Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Locked card I get a locked card message when I turn on my camera - how do I unlock it?
  • jzirbes Nov 28, 2008
    Camera keeps stating memory card error
    Problem Solver:
  • 9 Answers
Pull out your memory card, and find the little gray slide switch, if it is away from card connection it is locked, slide switch (little gray slide switch) toward the card connection. This will unlock your memory card.
Posted on Nov 26, 2008
Get card locked message when I turn camera on. Can't turn the message off,\.
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 14, 2012 | Samsung SL35 Digital Camera
I have a card locked message
You need to unlock your card. If you take the card out of the camera you will see a little notch on one side of the card. Move the little notch and your card will be unlocked. The reason for the card being able to be locked is so that if you have important stuff on there you can lock it so nothing can be changed.
Aug 26, 2011 | Canon PowerShot SD960 IS Digital Camera
When i turn on my DSC-W310 camera it says memory card is locked. So I cannot take pictures or find a way to unlock the memory card. How do i fix this?
Here is a tip that I wrote about SD Cards and how to unlock and lock SD Cards.
If you are getting a memory card locked message then check this out.
How to Unlock SD Card
heatman101
Oct 09, 2010 | Sony Cybershot DSCW310 Digital Camera
I am getting a "card Locked" message
Remove the SD Card from the camera. On the side of the card is usually a gray colored slide. The slide is probably in the lock position and you simply slide id down usually to unlock it.
Check this and re-insert card and turn camera on. If the card IS unlocked it is possible the card slot or the detection circuit is not working.
May 04, 2010 | HP Photosmart M517 Digital Camera
Camera message says 'card locked' how do I unlock
There is a slide switch on the side of the card...move it to the unlocked position.
Sep 10, 2009 | Cameras
CARD LOCKED
Pull the card out of the camera and slide the tiny slide switch on the card to the other position. All the SD-type cards that I have met have this lock on them.
Jun 27, 2009 | Samsung BL103 Digital Camera
I attempted to unlock a 1.0 gb camera card today which has been locked. After attempting to unlock it using a utility knife (since the lever was missing) I gave up after trying to load and reload the...
Hi there.
Turn the camera on and go into the setup menu, look down the list for "reset" and reset it, then try another camera card.
Please post back the results.
Good luck and thanks for choosing FixYa!!
May 27, 2009 | Canon Cameras
Locked memory card
Your camera is telling you the lock switch on the card is locked.
Take the card out of your camera and look on the side. There will be a little switch. One side of the switch says locked and the other side says unlocked. Move the switch from the locked position to the unlocked position and it will work for you.
Rob
Mar 09, 2009 | Canon PowerShot A620 Digital Camera
Card Locked Message
On the side of the SD card there is a slide button that has 2 positions, locked, or unlocked. Somehow it got slide to the locked position
Jan 22, 2009 | Vivitar ViviCam 5386 Digital Camera
Card Locked
remove the memory card out of your camera and look to the side of it.. there is a little switch on the memory card that locks the card... try that first it might not be your camera... :) good luck :)
Nov 04, 2007 | HP Photosmart R707 Digital Camera
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
129 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
