Question about Hyundai ImageQuest Q995 19" CRT Monitor
Ghosting image after 3 years of perfect operation
After a reboot and install of Linux, first time the monitor came up with graphics it was ghosting (i.e. repeated patterns next to text or images). Rebooted back to WinXP and it's ghosting again. Tried different computers on different locations, still ghosting. Tried different power cable, to no avail. I suspect the data cable but it's attached to the monitor and cannot replace myself.
  • Hyundai Master
  • 4,033 Answers
Ghosting is a memory problem, the monitor has a memory chip this helps with the video rendering to display the image, the chip can over time become damaged like any other memory chip, its its read use delete type but some times it can take longer to delete this then gives you the ghost shadow. it can sometimes be the software glitching, but there is no way to fix the firm wear on the monitor as the chip is pre programed before the monitor is assembled.
Posted on Aug 11, 2017
5 Suggested Answers
SOURCE: I have a Hyundai Image Quest L70S, the screen goes blank
hello, mine lcd it is extinguished continually. I have tried to open it and seems us or a problem on a condenser dell' inverter. Someone you would know dirmi where to find the outline in order to understand like repairing it?
Posted on Jan 31, 2009
  • 152 Answers
SOURCE: Hyundai imagequest Q17 montior problem
ontherhodes5, Your monitor will probably need servicing for one or both power supplys in the unit. Yes, If you can get a new oem Switch-mode-power-supply/inverter board you might get it working. I suspect that it (smps) can't supply the voltages needed by the logic-interface board- therefore no digital data can be processed for display on the screen, which should be white-bright but now only gray. (dim) because the 1000v ac from inverter circuit is also missing 10to40% of it's output. Your best bet will be to find out if Hundai can do a repair/swapout. You send yours+$40 to $90 and they send you a Refurbished same model with new CCF tubes, Inverter board, smps board. It seems that sooner or later these lcd ccf (cold cathode fluorescent tube backlights) will need servicing. Don't feel bad about this monitor. There are about, (guess only) 2500 more of all makes and models with similar power supply problems out there. To see whats inside a lcd search YOUTUBE for vids of servicing or repair of lcd screens or similar.. also www badcaps.net ??? or lcdrepair.us or visit electronicrepairguide.com run by a Jestine Yong. Ignore the sales pitch and just look fyi. hope this was of some help. drop me a note if possible. I'm louie12fix on fixya or lmistyrel@ aol.com BYE
Posted on Mar 30, 2009
HarryHarley
  • 343 Answers
SOURCE: Monitor is fuzzy as if it needs a driver?
Go the the manufacturer's website and download an updated driver for your particular monitor.
You'll find it here
http://driverscollection.com/?H=L91A&By=Hyundai
Posted on Dec 21, 2009
duane_wong
  • 6826 Answers
SOURCE: My monitors are just over 3 years old and I have
The monitor may have a bad inverter or fluorescent backlight problem inside.
Posted on Jan 14, 2011
ACER P223W Monitor Ghosting (Multi-Mon Setup Win8)
Hummmm.... are both monitors connected to the same surge protector?
I had a similar problem with 2 monitors and a Brother Laser Printer (with a long USB cable), where the Brother was connected to a different AC outlet connecting to a different breaker! No fair...
That happened because that 'Brother' outlet was part of a new room addition... and hence a 'new/different' circuit breaker.
Once I connected the Brother to the same surge protector my video problems went away. And yes, the "grounds" are connected properly at both outlets... go figure.
Anthony
Nov 22, 2017 | Acer P223W 22 inch Monitor
Ghosting on DELL 2007WFP
what connection do you use?
if this only happens when you browse web pages with java or dynamic content or when yo play games check in your graphics card drivers that you have not forced anti-aliasing, try also updating direct x
Jul 24, 2008 | Dell UltraSharp 2007WFP Monitor
Acer moniter has streaking and ghosting of images
Sorry, it's a graphics fault. Looks like its time to get a new monitor. Few repair shops will do toch LCD monitors.There IS a possibility that your PC has a graphics problem.You could check it out by connecting your PC to another monitor,or by connecting your monitor to another PC, or a notebook/laptop.
Jun 18, 2010 | Acer V173 b Monitor
Vertical lines and bad ghosting & image doubling
The Nvidea board is going bad - you proved that by using the old one.
Feb 10, 2010 | HP NVIDIA Quadro4 750 XGL (128 MB) AGP...
Ghosting of images and buzzing when on mostly white screen X2gen 19" monitor (HP/Vista )
Please bring the unit to an authorized service center as there's an internal electronic part/s of your monitor that is cold soldered / defective. regards
May 27, 2009 | X2Gen MG19VT 19" LCD Monitor
Westinghouse LCM-22W2 has "ghosting"
Usually, LCD monitor ghosting appears when the cable isn't tight, the cable is faulty, or low quality. The cable should be less than 8-10 feet long. Try using a different monitor cable (they're mostly interchangable) and see if the problem goes away. I'd put my money on the cable or a loose cable connection.
May 13, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Shadows/ghosting is present on screen at all times
What kind of shadowing are you seeing? Doe the picture look like a 3D movire (colors separated)? What is the make and model?
Please update this with the above info and I'll provide possible solutions.
Thanks,
Dan
Mar 20, 2009 | Televison & Video
GHOSTING
go to image revison in menu and try. auto, 0, 1, 2, or 3 for best picture
Jul 05, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Monitor Ghosting
You didn't descibe your problem.If you are seeing double image/ghost first try replacing signal cable.
Samir
Jun 10, 2008 | Computers & Internet
Card seems to be defective - slow, reboots, fails on resolution change
If Windows is continuously loading up to 800x600 then your drivers are not being installed. Are you using the the 169.21 Nvdia Forceware package? What OS?
Jan 09, 2008 | ASUS N6200/TD GeForce 6200 AGP 256MB DDR...
Hyundai ImageQuest Q995 19" CRT Monitor Logo
Top Hyundai Computers & Internet Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
 steve
steve
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
