Question about Acer Aspire 5500 5570-2609 Laptop
Windows fails to start and startup repair does not work.
I was downloading an update for Adobe Acrobat and system crashed.I can't get to the windows start screen and after trying 'startup repair" I get an application error(failed to initialize).The repair screen and error message continue to loop. Help
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    Have you tried to boot in Safe Mode?
    Tap F8 repeatedly when it begins to boot. Try to boot to last know good configuration. If that fails, try it again, this time try to boot to safe mode.
    Guru:
  • 859 Answers
Your startup repair option in Windows Install indicates a hardware conflict. Go to your System Setup in startup mode, by pressing Del, F2 or F10 whichever the hint is on screen during bootup. Once inside system setup, turn off almost everything, disable Speed Stepping in EPower, set monitor off to disable, Standby and Hibernation off as well. Turn off the modem and Network adapter if yo can. Just about everything that affects a device on the laptop. This would also include the Touch Pad if you're using a mouse.
And, in the long run, you may need to do a full Windows Install if the repair option continues to fail. Many of these failures are due to the Virtual Memory file size for Drive C being too low. If you can get into Safe Mode change this setting, right click My Computer, select Properties, go to Advanced, advance and change Virtual Memory on C to a fixed size about 1024Meg for min and max.
Also, should you be low on free space for drive C this could cause the same problem. You would have to choose a Full Install as an Option unfortunately.
In the absence of anything along these lines working, you should be able to choose Restore Acer option (or words to this affect), you would want to tap on F8 while booting, sometimes its F10, but this gives you a 'boot from what source' option, CDROM, Hard Drive or Restore Partition. Choose the Restore Partition and start over from scratch again.
Sorry, but this often happens and you and I have to live with this.
If you need any clarifications on what I've just stated, use the Comment Box Text Entry box below to send me a message. I'll get an email alert and will get back to you as soon as I can.
Regards,
Worldvet
Posted on Nov 08, 2008
When opening any pdf file internet explorer gets stop working and browser restart. Reader.exe faulty module
Check for any updates and optional updates in control panel.
Run Windows Update in Windows 7
Using Windows Update in Windows 7 keeps your laptop and desktop computer safer.
Microsoft periodically releases updates and security fixes.
By loading these updates, you are keeping your Windows computer safe from viruses, spyware and malware.
With Windows Update, you have the ability to download updates and choose when to install, automatically have updates applied, check for updates only and/or never check for updates.
Click "Start," "All Program" "Windows Update."
Alternatively, you can click the "Start" orb and type Windows Update in the instant search box.
Windows Update appears in the list for you to choose.
Click "Check for updates;" it is located on the left hand-side of the open window.
Windows 7 begins checking for updates.
They are categorized as important and optional.
Click the "Important Update" link and choose all that apply.
Once you are finished choosing your important updates, click "OK."
Click the "Optional Update" link and choose all that apply.
Click "Install updates."
Windows 7 downloads your updates and installs them.
A reboot of your computer is required once the update process is complete.
You might also try this for IE 7 not sure about IE 9
Fix Adobe Acrobat or Reader 9 Crash on Internet Explorer 7 Problem
Adobe Acrobat and Adobe Reader 9 enable the computer to view PDF files.
These applications also install an add on, or plug in a small software that adds extra features to a programto Internet Explorer 7, enabling IE7 to load PDF files from within the browser.
If conflicting add-ons are installed to the browser, or if the Adobe Acrobat or Adobe Reader software is not properly installed, however, IE7 will crash whenever it attempts to load a PDF.
Open Internet Explorer.
Hold down "Alt" to show all of the toolbars.
Click "Tools" from the menu bar.
Click "Internet Options."
Go to the "Advanced" tab.
Click "Reset" to revert the Internet Explorer 7 settings to default.
Click "OK."
Restart Internet Explorer after resetting the browser.
Return to the "Tools" menu and click "Manage Add-ons."
Wait for all of the add-ons to load in the right pane, then look through the list to find the add-ons labeled "BHO" or "Browser Helper."
Click each add-on with "BHO" or "Browser Helper" in the name, then click "Disable." Restart IE when finished.
Download the Adobe Acrobat or Adobe Reader 9 software from the Adobe website, if you do not already have the setup program on your computer or on disc.
Click "Start."
Click "Control Panel."
Click "Programs," then click "Programs and Features."
Scroll to "Adobe Acrobat" or "Adobe Reader 9."
Right-click the program. Select "Uninstall" from the context menu.
Follow the onscreen directions to remove the software from the computer, then restart the PC.
Log back in to Windows and click "Start."
Click "Computer."
Navigate to the folder where the Adobe setup file is saved or insert the Adobe Acrobat CD.
If the file is saved on the computer, double-click the file to launch the installer.
Follow the onscreen prompts to reinstall the plug-in to Internet Explorer 7.
Restart the PC when the installation is complete.
Open Internet Explorer 7 after booting to Windows.
Open a PDF file from within the browser to test the browser.
http://kb2.adobe.com/cps/331/331025.html
Dec 10, 2013 | Computers & Internet
Excel gives error "compile error" excel 2007
There are a bunch of compile errors.
Here is the most common since you did not include the entire error...
This problem may occur when the following conditions are true:
  • The Microsoft Office Startup folder or the Microsoft Excel Startup folder contains either or both of the following Adobe Acrobat PDFMaker add-in template files: Pdfmaker.dot
    Pdfmaker.xla
  • Norton AntiVirus software is installed.
Method 1: Download the latest version of the add-in for Adobe Acrobat 5.0 loadTOCNode(2, 'resolution'); To obtain an updated add-in for Adobe Acrobat 5.0, visit the following Adobe Web site: http://www.adobe.com/products/acrobat/update.html (http://www.adobe.com/products/acrobat/update.html) Note Microsoft does not support downloading and installing add-ins from the Adobe Web site. If you need help, you must contact Adobe Technical Support. uparrow.gifBack to the top Method 2: Move the files loadTOCNode(2, 'resolution'); Move the Pdfmaker.dot file and, if present, the Pdfmaker.xla file from the Office or Excel Startup folder to a different folder on your hard disk. For example, you can move the files to the My Documents folder.
To have us move these files for you, go to the “Fix it for me” section. If you would rather fix this problem yourself, go to the “Let me fix it myself” section. Fix it for me loadTOCNode(3, 'resolution'); To remove these files automatically, click the Fix this problem link. Click Run in the File Download dialog box, and follow the steps in this wizard.
Fix this problem
Microsoft Fix it 50303
Note this wizard may be in English only; however, the automatic fix also works for other language versions of Windows.
Note If you are not on the computer that has the problem, you can save the automatic fix to a flash drive or to a CD, and then you can run it on the computer that has the problem. Let me fix it myself loadTOCNode(3, 'resolution'); Note Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
To remove these files yourself this, follow these steps.
  1. Click Start, point to Search, and then click For Files or Folders.
  2. In the Search for file or folders named box, type pdfmaker.dot pdfmaker.xla.
  3. In the Look In box, click the disk drive where Windows is installed, such as C:, and then click Search Now.
    The Pdfmaker.dot file is located in one of the following folders:
    • C:\Program Files\Microsoft Office\Office\Startup (Word 2000)
    • C:\Program Files\Microsoft Office\Office10\Startup (Word 2002)
    • C:\Documents and Settings\User Name\Application Data\Microsoft\Word\Startup
    The Pdfmaker.xla file in located in one of the following folders:
    • C:\Program Files\Microsoft Office\Office\Xlstart (Excel 2000)
    • C:\Program Files\Microsoft Office\Office10\Xlstart (Excel 2002)
    • C:\Documents and Settings\User Name\Application Data\Microsoft\Excel\Xlstart
  4. In the Search Results window, right-click the file for each file that is found, and then click Cut.
  5. On your desktop, right-click the My Documents folder, and then click Paste.
uparrow.gifBack to the top Method 3: Visit the Symantec Web site for Norton Antivirus information and product updates loadTOCNode(2, 'resolution'); To resolve this behavior, visit the following Symantec Web site for more information and product updates: http://www.symantec.com/support/index.jsp (http://www.symantec.com/support/index.jsp)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2010 | Watches
Got window that said update Adobe. Ran it and
This depends on your operating system. you may need to upgrade to service pack 2 or 3 if you have a microsoft operating system such as windows xp,vista. go to www.microsoft.com and search for service pack 2 or 3. You can download it there. or click on the start in the bottom left corner of the screen, click on control panel then click on security, click on updates and click install updates. Your system could be slightly different from these steps, but should be close enough so you can do this.
May 26, 2010 | Adobe Acrobat Reader 3.0 for PC/Unix/Mac
Cannot complete uninstall of adobe acrobat 9 pro.
here is a link from adobe's website, this will help you completely remove the product.
http://kb.adobe.com/selfservice/viewContent.do?externalId=kb400654&sliceId=2
Apr 12, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
Cannot use reader 8.0,cannot remove it or install 9.0
oddly enough, you may find that updating the version 8.0 you have to 8.x will then allow you to remove it (or it will work correctly) can you open the reader manually in the programs list? if so open it, then go to help and check for updates. apply the updates. If they work you should be in good shape.
Dec 24, 2008 | Dell Dimension 8400 PC Desktop
Can't update Acrobat Reader
Go to the following link and you can find the update versions all the way back to 6.0
http://www.filehippo.com/download_adobe_reader/
However the versions after 7.0 are described in the technical specifications tab for each version as not compatible with all Windows OS versions, only Windows 2000/XP/2003/Vista/XP64/Vista64.
It seems you may not be able to update, sorry.
Nov 16, 2008 | Adobe Acrobat 6.0 for PC
Adobe 8
uninstall adobe from add and remove progremes and reinstall adobe from
http://www.download.com/Flash-Player/3000-2378_4-10001055.html
Jun 09, 2008 | Computers & Internet
Acrobat Reader 8.1.1 cannot be uninstalled
ok..go to control panel, and remove ALL of the Adobe reader products, and start again.
got backup for that HP?
Feb 20, 2008 | HP Pavilion dv5020us Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
93 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
