Question about Philips Pocket Memo 9450 VC
Dictaphone does not turn on
When connecting the dictaphone to my PC the display screen does not turn on, despite moving the on/off switches etc. My computer also does not recognise that the dictaphone has been connected. It seems that the dictaphone is nonresponsive &"dead" for all intents and purposes. Has anybody come across this problem?
  • 145 Answers
There is a small hole in the back of the unit. This activates the firmware update. My experiense is someone pushed this in with a pin and caused the switch to be stuck. You can disassemble the unit and use a pin to pry the bubble switch up or off. This switch is only needed to update the firmware which can also be done thre software so is not needed.
Posted on Jan 01, 2009
SOURCE:
My PC wont detect my dictaphone
Please refer to page 15 on this user manual to ensure you follow the correct steps to connect the dictaphone to PC using USB port.
http://www.olympus.at/site/rmt/media/consumer/pim/_manuals_aw2010_/VN-8700_8600_8500_PC_MANUAL_EN..PDF
Jun 27, 2014 | Olympus VN-8600PC Dictaphone
LG HDTV Monitor Permenantly switched on but no display white screen with V.2.0.0 moving around the screen
sounds like you are possibly over resolution (setting resolution higher than the monitor can show. Try setting to low resolution and see if it shows up. Try VGA first and move up if it shows.
Jun 21, 2014 | LG Flatron N1910lzbf 19 Led Lcd Monitor 43...
It worked beautifully last night with my macbook in a test run of my powerpoint, but this morning I plugged it in for the REAL presentation it didnt work. A bright, clear picture of the Viewsonic Logo...
you might need to turn off your computer .
then connect the data projector
and turn on data projector
then turn on computer
hopefully it detects the data projector is connected and switches windows to duplicate projection
On my P.C. F4 key in windows Switches the display manually to duplicate, alternate screen or pc screen only or projector screen only.
As I am not familiar with Apple this support article below might explain the switching of display outputs available on Apple Mac.
https://support.apple.com/en-au/HT202351
Mar 23, 2017 | ViewSonic PJ458D DLP Projector Multimedia...
I want to transfer files that were recorded on a dictaphone on to another dictaphone to play. How do I do this? The files are the same format and when I move them the dictaphone doesn't have them to play
Can't you simply take the tape from the 2750 and put it into the other Dictaphone to play it? Or is the other Dictaphone a different size tape (eg; mini or micro)?
Aug 24, 2010 | Dictaphone 2750 Desktop Cassette...
Dictaphone transcriber 3750 won't play, reverse, or go forward. What can I do?
Does anything show up on the display? Like 'No Cassette' or 'End Tape'?
Are you using a foot control? Does the tape move when pressing the buttons on the machine itself? Is the foot control plugged into the side of the machine (and NOT the back)?
Feb 18, 2010 | Dictaphone 3750 Desktop Cassette...
I have a dictaphone Smart 7120 and I can't get it
I've never encountered that problem, but the manual says: Make sure remote Transcribe indicator is extinguished. Move the Transcribe switch to Local position. Locate letter to erase with either [Prev. Ltr] or [Next Ltr]. Simultaneously press [Currnet Ltr] and [Erase] buttons to erase letter appearing in Item Status display. A tone plays and Erase LED lights briefly. Letter is automatically deleted.
To erase all Transcribed Letters: Make sure "In Use" Transcribe indicator is extinguished. Move Transcribe switch to Local position. Simultaneously press the [Finished Ltrs] and [Erase] buttons. Tone plays and Erase LED lights briefly. Good luck!
Do you know how to determine the total minutes on the machine? I have 2 that I want to sell, one of which is on eBay. Thanks.
Jul 09, 2009 | Dictaphone Office Equipment & Supplies
Dictaphone 2740 desktop.
Try another cassette. There is a tab on each side of the back edge of a tape which when removed will prevent most machines from going into record. If the tab is there (and not bent in), then the switch at the back of the cassette compartment is dirty or out of adjustment. If you can find a manual for the 2740 (try at www.nuance.com, they bought Dictaphone), it will show how to change the Letter display back to a timeline. Good Luck.
Sep 09, 2008 | Dictaphone 2740 Desktop Cassette...
Dictaphone 2740
More than likely then the drive belt is broken or the motor is bad.
If you press the reset button the 88.8 flashing should go to 00.0.
If you are sure the tape is good, there is also a switch at the rear of the cassette compartment to detect if the record prevention tab is missing from the cassette itself. If the tab is in the cassette, the switch could be dirty or out of adjustment.
Aug 14, 2008 | Dictaphone 2740 Desktop Cassette...
No Resource Upgrade resource agan
ok, so u formatted your player, hence the green screen. So now all you have to do is download the firmware(match your player, sl with sl firmware, etc) then extract w/ winrar, u get 2 files so put them both in root folder (displaying music, video, etc) unplug turn off, on it will update then wait few min till it turns off, then turn on and ur player will work.
May 08, 2008 | Meizu Mini Digital Media Player
342 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
