Question about Aiwa CDC-MA01 CD Player
Aiwa CDC-MA01 can't change station
The buttons below the main display in my Aiwa CDC-MA01 no longer work. They don't do anything. Since these buttons are in a moveable pannel that moves every time the radio is turned on or off, I figure that the movement (the radio is about 4 years old, so it's been through thousands of cycles) has finally broken some of the connecting wires between this moveable pannel and the main chassis. Question: Anyone know if this is likely to be repairable by a technically savy end user? [I'm more than technically savy, I'm a degreed EE and have FCC radio licenses ... both amateur and commercial. But flex cables, etc., can't really be fixed and must be replaced. Wire cables, however, I can probably fix. Soldering is not a problem. I have not yet removed the unit or taken it apart.]
Same thing, some of the buttons on the bottom flip panel work, the important ones do not. select is the most important one that does not function. I opened the unit up and checked all the connections, the ribbon cable seemed to be connecting, i can only conclude it is chip thing, as the switches under buttons rang the bell on my continuity tester. it is very easy to open up and put back to together.
Posted on Jan 23, 2007
I have a CDC-X504MP. How do I get the fade control. I was in the truck when I bought it. Works great.
To get to the sound settings: Press and hold the Volume knob down. Press the "Seek" button until you see "Fad" on the display It will be between "Bal" and "LPF" Turn the volume knob to adjust
Jul 23, 2011 | Aiwa CDC-X504MP CD Player
I need a user manual for CDC-Z137. I don't know how use AUX and time setup.
A pdf version of the manual can be downloaded from the link below. Scroll down to the bottom of the page and enter the code and select "download." Once you select download it will make you wait 30 seconds, but it will start after the time has elasped.
http://www.nodevice.com/user_manual/aiwa/cd_receivers/cdc-z137.html
Apr 17, 2011 | Aiwa CDC-Z137 CD Player
Hi Folks, I have an Aiwa CDC x204 car stereo that seems to be stuck in demo mode. I replaced the battery, so my guess is that this is the default. Upon reading the instructions, it indicates to...
This is what worked for me:
  1. Power the radio off (hold the power button in top left corner in for several seconds)
  2. Remove face plate
  3. Hold in reset 10 seconds
  4. Press push-menu dial/button 3 or 4 times
  5. Insert cd and hit source to switch to tuner before cd starts
Not all of these steps may be necessary.
I suspect having the power off before the reset button was the important part.
Sep 15, 2010 | Aiwa CDC-X204 CD Player
The panel will no longer recognize some of the buttons. for example, the source button doesn't work nor the push-menu. the power and eject button still works. How do i fix this?
it is possible ;you may have a bad switch. if you have a multimeter, try checking all the switches. if one or more is less than a few megaohms, it may be bad.
Aug 12, 2010 | Aiwa CDC-X204 CD Player
AiWa stuck on mute - no sound from subs.
have you tried powering down unit and seeing what happens?
Dec 02, 2009 | Aiwa CDC-X227 CD Player
Stuck in demo
I had the same issue and was about to give up.
cleaning, key combos and such didn't work out.
Solved the dirty way, as described some comments above:
"Just took the faceplate from the "push-menu" button and hit it against a hard surface [not too hard but not too soft hits] and thats it, it worked again."
ah, the good manners!
Jun 07, 2008 | Aiwa CDC-X504MP CD Player
Aiwa fm/am compact disc player cdc-x304 face plate
Buy a new radio, you'll never find just the faceplate... trust me on this one it's not worth the headache.
Mar 30, 2008 | Aiwa CDC-X304 CD Player
Aiwa CDC-X304
You can download the manual from the link below: http://www.us.aiwa.com/default.asp?page=ownerManual&action=browse&model=418
Aug 06, 2007 | Aiwa CDC-X204 CD Player
AIWA CDC-X115
Check BOTH of your power connections and your ground too. Make sure you actually have 12v at each connection and don't have a blown fuse etc. If you are lucky then you will solve the problem. Good luck.
Apr 29, 2007 | Aiwa CDC-X115
Won't reset/no input on bottom bar
Yes, the ribbon cable has gone bad on you. It's about 15$ itself and replacing it is easy.
Dec 18, 2005 | Aiwa CDC-MA01 CD Player
Aiwa CDC-MA01 CD Player Logo
126 people viewed this question
Top Aiwa Car Audio & Video Experts
Mike Duncan
Mike Duncan
fordexpert
Joaquim Martins
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
