Question about Sony KLV-S32A10 32 in. HD-Ready LCD Television
Snowy, reddish, weird picture
The picture is snowy, reddish tint to snow, almost a negative image sometimes.
  • 4 more comments
  • Deacon J Nov 07, 2008
    All inputs are effected. The menu and Display look pretty normal.
    I assume this 15 pin VGA connector is inside the box?
    Found it! Thanks!
    I had to borrow a VGA cable and I tried hooking a PC up to the TV. The picture is bad that way, also. So I guess I need to replace the B board to fix this problem? Is it obvious which board is the B board? Where can I purchase the part?
    Thanks for all the great help!
  • Any Guy
    Any Guy May 11, 2010
    Does this happen on all inputs? Does it effect the On screen display and menu as well?
  • Anonymous Mar 31, 2014
    picture is bad
  • 320 Answers
If the menu and OSD are OK, that probably eliminates the panel and TCON board. That still leaves the A3U board which does all the switching and intial processing of the video signal and the B board which does final video process and panel drive. The is one simple way of narrowing it down: hook up a PC to the 15 pin VGA connector (make sure the PC is set for a 60 hertz refresh rate). If you can see the problem when using the computer input, it is most likely the B board. The B board is the most likely cause of video distortion problems. Please be sure to rate this solution. Thanks!
Posted on Nov 07, 2008
  • Any Guy
    Any Guy Nov 07, 2008
    No the 15 pin connector is on the back panel
  • Any Guy
    Thanks for the good rating! It is appreciated!
LG flatron plasma rz42px10 snow screen with sound
Check and replace its tuner. If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 11, 2017 | Televison & Video
Snowy picture
Can you say it does it on all inputs including DVD etc?
Snow in the picture to me does not indicate a T-conn board.
Jun 15, 2012 | Samsung LN-S4051D 40 in. LCD Television
Snowy with blue and black squares
your va and vs need to be adjusted and if that doesnt fix it then you have a board going bad but still requiers repair or service tech to find out
Jan 14, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Picture clear then fades to snow when it does, makes annoying sound
sounds like poor solder on the ground conections of the tuner, depending on the age of the TV frostman
Feb 11, 2008 | Sony KV-27FS13 27" TV
NEC VH-605 VCR - Very Snowy Picture
Video head needs thorough cleaning. If no head cleaner, then run a few long tapes through it in the fast scan mode since the tape itself is abrasive and will over time remove debris from the heads. If that does not do it, try a chemical cleaner to dissolve the material.
Sep 01, 2017 | NEC Audio Players & Recorders
All the sudden my picture is bowed in the top left and bottom right
Snowy or intermittent picture
If you have much experience in dismantle TV set maybe you can do it by yourself. You need to solder all coils in stand up board and tuner.
For best result you can bring that to the TV Repair Shop possible it will only cost less $25.00USD to fix this problem.
Hope this wil work your problem.
Nov 24, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Akai leisure 2111 TV
try to check the video section, the diode and the capacitor.also the transistor>
Sep 19, 2007 | Akai LCT2060 Television
Rear projection snow
Bad primary tuner==can be replaced,or==by-pass by using video inputs.
Aug 26, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony KLV-S32A10 32 in. HD-Ready LCD Television Logo
130 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
