Thermostat wont turn on heater Robert Shaw 9600 prog.
I had this trouble 2 years ago. . . . Air, blower work fine, when I turn on "Heat" it clicks a couple of quick times and wont start up the furnace. The system is only 5 years old .( i believe it was installed in july of 2004 , furnace, a/c lennox)
I've replace batteries and "reset" several time thinking the batteries were too low to start it up.
The thermostat was replace 2 years ago and now its doing it again. Any suggestions other than having to get them back out here would be helpful. Thank you .
  • Anonymous Dec 20, 2008
    I had issues determining what color the "common" wire was. I have a red, white, yellow and green. Between the white and red i get .10-.70 volts - between the yellow or green and red I get 28 volts.
    So does this mean I need better batteries - the instructions say "energizer" - but if this is the case - does it mean it is not my furnace?
    I can hear the unit buzzing atop the roof. But inside to air blows unless I turn the "fan" position to "on". - Then of course no heat comes out.
  • tomtom09 Jan 06, 2009
    Hi
    Please I don't speak English too much, but I have a problem with my heater at home, the unit is at the top of roof.
    My heater was working good in automatic position, in this moment from 2 days isn't working. If I connect aircondition work good, if I connect fan is working good too, but when I change to heater then don't work.
    Right now my home have 32 degrees.
    I don't know anything in this problem, maybe is the thermostate, some friends they say the problem is in the light to fire the gas at the roof.
    Ones again escuseme my English, but I can read more, I'm in Las Vegas Nevada.
    Thanks everybody.
    Tom
I have a thermostat 9600 Robertshaw and I have to use the trip switch to start my furnace. Then it reaches the temperature and sometimes it will kick in by itself but majority of the time I have to trip it. I have changed the batteries cleaned the thermostat,and reset it. Is it time for a new thermostat and can I replace it myself. Thanks
Posted on Jan 16, 2009
    Novelist:
  • 124 Answers
Look under the cover where you change the batteries. find the common and the white wire. if you have it in heat and there is 24 volts batween w and common, then the stat is good and the problem lies in the furnace. checking in the furnace the power should arrive at the furnace control board or the common and white as 24 volts also. first to start is the forced draft motor, 120 volts. next the glow bar , 120 volts or ignitor arcs and then gas burner lights and heats up then the blower runs . whatever item fails to perform is your problem . check with meter where possible and if power goes in and item doesn't perform thats your problem. when the forced draft motor runs it closes a pressure switch usually to the upper right and then the board knows it can proceed to power glow bar or ignitor and light burner then open the gas valve for ignition. good luck
Posted on Nov 07, 2008
Eb20b/ electric furnance/ blower wont shut-off after heat kicks out, got to kill breaker , runs all the time, installed new thermostat, no change?????? Its cold??????
Check the thermostat and make sure the fan switch is set on "Auto". If it is set on "ON" the blower will run constantly.
Jan 31, 2015 | Heating & Cooling
WHITE ROGERS THERMOSTAT
Hey, did you ever figure out how to fix this?? Mine is doing the same now.
Dec 02, 2012 | Shaw Robert RS-9420 Thermostat
Repair robert shaw hot water heater gas valve I have a gas hot water heater with a robert shaw gas valve on it. I get no gas when i push on the red pilot button for lighting. I would like to fix it verses...
Yes you can get rebuild parts for the gas valve. You can go to partsguy.com to order them. Yo can also replace the whole valve for around $80.00.
Hope this was helpfull for you, let me know.
Thanks ,Matt
Dec 10, 2010 | Shaw Robert RS-9420 Thermostat
No display on Robertshaw 9600; unit seems dead/furnace works
have you checked to make sure you have a fresh battery in it
Jul 25, 2009 | Shaw Robert RS-9420 Thermostat
Error code on robert shaw 9600 thermostat
i am having a ER on my shaw robert theromostat model RS-9420
Jun 30, 2009 | Shaw Robert RS-9420 Thermostat
Can not get the heat to work only cold air
Two questions what brand heater and what are the wire colors at the t-stat
Jan 04, 2009 | Hunter Fan Company 5/1/1 Programmable...
Goodman gmnt100-4b wont ignite
listen for the gas valve to click on,,,if you do not hear it clicking on u could have bad gas valve,,,if it is smart valve which was around about 4 years ago they had major troubles and most where dead on startup. if it is clicking on than you might have something in the pilot tube or moisture in the valve,,try banging on the valve some ,,sometimes that will break it up and let it flow past if do right after it clicks in..might have to pull the pilot tube and blow out,,,sorry just dont have enough info at moment for lock down diagnoses,,good luck
Oct 22, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
2,991 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
