktop PC
No sound from speakers
1.check that speaker is power on properly
2.either volume of speaker is not low
Mar 05, 2008 | Princeton Digital VL1716 17" LCD Monitor
Can't get componet Video to work
Make sure you have an input Video signal on that Yamaha Reciever (exa. DVD, Cable box, etc...) then choose the right input selection on ur receiver (Video1, Video2, AUX, etc..), then connect ur TV on the receiver Monitor Video out. And put your TV on the right VIDEO input too (Video1, Video2, AUX, etc..). Goodluck
Aug 10, 2007 | Yamaha HTR-5930 Receiver
E-Machines eMachines Desktop PC Logo
81 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
