Question about GoVideo Televison & Video
My GoVideo VCR had a tape stuck in the DEck 1 side and after powering off and on it ejected the tape. Now deck 1 no longer will accept a tape. Also, deck 2 the tape will not go past a time of 3 hours on SLP. Where do I take it to be repaired or what do you suggest ? It is out of warranty. I bought it around in 2000.
  • jsclafani1 Nov 06, 2008
    I live in E. Greenville, Pa. 18041 I do have the
    tape out of the VCR.
  • 849 Answers
It is out of date product, must cost higher for repairing, even then try a qualified technician of vcr around you.
Posted on Nov 10, 2008
  • 1,879 Answers
Here's a list for you :
http://yp.yahoo.com/yp/East_Greenville_PA/Retail_Shopping_Home_Electronics_TV_and_Electronics_Repair/94168756.html
  • 83 Answers
A small eject spring inside your VCR having problem you need to take it to service center
    Genius:
  • 1,239 Answers
Hi if you have firmware install it
    Scholar:
  • 155 Answers
Remove all the connections of the tape and wait for a minute then again connect and see it should work.as you said it is out of warranty so you can try opening the device and check out the lens.
you can get it repaired at any local electronics reparing shop.as if the lens is faulty it will cost you much, for any other problem it will not cost you much.
thanks.
Posted on Nov 06, 2008
    Sergeant:
    Novelist:
  • 196 Answers
Either the lens is faulty or dusty open the dvd cover and clean it.or check any thing blocking the door.tap the sides of dvd player and then try.
  • 10,594 Answers
Best option is to buy new VCR on ebay some thing approx $20-30
  • 6,487 Answers
You can try to open the VCR and manually remove the stuck tape before taking it to a repair center, but if you want inform us where are you located so we can check for the nearest service center near you....
Have a Sony HVR M25U deck and put in a mini-dv tape and the tape played fine but not able to play, ffwd, rwd or stop. So I unplugged power cord on deck. Plugged power cord back in and now the tape is...
DO NOT , UNPLUG THE POWER CHORD, DO ONE THING SWITCH ON THE VTR AND THEN HAVE AN ALL PIN .. THEN RESET THE MACHINE ... WITH THAT PIN .. AND THEN PRESS EJECT ... YOUR TAPE WILL COME OUT ..
Jul 14, 2011 | Sony HVR-M25U HDV VCR
Videotape dubbing deck dead
1. Check to see if a tape is jammed inside (see 284 Extract a Jammed Videotape).
2. Try changing the video input and/or output source. Many VCRs have two ways to receive and send a video signal (coaxial and video direct). If that works, try changing the cable for the other method to see whether you need a new cable.
3. Clean tape heads (see How to Clean VCR Heads).
4. Open VCR and inspect any belts that are accessible (see 284 Extract a Jammed Videotape). A drive belt may be broken or loose.
If tapes are getting stuck / enmeshed inside the machine, itis 90% probability) a mechanical problem. Change the Belts, clean all rollers, idlers, and braking pads.
I would suggest that you also replace the Capstan Pinch Roller.
Goodluck..
Feb 17, 2008 | Rio Go Video DDV9556 Dual Deck VCR
VCR Deck not working
i found a website that explained what was wrong and how to fix.
Jan 06, 2009 | GoVideo Televison & Video
How to time loading arm cogs on VCR?
Most Panasonic VCR use a mechanisms with a letter. For example the NV-HS900 uses a K Deck. What you need to do is type the model number into google and search for which deck it uses. Then with luck you might also find the instructions for setting the deck up correctly. I got the K-Deck one free.
Jan 03, 2009 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Request for GoVideo Email Address
It seems that Go Video is now out of business.
Their website is no longer working and the telephone is out of service.
Dec 06, 2008 | GoVideo Go Video DVD/VCR Combo
Won't properly accept tapes/ tape won't fully insert
probably a bent cassette housing in the deck - time to seek out jvc authorized repair.
Jun 12, 2008 | JVC BR-DV3000U DV/Mini DV VCR
VCR repeatedly tries to play and eject when tape deck is empty
the tape carriage is probably stuck, or something stuck inside blocking the tape sensor.
feed a tape in and see if it does it "with" the tape too
hope this helps
Jan 08, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Go video gv6060
check the drive belt - it's probably stretched and won't operate the mechanism to eject the tape.
Nov 27, 2007 | Rio Go Video GV6060 Dual Deck VCR
Televison & Video Logo
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
