Question about Brother MFC-7220 All-In-One Laser Printer
CHANGE DRUM SOON
I replaced my toner cartridge with the factory TN-350 when the error message "CHANGE DRUM SOON" appeared and no ink showed up on the print function.
Since then, I still get the Change drum soon error and Dust on Drum errors, subsequently, it doesn't allow me to print or copy...I hope its allowing my faxes to go through, as there is no confirmation printed.
I have used canned air to clean the inside of the machine and I have replaced the cartridge a couple of times .
On occasion, i can pull down the front cover and close it which allows the machine to function properly for whatever event I am doing, but its not happening anymore.
It will take copies into the memory, but won't print the copies.
HELP, need to get some work done.
Glenn
    President:
  • 1,314 Answers
You need to change the drum on your printer. Part # DR-350.
Thanks and please take a moment to rate as fixya.
Posted on Nov 06, 2008
  • jeffpilote Feb 03, 2011
    I changed the drum (and cartridge before) too and I still get the message... Do I have to reset it or something?
    Thnx
    Jeff
I HAVE REPLACED TONER WITH THE CORRECT BROTHER TONER CARRTRIDGE AND THE MACHINE KEEPS TELLING ME TONER ERROR AND REINSTALL DRUM UNIT..HELP
Below are instructions that I have found from the internet. Hope that they will help.
  • Open the front cover of the printer.
  • Hold down the Go button for 4 seconds until all the LEDs light up. Then release the Go button
  • Remove the drum unit and toner cartridge assembly.
  • Replace the drum unit and toner cartridge assembly back into the printer.
  • Close the front cover of the printer
  • Your drum unit should now be reset
  • MFC / DCP PRINTER SERIES
    1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
    2.Replace the drum unit and toner cartridge into printer.
    3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
    4.To clear this error message, you need to reset the drum counter as instructed below.
    5.Make sure that the machine is turned on.
    For MFC users: To confirm you are installing a new drum, press 1. For DCP users To confirm you are installing a new drum, press the Up Arrow key
    7.When the LCD shows Accepted, close the front cover.
    8.Your drum is now reset.
    Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
Feb 24, 2015 | Brother MFC-8860DN Printer
How to reset " replace drum" for brother MFC-7860DW
Time to really order a new drum and really replace with a new one.
6.Press Options.
Jul 30, 2014 | Brother MFC-7860DW Laser All-In-One
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
Can not find out how to change ink cartridge on a tn 350
tn 350 is a toner cartridge, you pull the toner and drum out together, set on a table, press the blue lever on the side of the holder and lift out the toner. Remove all packing and insert the toner front edge first into the holder and then snap down the rear edge. Re insert into the printer and close the front door...
Feb 13, 2010 | Office Equipment & Supplies
Change drum
You need to go buy a Brother DR-350 drum unit cartridge. The drum unit is the thing that the toner cartridge (TN-350) clicks into. Pull out the drum/toner unit and separate the two halves. Place your TN-350 into the new DR-350 cartridge and put back in the printer.
Jan 18, 2010 | Brother IntelliFax-2820 Laser Fax
I have a Brother fax and copy machine and have just replaced toner with a brother TN 350 cartridge and still getting message that toner is low
You didn't include the model, but here are instructions for the Fax-2820; it should work for any of the models that use the TN-350 toner:
  1. With the power on, open the front cover.
  2. Press the Options key. The display will read "Change Drum?"
  3. Press Start.
  4. Press 1 0.
  5. The display reads "Accepted" for about 2 seconds, then change to "Cover Open."
  6. Close cover. The "Replace toner" message should be cleared.
Normally, inserting a new cartridge (with the power on) will reset the toner counter, and you won't have to do any of this.
Dec 21, 2009 | Brother IntelliFax-2820 Laser Fax
The toner tray will not pull out from the machine
Replacing the Toner Cartridge
The MFC can print up to 6,000 pages using a high yield toner cartridge. When
the toner cartridge is running low, the LCD shows TONER LOW. The MFC is
supplied with a standard toner cartridge that must be replaced after
approximately 3,000 pages. Actual page count will vary depending on your
average document type (i.e., standard letter, detailed graphics).
Discard the used toner cartridge according to local regulations. If you are not
sure of them, your local Sanitation Department. Be sure to seal the toner
cartridge tightly so toner powder does not spill out of the cartridge. When
discarding used toner cartridges, keep them separate from domestic garbage.
We recommend that you clean the MFC when you replace the toner cartridge.
1 Open the front cover and pull out the drum unit.
Place the drum unit on a drop cloth or large piece of disposable paper to avoid
spilling and scattering the toner.
2 Hold down the lock lever on the right and pull the toner cartridge out of the drum
unit assembly.
Caution
Handle the toner cartridge carefully. If toner scatters on your hands or clothes,
immediately wipe it off or wash it with cold water.
3 Unpack the new toner cartridge. Place the used toner cartridge into the
aluminum bag and discard it according to local regulations.
 Wait to unpack the toner cartridge until immediately before you install it in the
MFC. If a toner cartridge is left unpacked for a long period of time, the toner life
is shortened.
 You can use only a genuine Brother toner cartridge (TN-430 or TN-460), which
is specially formulated to ensure top print quality. Using another brand of toner
cartridge may void your MFC’s warranty. Warranty coverage does not apply to
problems caused by the use of 3rd party Toner, 3rd party Toner Cartridge or 3rd
party Drum unit.
4 Gently rock the toner cartidge from side
to side five or six times to distribute the
toner evenly inside the cartridge.
5 Remove the protective cover.
6 Insert the new toner cartridge in the
drum unit until it clicks into place.
7 Clean the primary corona
wire inside the drum unit by
gently sliding the blue tab
from right to left several
times. Return the blue tab to
the Home position ( )
before reinstalling the drum
unit assembly.
Reinstall the drum unit and close the
front cover.
Replacing the Drum Unit
The MFC uses a drum unit to create print images on paper. If the LCD shows
CHANGE DRUM SOON, the drum unit is near the end of its life and it is time
to purchase a new one.
Even if the LCD shows CHANGE DRUM SOON, you may be able to continue
printing without having to replace the drum unit for a while. However, if there
is a noticeable deterioration in the output print quality (even before CHANGE
DRUM SOON appears), then the drum unit should be replaced. You should
clean the MFC when you replace the drum unit. (See page 21-18.)
Caution
When removing the drum unit, handle it carefully because it contains toner. If
toner scatters and your hands or clothes get dirty, immediately wipe or wash
with cold water.
WARNING
Just after you have used the MFC, some
internal parts of the MFC are extremely
HOT! So please be careful.
The drum unit is a consumable item, and it is necessary to replace it periodically.
There are many factors that determine the actual drum life, such as temperature,
humidity, type of paper and how much toner you use for the number of pages per print
job. The estimated drum life is up to 20,000 pages. The actual number of pages your
drum will print may be significantly less than these estimates. Because we have no
control over the many factors that determine the actual drum life, we cannot
guarantee a minimum number of pages that will be printed by your drum.
Oct 02, 2009 | Brother MFC-9840CDW Laser Printer
Brother MCF-7340 first time toner replacement
If this model comes with the drum separately of the cartridge, only replace the cartridge. There's no need to change it every time. until prints start to get lines or dots. Don't expose the drum to light too much.
Jul 30, 2009 | Brother MFC-7340 All-In-One Laser Printer
Toner for fax machine 2920
If your machine is a Brother Intellifax 2920, it does take a TN-350 toner cartridge. Maybe you were wanting to replace the Drum Unit instead, DR-350. I'll bet this info is useful, yes?
Jul 03, 2009 | Brother FAX-2920 Plain Paper Laser
DRUM ERROR
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
It happens because Brother decide that we are morons and cannot figure out when a drum is dead and so they make the printer refuse to work after a certain amount of time. This resets their dummy counter.
Jul 07, 2008 | Brother MFC-7820N Printer
Brother MFC-7220 All-In-One Laser Printer Logo
524 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
