Question about SanDisk Sansa e250 MP3 Player
E250r memory expansion
What is the biggest capacity can I add for memory expansion?
  • 80 Answers
The bigest is 2 GB micro sd
Posted on Nov 15, 2008
Installing additional memory into my Jitterbug smartphone--How do I do it?
Per the Jitterbug Smartphone manual, on page 124:
https://www.greatcall.com/docs/default-source/pdfs/jitterbug-smart-user-guide.pdf
Adding more Memory Your Jitterbug features a microSD expansion slot to add up to an additional 32 GB of memory. The following is how to add more memory:
1. Remove the Back Cover using the Back Cover Release notch found on the bottom corner.
2. Locate the microSD expansion slot, which is below the External Speaker, and carefully insert the microSD card into the expansion slot until it clicks into place.
3. Replace the Back Cover.
IMPORTANT! Do not remove the SIM Card located opposite of the microSD expansion slot. Tampering of the SIM Card may cause issues with connectivity to the GreatCall network.
May 19, 2017 | Cell Phones
How do i add more space?
This device does not support memory expansion. I'm afraid the capacity is limited to the amount that came with the player.
Apr 17, 2011 | Philips GOGEAR SA6045 MP3 Player
It does not recognize an 8gb sd card in storage expansion.
Your netbook should read SDHC(over 2 GB capacity) memory cards. The problem might be either the card slot driver, Which you should download if a newer one is available. Or in case you format the SD as DOS then it will only have around 2GB of space, You should format it as DOS32 or NTFS so you get the full capacity for the SD card. Some pirated rather cheaper memory cards have a lower actual capacity. With some compression technique the capacity presented is higher than it actually is. If you format it then it will show the real capacity. hope that is not the case!
Good Luck!
Nov 24, 2009 | Acer Aspire One Netbook 8.9" Notebook
I took 18 pictures and the display is saying FEE I cannot take anymore pictures what does this mean?
Need more information..
.. memory capacity, internal and/or expansion (cards), file size/resolution of the pictures....
I would suggest that the memory is full, and the solution is to transfer the 18 photos to your computer and clear out the memory, or add more memory.
If you have an expansion card installed, maybe you need to tell the camera where to store the photos.
Oct 30, 2009 | Cameras
Problems adding memory to e250r
If your firmware is version 1, the largest you can use is a 4Gb card. You need version 3 firmware to use cards up to 16Gb. To check your firmware version, go to Settings>Info.
Jan 17, 2009 | Electronics - Others
Added 2gb micro card
The player can read the card, but it is not going to add more memory space to the player. The function of the card reader is to enable your player to play songs that you otherwise couldn't play because the hard drive is full.
-Tha Mp3 Doctor
Dec 27, 2008 | SanDisk Sansa e250 MP3 Player
What is the biggest memory card I can use in my aiptek AHD200
THis is the maximum size of memory card that you can use for this camera ,SD Expansion up to 32GB (SDHC)....
Nov 10, 2008 | Aiptek Cameras
I have an rca "pearl" with a micro sd slot, what is this for? i put one in and gained no extra capacity for songs, so is it a backup or what and how is it supposed to work?
sir, micro sd slot is a expansion memory of your mp3. like if you dont have any bytes left on your mp3 and you want to add another songs then sd memory card will be the option. so that you can listen a songs from your mp3 internal memory and micro sd memory card. by the way micro sd is cheaper than any other memory card selling in the market.
thank you for using fixya
CHARCOIS
Oct 24, 2008 | Audio Players & Recorders
Want to konw my memory capacity Serial NB24A 310 55747 Model 4530GZ
Gateway 4530GZ Notebook
Memory type 333 MHz DDR RAM
Memory expansion options Two 200-pin industry standard DDR-SODIMM sockets
Accepts two 333 MHz DDR RAM memory modules in memory bay
2 GB maximum system memory
Oct 23, 2008 | Gateway Computers & Internet
4 GB micro sd and the Sandisk Sansa e250R...
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
118 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
