Question about Lexmark X1240 All-In-One InkJet Printer
Scanner all in one center not appearing
It is all sussefully working used the disk but i cannot scan the scanner wizard is all saying tested and fine but if i hold scan button down for 3 secs it prints out a picture of what to do and lots of blue lines please help ive never used the scanner till now and it not working thank you
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 214 Answers
If you have the BLUE LINES on the print out, you have an image quality issue, try cleaning the printhead 3x to resolve problem
Posted on Nov 16, 2008
Brother control center 4 won't open on my computer
This may help others with scanning issues:
I just bought a Brother MFCJ6510 printer/scanner and was nearly driven cracked trying to get the scanner to work as it was not talking to the PC, even though as a printer it was working fine. Realised eventually that it was just the Brother Control Centre 4 it wasn't talking to. After hours of re-installing software and updates, etc, nothing worked.
The solution: I went into Control Panel on my PC (I use Windows XP), to the Scanners and Cameras section, and in there the Brother Scanner was visible and could be used from there, Click on it to open the Windows Scanner and Camera Wizard and use that. Further, by right-clicking on it and going to properties I choose the software to start when it talks to the PC. I abandoned the Brother CC4 and set it up to start the Scanner and Camera Wizard if I choose 'Scan to Image' on the scanner control panel, and to open Photoshop if I 'Scan to File' on the scanner. Works fine either way, just make sure you choose the right dpi setting to suit your needs.
Hope this helps somebody else as frustrated as I was.
Apr 17, 2013 | Brother DCP Office Equipment & Supplies
Perfection 1670 Flatbed Scanner: When I try to scan I get a message saying: "Can...
Do the following:
Uninstall the scanner from your computer
Restart
Re-install all software and drivers with the original CD * if you dont have the drivers check the manufacturars website *
Restart again
And then it should work fine. If this fails use the scanner wizard in Windows Control Panel and follow the step by step instructions.
May 18, 2010 | Epson Perfection 1670 Flatbed Scanner
Trying to scan. The Dell All in One center
For normal scanning you can choose the option of Scanners and Cameras wizard in control panel. But it is better if you have software disk of printer because it contains more option.
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 20, 2010 | Dell 922 All-In-One InkJet Printer
Lexmark x3350-4500 scanner doesn't work
Please follow the steps given below to update the scanner driver:
1. Right click on My Computer and select Properties.
2 Click the Hardware tab and select Device Manager
3. Right click on the scanner entry that is displaying a conflict.
4. Select Update Driver from the drop-down menu that appears. The Hardware Update Wizard appears.
5. Select Install from a list or specific location, then click Next.
6. Select the Don't search... option and then click Next.
7. Click Have Disk. The Install from Disk dialog appears.
8. Click Browse and select the Lexmark CD from the Look in drop-down list.
9. Double-click on Drivers.
10.Double-click click on Scan, select the lxbksxp file, and then click Open.
11.Click OK. The following screen appears:
12.Click Next to start the scanner installation.
13.When the installation is complete, click Finish to close the wizard.
Aug 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
USB NOT CONNECTED ERROR WHEN IT IS CONNECTED
This is a HP hardware/software error and HP has not fixed it.
The C4250 may report that "USB is not connected" but the printer works just fine and when you use the Microsoft Scanner and Camera Wizard to carry out a scan, it works just fine too. So the error message is wrong.
The Microsost Scanner and Camera Wizard can be found on the Control Panel.
May 05, 2009 | HP Photosmart C4250 Multifunction Photo...
Cannot retrieve application list
Apr 28, 2009 | Office Equipment & Supplies
SmarThru Office can't see scanner (nor can word)
Windows is using Window's default scan driver, so it's working only within Windows scan wizard feature. You will need to install the Scan Driver separately to work with SmarThru and other software. The Scan Driver is available at Samsung website.
Apr 16, 2009 | HP PSC 1350 All-In-One Thermal Printer
C4200 - says USB not connected when trying to scan
Mar 01, 2009 | HP Photosmart C4280 All-in-One InkJet...
Scanner on HP6110
I also have this problem. Try going to
-Start
-Programs
-Accessories
-Scanner and Camera Wizard.
I can get my scanner to work through the wizard when it won't work by just pressing the scan button on the printer.
Jul 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanner not working
Please open HP director from Start - All programs - HP .
Click Scan document to scan.
You can scan by following steps :
For Windows XP:
To isolate the issue I suggest you to try scanning from the Windows Image acquisition(WIA) wizard on the computer.
Follow the below steps to Scan using WIA
1.Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2.Click Start then Click All Programs then Click Accessories then Click Scanner and Camera Wizard.
3.Follow the Scanner and Camera Wizard instructions to scan images to the computer.
Waiting for you reply.
Thanks
Dec 22, 2007 | HP PSC 2355 All-In-One InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
70 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
