Home | IBM | ThinkPad T42 PC Notebook | IBM T 42 - Not starting
IBM ThinkPad T42 PC Notebook
Problem for IBM ThinkPad T42 PC Notebook
By rhalmuthur on Oct 15, 2006
I am not able to start the laptop.
When I switch it on, the lights come on and in a second two lights - battery indicator and the one next to it - stay on...others go off. The laptop does not get booted. Nothing comes on screen.
Have checked the Power Cable, battery. both are fine.
What should I do?
To me it appears it fails after doing keyboard test...
Same Problem
Sep 14, 2008
-   Same problem here with an R50e. I asked my boss if I could take it home. He said yes and I took it home. To my surprise the machine booted and worked for almost two days (with several reboots due to windows updates, benchmark tests, and burn in tests that stress the CPU and memory.) Now the Problem is back.
I guess It has to do with large SMD components on the motherboard that become lose when the motherboard flexes. A known problem
The only thing that starts up are the LEDs and the CPU fan.
I think they are (left to right)
NUM CAPS HDD POWER BATTERY SLEEP.
  • When pressing the power button all LEDs light up. (except for the wlan indicator which is a bit separate)
  • After about a second BATTERY and SLEEP will go dark.
  • After a little more than a second BATTERY comes back. (If I pull the battery and only work with the AC adaptor the BATTERY LED will stay dark after the initial stage)
  • Half a second later NUM and CAPS go out.
  • HDD POWER and BATTERY (if a battery is presend) will stay lit.
You can hear the fan spin up quite a bit so I guess the CPU is running at full speed.
Notes:
The ThinkLight does not work. Usually It does as soon as the BIOS is done with the POST (power on self test).-   henrik-fixya
Feb 03, 2008
-   Hello, I have the same problem with R50e. Did you find any solution Please?-   tpitter
Solution #1
posted on Oct 16, 2006
Somewhat Helpful)
dugiehowsa
Rank: Wiz
Rating: 77%, 871 votes
If the laptop is not even getting to boot the hard drive, then their may be a problem some where on the motherboard and it may need to be replaced.
Before replacing the motherboard, there are a few things you can try.
1) If you have extra memory, try swapping in new memory and see if the laptop boots then.
2) Try disconnecting all peripherals and add-ons and see if the laptop boots then.
Was this helpful?
Yes
No
Popular Solutions for IBM ThinkPad T42 PC Notebook
Questions and Unsolved Problems for IBM ThinkPad T42 PC Notebook
Do you recommend IBM ThinkPad T42 PC Notebook?
Answer
Answer
My wireless connection keeps disconnecting and then keep acquiring for network address but never... (More)
Answer
I cannot type the symbol ? when I strike that key
Answer
HP Pavilion dv9000 used to burn DVD+R, now just spins for 30 seconds and then stops. what changed?... (More)
Answer
How do you know what password you need? Windows starts and then it askes for a password for ibm that... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For IBM ThinkPad T42 PC Notebook:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
