Question about Whirlpool AWZ410 Front Load Washer/Dryer
Jammed door my door jammed today. put the washing in selected the cycle and switched it on and it popped and all the power went out of it and now the door won't open. No one can come out until next week as we went and has to go through the estate agent. It has all my work clothes in it for next weel Help me please
  • lemonjelly84 Nov 06, 2008
    help
  • Anonymous Mar 29, 2014
    The open button is not work. What to do next? IN English please
Turn it off all the way and its automatic timer will release after about 3mins
Posted on Dec 21, 2008
Indesit DIF04UK: Help with problem determination please?
Modifying a wash cycle in progress:
If a mistake was made during the wash cycle selection process it is possible to change the cycle, provided that it has only just begun: open the door, taking care to avoid the escaping steam, and press and hold the ON/OFF button; the machine will switch off with a long beep. Switch the machine back on using the ON/OFF button and select the new wash cycle using the SELECT WASH CYCLE button; start the cycle by closing the door.
Dado
Sep 08, 2014 | Indesit Dishwashers
I went to use it today and it wasn't working properly. i set the laundry in, put in the detergent, closed the door and then deposited my money and selected the cycle. the machine ran for 1 minute then...
yes, your guess is most likely correct. Problems on the water supply into the drum of the washing machine. you can check the start of the tap water, hoses and water inlet valve Selenoid. Hopefully help.
Aug 18, 2010 | Maytag MAH21PDD Commercial Front-Load...
Door popped off my Krups FME4 drip coffeemaker.
Just had the same problem today so I thought I would share with you how to fix it. The spring runs up through the door that opens, pop off the silver top and the wire where it makes a L, lock it into the top and put the silver top back on. The switch on the right is only to hold the door open. Good luck.
May 06, 2010 | Krups FME4 Coffee Maker
Hotpoint WMA33 washer - door won't open
Problem seems to have corrected itself! I tried another slow spin cycle, waited a reasonable interval for the Door Locked light to go off, then when it didn't I switched the power to the machine off. I tried squeezing the door catch a few times and pressing the door downwards, then left it. Some time later when I went into the kitchen the door was open. I washed a small load this morning and the machine worked normally. Fingers crossed, it's ok now.
Oct 07, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Brand NEW Whirlpool Duet Sport
After six failed attempts by your machine to lock the door F22 flashes.
Causes & Procedure:
Door lock mechanism is broken or removed from door.
Door switch or door unit failure.
1 Unplug / disconnect washer.
2 Check door switch lock unit.
3 Check wire harness connections to door switch/lock unit & the
Central Control Unit (CCU)
Fault 22
Push the door to make sure it is locked firmly (try some WD40 on the door mechanism on machine, not on door, to ease out any lock jam & try the door open/close with the power off the wall) I'm giving you tips to avoid the so-called techs zooming for your wallet.
Fault 28
The communication between the CCU & the MCU (motor control
unit cannot be sent correctly.
1 Unplug washer / Disconnect power
2 Check wire harness connection to the MCU, the motor & CCU
Check communication of the CCU board within the housing.
Make sure all grounding switches are engaged.
3 Check the drive system for any worn or failed components
4 Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
5 Verify CCU operation by running the Diagnostic Test or any
cycle after plugging in.
Will try getting back re the door lock. Desperate i know, so am i.
Mar 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet washer showed F22 error; we followed manual instructions; disconnecting power, etc. but door remains locked and washing cycle won't restart. Help!
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door jammed
take the top off the machine,put your hand down to the reigon of the door lock and by using a small screw driver the catch on the door can be forced open without doing any damage.
Jul 24, 2006 | Indesit W 123 Front Load Washer
Whirlpool AWZ410 Front Load Washer/Dryer Logo
137 people viewed this question
Dan Webster
Dan Webster
Sal De
