Question about Mitsubishi VS-55601 55" Rear Projection Television
Cant get the tv to power up
No power up. The tv makes a "click" noise when pluged in , but fails to power up when the "on" button is pressed. Also tried with the remote with no luck.. Removed the back panel to inspect for possible blown fuse. Replaced the visual ones and still no response from the power switch. - Inspected the power cord... no irregularities - double checked the outlet, all is functional - Inspected the rear panel with board cover removed, and plugged in the power cord and tried to pinpoint clicking noise. seems to get power, but fails to power-up by either the front power-on switch or the remote. Question....? Is there any special fuses that burn out that are not visually acccessable with rear board off? John H
  • 3 more comments
  • JARGON Nov 25, 2007
    WHEN I PLUG UP THE TV AND HIT THE ON SWITCH THE TV BEGAN TO FLICKER AND CLICK AND THE SMELL OF SOMETHING BURNING COMES FROM THE BACK. NOT SURE OF WHAT TO DO.
  • tomster Dec 03, 2007
    have a mitsubish 55601...1998...55in...when powering up manually or w/remote it clicks on...green ON light appears for 1 sec and then the tv powers off by itself...when doing this the screen remains blank.
  • Anonymous Feb 02, 2008
    having the same problem with my model VS 55601 what can I do to solve the problem.
  • Anonymous Jul 06, 2008
    green light goes for 1 second then turns off
  • little_rew Jan 10, 2009
    turn the vs 55601 on, it clicks and then turns off.
I'm having the same problem. No power at all, tv was working fine and shut off by itself WS-65517. Please help!
Posted on Mar 27, 2008
SOURCE:
Tv just makes a click noise when pluged in
remove the back and look for any swollen or blown capacitors. it sounds like your power board went out
Dec 02, 2013 | Pioneer PDP-6010FD 60 in. Plasma HDTV
Phillips 60pl9220d 37
The power supply may be failing.
Nov 22, 2013 | Office Equipment & Supplies
Visio VP504 fhdtv10a - When I plug it in, it has an amber logo light and makes a click noise (like a relay). When I press the power button nothing happens.
These are problems gradually developed in TV over the years. You may have to look for any dry solder, change the capacitors that look 'puffy' and try.
Jul 30, 2012 | Televison & Video
Hi our tv just won't turn on any ideas? We have pluged it into another power source and checked the cable . the cable is fine. thanks
If it does not turn on then it is usually due to a component level failure on one of the boards. Does the LED at the front blink or just stay on? Does it make a clicking noise like its trying to turn on when you press the power button on your remote? Also please let me know the make and model of the tv. Please provide this info so that I can offer you insights into the cause of the problem and how to fix it.
Sai.
May 28, 2011 | Televison & Video
RCA 32'' TV making a humming noise
sounds like a shorted horizontal output transistor probably caused by the high voltage transformer or hot. it is most likely fixable but it will be costly.
Aug 19, 2009 | Televison & Video
Televison & Video Logo
530 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
