Canon Pixma mp800...2 years old.... got message "wrong print head"; i turned the machine off and now it will not turn back on?
  • taa5925 Nov 06, 2008
    I have had the printer for 2 years. Today I pressed Print and got message: "wrong printhead". I attempted to reset the printer; when this didn't work, I turned the printer off. I tried to turn the printer back on and absolutely nothing happens? What do you think has gone wrong. (Recently I installed this printer on a new computer, which is running Vista; printer has been working ok in this configuration for 6 months or so)
    I of course have check connections (having reconnected) and also pluged into a different electrical outlet.
  • 3,037 Answers
Probably a dead controller board. have you check voltage in the circuitry of the machine. In any case, I believe you will be replacing it as that would be the cheaper method rather than repairing it and I suggest going with an hp printer which I find much more reliable
let me know if you have any further questions and I would be glad to answer them
Posted on Nov 06, 2008
    Guru:
  • 558 Answers
Its printer head or the "strip cable" connecting the head of cartridge rack need to be replaced.
  • 6,487 Answers
Try to connect the printer back to the old computer where it was working fine before and also press the power button for about 10 sconds after you plug it to a power outlet and check if the printer will even respond....
  • 1,879 Answers
Now that the printer won't turn on:
disconnect the printer from the computer.
check for any obstructions inside.
use another power outlet.
turn it on.
if you can't go past this test, the printer needs servicing.
  • 19,396 Answers
Try unplugging the printer power cord for at least ten minutes, then plug it back.
Try also removing the ink cartridge and reinstalling them back on printer.
If that diod not work, then the print head is faulty and should be replaced.
Error B200
Get steps to Fix Canon Printer Error Code B200 instantly. Watch below video to learn how to fix Error Code B200 on PIXMA Printer Call now +44-8000465291 for instant Printer help.
Source: https://goo.gl/xskzcB
For 4+ Cartridge Printers:
Step1:-Remove All Printer Cartridges.
Do remove the individual ink cartridges from your printer. This will be opening the lid of your printer and waiting for the cartridge cradle to be placed in the correct position.
Step2:-Remove the Print-head.
This is can be done by lifting the orange or gray locking lever on the side of the cartridge cradle and then gently lifting the print-head from the printer.
Get full Step by click below link
How to Fix Error Code B200 on Canon PIXMA Printers 44 8000465291
Feb 01, 2016 | Office Equipment & Supplies
"wrong cartridge"- Printer is giving us a "wrong
Hi Sherri
I am having the same problem with my MP780 mine started doing the same thingafter deciding to use Calidad inks the large black ink leaked into the yellowink (stick to canon inks).
What I have done so far with no success -
Replaced the ink cartridges with new ones supplied by Calidad, still the sameproblem.
Removed and cleaned the print heads manually and to my surprize after soakingin warm water and multiple cleanings for over 1hr black ink is still coming outof the yellow ink head.
I still get the same message after all I have tried...
One thing I did manage to do is prime the yellow ink and got it flowing throughthe head again but it's still mixed with black... I wonder if you may have runout of magenta and dried the head...
Try priming the magenta ink by removing the head (don't touch or wet the metalcontacts at the rear, the ink heads are on the bottom) place on a clean lintfree cloth (or I just used damp tissues then dry tissues) you should get onelong black strip and two cyan, two magenta and two yellow strips on the tissue,if you do not then try priming by replacing the magenta cartridge and gentlypumping the cartridge up and down repeat until you get the ink flowing.
Replace the head and cartridges, press ok, turn the printer off then reset.
Let me know if it works or if you come up with another solution that works as Iam still trying to figure out how to fix mine.
Good luck
Dec 21, 2010 | Canon PIXMA MP780 All-In-One InkJet...
I am getting a "wrong print head" error message.
Turn the printer off.
Disconnect the power-cord from the wall-outlet.
Reconnect the power.
Turn the printer on.
If you still get the same message, it's time to responsibly recycle the printer,
and buy a replacement -- maybe you can buy a new PIXMA that takes the same ink-cartridges???
Dec 08, 2010 | Canon PIXMA MP810 All-In-One InkJet...
Canon PIXMA iP3000 inkjet printer- print head is overheating
Try to remove the print head from printer and turn it on.If starts you need to replace the print head.It's part number is QY6-0064 becouse the old print head QY6-0034 is discontinued.
Oct 09, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Printer made machine gun noise. will not print.
The print head is stuck - something has jammed it and the noise you are hearing is the carriage for the print head. Open the top and try moving the head by head sideways to see what has jammed it.
Aug 31, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Canon Pixma MP780 "Wrong Cartridge" Error Message
I have two Pixma 780's. After getting the "wrong cartridge" error one day when I turned it on, (I knew it was the right cartridge) I tried switching ink tanks, and the print head cartridge several times between the two printers. the problem followed the black print head cartridge, so I am guessing I need a new one. From that experience, I would recomend swithing the print cartridge if you get this error. Does anyone know how to do a reset on this machine? A Canon tech told me once, but I lost the info.
Jun 05, 2008 | Canon PIXMA MP780 All-In-One InkJet...
PIXMA MP780 "WRONG CARTRIDGE" MESSAGE?
Here is what I did and it now works just fine.I turned off the printer and unplugged the power cord, and unplugged it from my computer. I then removed all the ink cartriges and removed the print Head I got some rubbing alcohol put it on some toilet paper and wiped down the back and bottom of the print head.Plugged everything back in and It now works better then ever.
Feb 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
NO PRINT HEAD
First remove cartridges and remove print head and make sure the contacts on back of head look clean. I use fibreglass pen and give clean if in doubt.But be very carefull cleaning. But maybe not seated correctly.? If you pull the print head out and do another test does it come up with same message.?
Try again and see what you get. Still worth replacing head if faulty as where else can you get a 8 ink printer. Unsure what head costs.
Nov 12, 2007 | Canon PIXMA iP8500 InkJet Photo Printer
19 people viewed this question
jasbo
jasbo
