Question about Parrot 3400 GPS Receiver
Parrot 3400 And XDA Orbit
I have just changed my phone to XDA Orbit but when I connect it to my Parrot 3400 the numbers are all blue toothed across to the device but when you click on a letter to search for a contact the phone numbers are not filed correctly under the letters they begin with. Any suggestions.
Thanks Les.
5 Suggested Answers
dancandoit
  • 436 Answers
SOURCE: Parrot Car Kit "no signal" detected problem
No signal is normally a result of the power wires been the wrong way round, disconnect the parrot, check memory and switched live are correct the try the unit again, if it still dont work then it will need new software hard wired into it. Find your nearest Parrot engineer from parrot.com
Posted on Nov 16, 2009
  • 95 Answers
SOURCE: it will not connect
First, try to check into settings -> pair with phone and ensure that you do not have already five phone paired with the kit. If yes, just delete one of the phone. If not, you have most of the time a message on the phone saying "pairing fail" or other.
Check to the phone that you do not have the infrared activated. Does the phone find the kit?
You can also trying to retreive the battery of the phone during one minute and put it on again. The try to pair once again.
You can make a crossing test with an other phone to ensure that the kit is working.
Posted on Mar 29, 2010
dancandoit
  • 436 Answers
SOURCE: I have bought a car with a parrot blue tooth hands
you can download the full user guide from parrot.com/support.
Posted on Jun 19, 2010
dancandoit
  • 436 Answers
you will need to delete any old devices from the memory.go to SETTING / PAIRED DEVICES / move onto a paired device and press the middle button , then scroll down to delete and press middle button, then press green to confirm.
When i try to pair with my galaxy tab s through bluetooth the tab goes through the process of connecting but doesnt pair however my galaxy s5 phone pairs immeditely ?
  • Your issue is that you can only connect one mobile or tab to a blue tooth.
  • It only accepts one device at a time.
  • You need to connect one to your blue tooth in your vehicle and try something like a blue tooth pill or blue tooth speaker.
  • I have had this problem with my Parrot car kit.
  • Hope this helps. Russell
Nov 22, 2015 | Cell Phones
Hi how do i connect my samsung to my parrot blue tooth,im using my sons phone but will be getting a sansung s3,athe moment im using a s3 mini
Try 0000 or 1234 as the pin number or get the pin number from the instruction manual that came with the Bluetooth Car Kit (under "Pairing with your phone").
Hope this helps.
Nov 13, 2014 | Parrot 3200 Ls Color Handsfree Bluetooth...
How can i connect htc p 3400 mobile with sony vio window 7.
you can connect your phone via blue tooth,data cable or infrared.switch on blue tooth of your both devices than let your other device discover your phone.It will ask to connect allow it to connect.
Jan 07, 2011 | Computers & Internet
My nokia 2330 classic doesnt pair with my parrot 3200 ls color. after synchrinsing them unable to get authorisation code
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 16, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
My nokia 5130 will not connect to a parrot car kit. Blue tooth is enabled on both devices but it's looking for additional password. Anyone got any ideas?
additional passcode will be 1234 unless you have a ck3200ls then you will need to go to setting ? advanced settings / pair with phone, then it will give you a code to enter into your phone. try deleting any old paired devices first from the parrot. if this dont work let me know exactly the model number and software version of your phone and parrot.
Mar 04, 2010 | Nokia 5130 Cellular Phone
My Nokio E52 'sees' the CK3000 Evol parrot, but will not connect.
Switched on the E52 the blue tooth option External SIM Modus to On and kept on trying. And then finally the phone asked for accepting the arrot connection. Entered 1234 and it worked.
Oct 12, 2009 | Parrot Par Ck3000 Evolution Ck3000...
O2 xda orbit Screen display problem
hi what u need to do is go on ebay get another screen then go to www.blueunplgged.com and type in the name of your phone like nokia 3410 screwdriver get this screw driver and i will tell you what to do cost of this in all 10pounds or i have the tools to sell you if you would like once you have done all of this E mail me glenroy1112@yahoo.com
Sep 16, 2009 | O2 Xda Orbit Smartphone
Updating my parrot 3400 ls
You can make the proceed using Bluetooth dongle and a laptop or a bluetooth included to the laptop.
Just make a look:
http://www.parrot.com/uk/support/downloads/#software
Jun 22, 2009 | Parrot Ck3400ls Bluetooth Lcd Car Kit With...
Blank white screen xda orbit
The only solution is to format your phone but you will loose all data.
Jan 11, 2009 | O2 Xda Orbit Smartphone
Turning off Blue-Tooth and using phone
there is no another way to off your BT so you have to turn off your Bluetooth and go when u come back then turn on again its automatic connect with your car
May 15, 2017 | Parrot Cell Phones
Parrot 3400 GPS Receiver Logo
26 people viewed this question
Top Parrot GPS Experts
George Merkley
George Merkley
Vladimir Frolov
Are you a Parrot GPS Expert? Answer questions, earn points and help others
