I have an R11xx radar the display turns bright green with vertical line on it. You can still see the targets but it stays Bright green
Captmarkr1 if you are not able to fix your display and you consider buying new, I would be interested in buying your open array scanner to repair mine.
Posted on Feb 20, 2009
Please connect your laptop to an external monitor and see if the output is the same. If it displays fine on the monitor, then we are looking at either a screen cable problem or a screen problem. If the display is the same as on the laptop, then it is a problem with the display adapter on the mother board.
All the best.
Jan 14, 2010 | Dell Inspiron 1525 Notebook
Bright green vertical line down Compaq Presario C500
Sounds like the display is going out and may have to be replaced to solve the green line problem.
Oct 12, 2009 | Compaq Presario Notebook
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Jul 05, 2008 | LG Studioworks 552V 15" CRT Monitor
I no longer get a bright display. The display stays on dim even when I switch to bright. I cannot see the screen at all during the day.
could be bad LED's inside, loose led screen or a problem occurring with the BRIGHT/DIM switch. if possible take to a tech center. radio shack, or circuit city.
May 06, 2008 | XRS 9330 Radar Detector
spay a can of freeze on the vertical ic while it happens if not that ic try others.
i found this on a different page
his set could have a few probems. One common problem on alot of mitsubishi big screens is the surface mount capacitors on the doubler module go bad, but usaully the set stays on but does not have any sound or picture. It is most likely a problem in the vertical. If there is no vertical sweep seen by a certain protection circuit, it will shut down the set to protect the picture tubes from having a line burned into them from just a single intensely bright line being displayed. I have had many a mitsubishi have pico fuses open randomly in the 26 volt line for the vertical and when replaced the set operated normaly. I also had bad solder connection on the vertical output I.C's causing them to short out and open the same pico fuse. There could be oher factors but those are 2 of the most common ones I see. Without actaully looking at the set thats the best I can do. I would say its well worth getting fixed..
Oct 27, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Vertical lines and purple artifacts when the camera is aimed at bright subjects
Current LCD display technology can reproduce about 300 different levels of brightness. Brightly lit scenes or light sources may exceed this brightness range, causing a temporary disruption (artifacts) in the live display. Artifacts are part of the display, but they are not part of your recorded image. If you take a picture while you see artifacts on the screen and then display the picture on the LCD, you will no longer see the artifacts.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
