Question about Proscan Televison & Video
Proscan television repair
I'm a service center that repairs televisions. I'm in need of a Remote control and a IR Board for Proscan model# 26LB30H. Do you have contact information?
SOURCE: Sova Digital DS205-S32 Television power cord adaptor
Here is the contact info I found for SOVA. Hope it helps... Registrant: Sova Digital Inc. 17300 Dallas Pkwy Suite 3158 Dallas, Texas 75248 United States Registered through: GoDaddy.com, Inc. (http://www.godaddy.com) Domain Name: SOVAUSA.COM Created on: 12-Feb-04 Expires on: 12-Feb-07 Last Updated on: 22-Feb-06 Administrative Contact: , yongshen@sovadigital.com Sova Digital Inc. 17300 Dallas Pkwy Suite 3158 Dallas, Texas 75248 United States Technical Contact: , yongshen@sovadigital.com Sova Digital Inc. 17300 Dallas Pkwy Suite 3158 Dallas, Texas 75248 United States +1 (972)8181088 Good luck.
Posted on Jan 10, 2007
I finally got the power supply fixed.It cost about $300,but the TV works know. Same Day TV in Norfolk VA
Posted on Jan 24, 2008
  • 25 Answers
SOURCE: How to activate "closed captioning" for a Proscan Full HD 1080P
Comcast's remote has nothing to do with closed captioning. It's on your tv remote. First, the tv has to be capable of handling closed captioning, and your's is- and second, the program must have closed captioning provided- current programs do, some older shows do not support closed captioning. Recheck your remote, and if necessary- look at the setup instructions that came with the TV- they should also be posted online at the Proscan support site.
Posted on Apr 02, 2009
SOURCE: I need a universal remote
I can confirm that the 0441 code does indeed work for the Xbox 360 Universal Remote. I just programmed it and it works perfectly. Thanks to the person that first posted that code!
Posted on Apr 06, 2009
  • 2326 Answers
SOURCE: proscan lcd tv model 26lb30h blows fuse on power board
If the fuse blows again after replacing it, there's a shorted diode, bridge rectifier, capacitor or transistor in the power supply.
I repair these power supplies. If you need furhter assistance, write to jah2mil@hotmail.com
Posted on Jun 20, 2009
Why do I get a "No Sync. Signal" note when I attempt to use my DVD player on Input 2?
Depending on the TV model, there were some where the IR (Infrared) board inside the TV failed. It is not the remote that failed. You can test the remote by trying it at a Best Buy store on some of their TV's. If you are somewhat handy, you can easily remove the IR board and send it into a repair service that I located on E-Bay. There was repair service in Indiana and one in California. I sent it to the California and it came back in less than 1 week. I installed it and the TV works fine now.
Feb 21, 2015 | Hitachi 42HDS69 42 in. Plasma Television
FAILURE OF REMOTE FUNCTION
The Sony remote may be working fine. You may have to test it on another Sony TV such as at Best Buy or at a friend's place. Some of the Sony TV's had a bad or defective infrared(IR) board. If the IR board fails, then the TV will not respond to the remote. The TV will work fine with the manual controls, but will not respond to the remote. If you are handy with taking apart computers, then taking out the IR board is not that hard. It looks like a computer memory or RAM board. One can buy a replacement board on the internet or send your bad IR board in for repair. I did just that last week by sending it to a repair service. I got the board back in less than a week and installed it. The Sony TV works fine with the remote now. I found the repair service on E-Bay. There was one in Indiana and one in California. I used the one in California. It all depends on the Sony model, but there appears to be a bunch of models with a defective IR board. Yes, it was really frustrating.
Feb 12, 2015 | Sony Televison & Video
I have a 26lb30h proscan 26
Hello
There are two possibilites for this fault. The first one is shorted inverter transformer in the backlight inverter board. The second one is the fault with main board. For both faults, card base replacement is only possible. Check out which board has the short, and replace it.Image of the digital board is given here. Baclight inverter board can be located aty the panel itself, will be fitted vertically at the right or left side of it.2_8_2012_5_34_32_pm.jpg
Feb 08, 2012 | Proscan 26LB30H 26 in. LCD TV
My remote stopped working on my tv how do i fix it
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
Oct 29, 2010 | Proscan 26LB30QD 26 in. LCD HDTV
My remote dose not work. I Have had it for only 2 months!!! 1:Checked voltage on batts both read 1.67v 2:Cable company tech said eye on TV is defective.
Tv only bought for 2 months,no way the the tv IR board dies that fast.The tv remote CPU is shorted and dead.The remote is the problems.Call Proscan customers service,talk to them get ur warrenty at work.Tell them u need another tv remote.Might have to send their old remote back.
Oct 25, 2010 | Proscan 40LD45Q TV
LG 47LC7DF LCD TV Remote Sensor not working
IR senor may not be bad. Try using a different remote (universal) and program to TV. If universal remote works and your doesn't, you may need to purchase a remote instead of IR board. If you confirmed that the IR board is bad then replacing the IR board will fix the remote issue. IR board is an easy fix. Just open the back cover out and it's located right in the middle toward the bottom of the TV.
Jun 22, 2009 | LG 47LC7DF 47 in. LCD HDTV
Proscan lcd tv model 26lb30h blows fuse on power board
Jun 20, 2009 | Proscan 26LB30H 26 in. LCD TV
Proscan universal remote
Found these codes on the website for PROSCAN. www.oncorpus.com, for you model television.I hope this help you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
Feb 17, 2009 | Proscan 32LA30Q Television
Televison & Video Logo
42 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
